SPECIFICATION
Patent Granted
FXP74 Black Diamond 2.4GHz Band Antenna
Part No.
FXP74.07.0100A
Product Name
FXP74 Black Diamond 2.4GHz Antenna
Feature
4dBi Peak Gain
Flexible, Ultra Low Profile
IPEX MHF I Connector (U.FL compatible)
100mm 1.13 Mini-Coaxial Cable
47*7*0.1 mm
RoHS & Reach Compliant
SPE-12-8-137/F/OH
Page 1 of 15
US Patent #9214732
1. Introduction
The FXP74 Black Diamond is a small ultra-low profile antenna for 2.4GHz band that
includes Bluetooth, Zigbee and Wi-Fi single band application. The FXP74 has a peak
gain of 4dBi at 2.4GHz and efficiencies of above 50%.
This Taoglas patent granted antenna is unique in the market with exceptionally stable
performance different applications. It is made from a flexible polymer, has a tiny form
factor (14mm*7.0mm*0.1mm) and has double-sided 3M tape for easy and robust
“peel and stick” mounting.
The FXP74 is the ideal all-round antenna solution for fitting into narrow spaces and
still maintaining high performance, for example on the inside top or adjacent side
applied directly to the plastic housing of LCD monitors, tablets, smartphones, small AP
routers, etc.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least
1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this
effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our antennas’
peak gain will be below the peak gain limits. Taoglas can then issue a specification
and/or report for the selected antenna in your device that will clearly show it
complying with the peak gain limits, so you can be assured you are meeting
regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than
2dBi peak gain, but you don’t need to select an embedded antenna that has a peak
gain of less than 2dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3dBi or more if available.
SPE-12-8-137/F/OH
Page 2 of 15
US Patent #9214732
Once that antenna gets integrated into your device, performance will degrade below
this 2dBi peak gain due to the effects of GND plane, surrounding components, and
device housing. If you want to be absolutely sure, contact Taoglas and we will test.
Choosing a Taoglas antenna with a higher peak gain than what is specified by the
module manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
SPE-12-8-137/F/OH
Page 3 of 15
US Patent #9214732
2. Specification
Communication
System
Bluetooth
24012480
WiFi
24122462
ZigBee
24102480
Efficiency
50%
Gain
4dBi
Return Loss
< -10dB
Impedance
50 Ohms
VSWR
≤ 2:1
Polarization
Linear
Power Handled
5W
2.4GHz ISM
2400-2483.5
MECHANICAL
Dimensions
47*7*0.1 mm
Weight
1.2 g
Connector
MHFI (U.FL Compatible)
Cable Standard
Cable Length and
color
Mini-Coax 1.13 mm
Adhesive tape
3M 467
100mm, Black
ENVIRONMENTAL
Operation
Temperature
Storage
Temperature
RoHS Compliant
-40 ºC ~ +85 ºC
-40 ºC ~ +85 ºC
Yes
SPE-12-8-137/F/OH
Page 4 of 15
US Patent #9214732
3. Antenna Characteristics
3.1.
Test Setup
Rohde & Schwarz ZNB 8 Vector Network Analyzer
ETS 3D Radiation Scan System with Anechoic Chamber
Y
X
Z
SPE-12-8-137/F/OH
Page 5 of 15
US Patent #9214732
3.2.
Return Loss
3.3.
Peak Gain
SPE-12-8-137/F/OH
Page 6 of 15
US Patent #9214732
3.4.
Average Gain
3.5.
Efficiency
SPE-12-8-137/F/OH
Page 7 of 15
US Patent #9214732
4. Antenna Radiation Pattern
XY-plane
XZ-plane
SPE-12-8-137/F/OH
Page 8 of 15
US Patent #9214732
YZ-plane
SPE-12-8-137/F/OH
Page 9 of 15
US Patent #9214732
5. Antenna Drawing
SPE-12-8-137/F/OH
Page 10 of 15
US Patent #9214732
6. Packaging
SPE-12-8-137/F/OH
Page 11 of 15
US Patent #9214732
7. Return Loss – environmental effects
7.1.
Antenna on different ABS thickness
(Cable Length 100mm)
SPE-12-8-137/F/OH
Page 12 of 15
US Patent #9214732
7.2.
Proximities to metal ground plane
(Cable Length 100mm, antenna stuck on 2mm ABS base)
SPE-12-8-137/F/OH
Page 13 of 15
US Patent #9214732
7.3.
Antenna with different cable type
(Antenna stuck on 2mm ABS base)
SPE-12-8-137/F/OH
Page 14 of 15
US Patent #9214732
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice. Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
© Taoglas
SPE-12-8-137/F/OH
Page 15 of 15
US Patent #9214732
很抱歉,暂时无法提供与“FXP74.07.0100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+26.98712
- 95+23.06964
- 100+18.71688
- 国内价格 香港价格
- 3+34.988263+4.53515
- 10+28.9706210+3.75515
- 100+20.44607100+2.65020
- 200+19.75752200+2.56095
- 500+19.14187500+2.48115
- 2500+18.582922500+2.40870
- 国内价格
- 1+55.10160
- 200+21.98880
- 500+21.25440
- 1000+20.89800
- 国内价格 香港价格
- 100+27.34136100+3.54396
- 300+24.84230300+3.22004
- 国内价格 香港价格
- 1+39.360851+5.10192
- 10+29.7551010+3.85683
- 100+20.44987100+2.65070
- 200+19.51754200+2.52985
- 500+18.69748500+2.42355
- 2500+17.964992500+2.32861
- 国内价格 香港价格
- 5+40.047375+5.19091
- 10+30.2740910+3.92410
- 100+20.80655100+2.69693
- 200+19.85797200+2.57397
- 500+19.02360500+2.46582
- 2500+18.278342500+2.36922
