Front
Back
Maximus
FXUB66.01.0150C
Specification
Patent Granted
Part No.
FXUB66.01.0150C
Product Name
Maximus
Flexible Ultra Wide-Band Antenna 700-6000MHz
Feature
Patent Granted
Ground Plane Independent
700-6000MHz
5 dBi Peak Gain
Efficiencies above 60% on all cellular 2G/3G/4G bands
120.4x50.4x0.2 mm size
SMA(M) Connector
RoHS Compliant
SPE-12-8-145/C/RC |
US Patent 9257747
page 1 of 15
1. Introduction
The patent granted Maximus FXUB66
flexible ultra wide band antenna has been
designed to cover all working frequencies
in the 700-6000 MHz spectrum, including
all Cellular, Wi-Fi, ISM and GNSS bands.
Its use in a device improves substantially
the radiated power and sensitivity,
and enables the highest throughput
rates of today’s broadband devices.
The antenna is delivered with a flexible
body with ground breaking high efficiencies
on all bands, ground-plane independent,
with a cable and connector for
easy installation. It is made of durable
flexible polymer, with a peak gain of 5dBi,
an efficiency of more than 60% across
all cellular bands and is designed to be
mounted directly onto a plastic or glass
enclosure / cover.
At 120.4x50.4x.2mm, the antenna is ultra
thin. It is assembled by a simple “peel and
stick” process, attaching securely to
non-metal surfaces via 3M adhesive.
predominant propagation modes - one for
lower frequencies, (e.g. LTE at 700 MHz)
and the other for higher 4G and Wi-Fi
frequencies up to 6GHz.
It enables designers to use only one
antenna that covers all frequencies and
future proofs device design for LTE and
4G globally. It is also the ideal antenna to
fit in devices that are being retrofitted with
wireless functionality, as it will cover non
cellular applications such as 868, 915MHz
or Zigbee applications. It’s inherently wide
bandwidth is more resistant to detuning
than traditional small but narrow-band
legacy antennas.
It is an ideal choice for any device maker
that needs to keep manufacturing costs
down over the lifetime of a product,
as the same antenna can be used if the
radio module is upgraded to work on
a different frequency band.
Cables and connectors are customizable.
The Maximus antenna has a unique
hybrid design. Within one antenna structure
the electromagnetic waves travel in two
SPE-12-8-145/C/RC |
US Patent 9257747
page 2 of 15
2. Specification
Electrical
Band
Standard
700
1400
1575
1700
850
1800
900
1900
LTE
2600
3500
5000
LTE
LTE
ISM
LTE
UMTS
ISM
GSM
HSPA
WIFI
CDMA
CDMA
698960
Polarization
Linear
Impedance (Ohms)
50 Ohms
Max VSWR
3.5:1
Max Return Loss (dB) -5
GPS
2400
GSM
Frequency (MHz)
MIL
2100
WIFI
13901435
1575.42
17101990
17552170
24002500
25002700
34003600
48006000
3.5:1
1.1:1
3.0:1
3.3:1
2.2:1
2.0:1
2.2:1
3.0:1
-5
-20
-6
-5.5
-7
-10
-7
-6
Peak Gain (dBi)
2.7
3.8
5
5
5
3.5
3.8
6.4
5.5
Efficiency (%)
80
55
75
78
65
75
75
85
60
Average Gain (dB)
-0.97
-2.6
-1.1
-1
-1.8
-1.1
-1.1
-0.7
-2
Radiation Properties
Omni-directional
Max Input Power
(Watts)
5W
* Antenna measured on 2mm ABS plastic plate.
Mechanical
Dimensions (mm)
120.4x50.4x0.2 mm
Material
Flexible Polymer
Connector and Cable
SMA(M) and 1.37mm mini coax
Environmental
Operation Temp.
-40°C to 85°C
Storage Temp.
