CGGP.35.3.A.02
CGGP.35.3.A.02
    TAOGLASLIMITED
    CGGP.35.3.A.02
CGGP.35.3.A.02 数据手册
Part No: CGGP.35.3.A.02 Description: 3.5mm height GPS/GLONASS/Galileo Patch Antenna 1575/1610MHz Features: Wide-band Operation 35mm*35mm*3.5mm 4dBi Peak Gain (on 50mm*50mm ground-plane) 85% Efficiency (on 50mm*50mm ground-plane) Pin type Automotive TS16949 Production and Quality Approved RoHS & Reach Compliant SPE-11-8-062-N 1. Introduction 3 2. Specifications 4 3. Antenna Test Setup 5 3. Antenna Characteristics 6 4. Antenna Radiation Pattern 8 5. Axial Ratio 10 6. Mechanical Drawing 11 7. PCB Footprint Recommendation 13 8. Evaluation Board 14 9. Packaging 15 Changelog 16 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-11-8-062-N www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction The Taoglas 35mm ceramic GPS/GLONASS/GALILEO patch antenna, by means of a double resonance design, has unique wide-band operation over the whole operating bands of GPS/GLONASS/Galileo systems spanning from 1575MHz to 1610MHz. It is mounted via pin and double-sided adhesive. This antenna has been tuned for a center position on a 50mm*50mm ground-plane. It is manufactured and tested in a TS16949 first tier automotive approved facility. 1. Introduction optimization to customer specific device environments where positioning is off center or on different 1.For further Introduction ground-plane sizes, custom tuned patch antennas can be supplied. Taoglas can also provide different pin lengths for these antennas, subject to potential NRE and MOQ. For more details please contact your regional Taoglas customer support team. 1. Introduction 1. Introduction SPE-11-8-062-N www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. 4. Application Bands GPS/Galileo GLONASS Operation Frequency 1575.42 ±1.023MHz 1602±5MHz Bandwidth 1.5 Peak Gain 4.0dBi typ. Gain at Zenith 4.0dBi Antenna Patterns3.Antenna Gain atRadiation 10°elevation Axial Ratio Impedance 3. 22MHz min Antenna Characteristics VSWR Characteristics2. 3. Specifications Electrical 1.5dBi typ. 3dB max Specifications 50 Ohms Efficiency 85% typ. Frequency Temperature Coefficient(τf) 0 ± 20ppm / oC Antenna Characteristics2. Mechanical Specifications Ceramic Dimension 35*35*3.5mm Pin Length 2.4mm Diameter AntennaPinCharacteristics 0.9mm Environmental Storage Temperature 4. Operating Temperature Antenna Radiation Patterns3.Antenna -40°C to +85°C -40°C to +85°C Moisture Sensitivity Level 3 * Antenna properties were measured with the antenna mounted on 50*50mm Ground Plane Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-062-N Specifications www.taoglas.com 4 3. Antenna Test Setup 3. Antenna Characteristics2. 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. Specifications Specifications Return Loss measurement of the CGGP.35.3.A.02 3. Antenna Characteristics2. Specifications Z 3. Antenna Characteristics X 4. Y Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Peak gain, efficiencyPatterns and radiation pattern measurements of the CGGP.35.3.A.02 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-062-N Specifications www.taoglas.com 5 4. Antenna Characteristics Loss Characteristics2. 3.4.1 Return Antenna Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. 3. Specifications Antenna Characteristics2. Specifications 3.4.2 VSWR Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-062-N Specifications www.taoglas.com 6 4.3 Efficiency 4.4 Peak Gain SPE-11-8-062-N www.taoglas.com 7 4. Antenna Radiation Pattern 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. 1560Mhz Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. 1575Mhz Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-11-8-062-N www.taoglas.com 8 1590Mhz 1610Mhz SPE-11-8-062-N www.taoglas.com 9 5. Axial Ratio 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical1575.42MHz Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 1602MHz 7. Application Note6. Packaging5. Mechanical Drawing 6.SPE-11-8-062-N Packaging5. Mechanical Drawing www.taoglas.com 10 6. Mechanical Drawing (Unit: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. SPE-11-8-062-N Packaging5. Mechanical Drawing www.taoglas.com 11 Adhesive Thickness Red Line shows the adhesive without Liner – thickness 0.08~0.1mm SPE-11-8-062-N www.taoglas.com 12 7. PCB Footprint Recommendation 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6.SPE-11-8-062-N Packaging5. Mechanical Drawing www.taoglas.com 13 8. Evaluation Board CGGPD.35.A (Unit: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. SPE-11-8-062-N Packaging5. Mechanical Drawing www.taoglas.com 14 9. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. SPE-11-8-062-N Packaging5. Mechanical Drawing www.taoglas.com 15 Changelog for the datasheet SPE-11-8-062– CGGP.35.3.A.02 Revision: N (Current Version) Date: Changes: Changes Made by: 2021-06-12 Updated Pin Length to 2.4mm Updated Drawing Dan Cantwell Previous Revisions Revision: H Revision: M Date: Changes: Changes Made by: 2020-11-23 Updated to new format Dan Cantwell Revision: L Date: Changes: Changes Made by: Changes Made by: David Connolly Changes Made by: Aine Doyle Date: Changes: Changes Made by: 2015-06-01 Amended PCB Footprint Aine Doyle Revision: F 2019-02-12 Amended Drawing Technical Writer Revision: J Date: Changes: Changes Made by: 2015-10-02 Added efficiency Rating to cover page Revision: G 2019-04-12 Added AR Values Revision: K Date: Changes: Date: Changes: Date: Changes: Changes Made by: 2014-08-19 Removed Circular Polarization data from spec Aine Doyle Revision: E 2016-09-09 Updated drawing as per PCN Andy Mahoney Revision: I Date: Changes: Changes Made by: 2014-07-04 Updated test results Aine Doyle Revision: D Date: Changes: Changes Made by: SPE-11-8-062-N 2016-05-12 Updated Packaging Spec Aine Doyle Date: Changes: Changes Made by: 2014-11-06 Added EBV information Aine Doyle www.taoglas.com 16 Revision: C Date: Changes: Changes Made by: 2013-04-15 updated Supplier spec with GND plane info Aine Doyle Revision: B Date: Changes: Changes Made by: 2011-08-30 Technical Writer Revision: A (Original First Release) Date: Notes: Author: SPE-11-8-062-N 2011-07-29 Technical Writer www.taoglas.com 17 www.taoglas.com SPE-11-8-062-N © Taoglas 18 www.taoglas.com
CGGP.35.3.A.02 价格&库存
很抱歉,暂时无法提供与“CGGP.35.3.A.02”相匹配的价格&库存,您可以联系我们找货
CGGP.35.3.A.02
  • 10+47.36046
  • 55+40.48068
  • 100+32.91171
库存:45
CGGP.35.3.A.02
    • 1+99.10080
    • 216+39.54960
    • 504+38.22120
    • 1008+37.57320