-40°C to 85°C
Relative Humidity
40% to 95%
RoHs Compliant
Yes
SPE-12-8-145/C/RC |
US Patent 9257747
page 3 of 15
3. Test Set Up
Figure 1. Impedance measurements (left hand) and peak gain, average gain, efficiency and radiation
pattern measurements (right hand)
4. Antenna Parameters
4.1 Return Loss
Return Loss (dB)
-10
-15
-20
-25
600
1100
1600
2100
2600
3100
3600
4100
4600
5100
5600
6100
MHz
Figure 2. Return loss of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC |
US Patent 9257747
page 4 of 15
4.2 VSWR
VSWR
6
5
4
3
2
1
1100
1600
2100
2600
3100
3600
4100
4600
5100
5600
6100
4600
5100
5600
6100
MHz
Figure 3. VSWR of FXUB66 UWB Antenna
4.3 Efficiency
Efficiency (%)
100
90
80
70
60
50
40
30
1100
1600
2100
2600
3100
3600
4100
MHz
Figure 4. Efficiency of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC |
US Patent 9257747
page 5 of 15
4.4 Peak Gain
Peak Gain (dBi)
7
6
5
4
3
2
1
1100
1600
2100
2600
3100
3600
4100
4600
5100
5600
6100
5600
6100
MHz
Figure 5. Peak Gain of FXUB66 UWB Antenna
4.5 Average Gain
Average Gain (dB)
-2
-3
-4
-5
600
1100
1600
2100
2600
3100
3600
4100
4600
5100
MHz
Figure 6. Average Gain of FXUB66 UWB Antenna
SPE-12-8-145/C/RC |
US Patent 9257747
page 6 of 15
4.6 Radiation Pattern
Figure 7. Radiation Pattern at 750 MHz of FXUB66 UWB Antenna.
Figure 8. Radiation Pattern at 850 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC |
US Patent 9257747
page 7 of 15
Figure 9. Radiation Pattern at 925 MHz of FXUB66 UWB Antenna..
Figure 10. Radiation Pattern at 1400 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC |
US Patent 9257747
page 8 of 15
Figure 11. Radiation Pattern at 1575 MHz of FXUB66 UWB Antenna.
Figure 12. Radiation Pattern at 1750 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC |
US Patent 9257747
page 9 of 15
Figure 13. Radiation Pattern at 1850 MHz of FXUB66 UWB Antenna.
Figure 14. Radiation Pattern at 1950 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC | page 10 of 15
US Patent 9257747
Figure 15. Radiation Pattern at 2100 MHz of FXUB66 UWB Antenna..
Figure 16. Radiation Pattern at 2450 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC | page 11 of 15
US Patent 9257747
Figure 17. Radiation Pattern at 2600 MHz of FXUB66 UWB Antenna.
Figure 18. Radiation Pattern at 3600 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC | page 12 of 15
US Patent 9257747
Figure 19. Radiation Pattern at 5500 MHz of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC | page 13 of 15
US Patent 9257747
5. Mechanical Drawing
Name
Material
Finish
QTY
1
FXUB66 FPCB
FPCB 0.1t
Black
1
2
1.37 Coaxial Cable
FEP
Black
1
3
SMA(M)ST
Brass
Gold
1
4
Double-Sided Adhesive
3M 467
Brown Liner
1
5
Heat Shrink Tube 1.37
PE
Black
1
Figure 20. Mechanical drawing of FXUB66 UWB Antenna.
SPE-12-8-145/C/RC | page 14 of 15
US Patent 9257747
5 包裝規格
5.1 每個小 PE 袋放置 100 天線
【100cs antennas per small PE bag】
5.2 每個大 PE 袋放置 10 個小 PE 袋,如下圖所示
【10 small PE bag per big PE bag】
6. Packaging
5.3 每包大 PE 袋內數量共 1000pcs 天線
【1000pcs antennas per big PE bag】
5.4100pcs
封口時須注意不可壓到天線,裝入需平整不可雜亂
【Antenna should be placed flat and neat in the PE bag. Hot seal the PE bag without
pressing or damage the antenna】
5.5 清點每袋數量不可短缺
【Confirm the quantity in each PE bag】
taoglas
1215
Ultra W ide Band Antenna
700-6000 M Hz
FXUB66
MAXIM US
FXUB66
P atent Pending
小 PE 袋
大 PE 袋
UNLESS OTHER SPECIFIED TOLERANCES ON:
Taoglas makes no warranties based on the
product descriptions at any time
X=±
X.X=± of the contents
X.XX= without notice. Taoglas reserves all
accuracy or completeness
ANGLES=±
HOLEDIA=±
of this document and reserves the
right to
rights to this document and the
SCALE:
xxxx
make changes
to specificationsUNIT:mm
and
information contained herein.
DRAWN BY: Gabriel
CHECKED BY: Wayne
DESIGNED BY: Orville
APPROVED BY: Wayne
TITLE: FXUB66 Antenna Assembly
ISO NO: PSP-12-8-0214
DOCUMENT
NO.
Reproduction, use or disclosure to third
parties without express permission is
strictly prohibited.
Copyright © Taoglas Ltd.
SPE-12-8-145/C/RC
FXUB66.01.0150C
US Patent 9257747
REV.
| PAGE
page 15
of 15
B
很抱歉,暂时无法提供与“FXUB66.01.0150C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+50.96344100+6.60584
- 300+50.62905300+6.56249
- 500+48.82968500+6.32926
- 1000+48.264401000+6.25599
- 国内价格 香港价格
- 1+89.189971+11.56072
- 10+74.9733010+9.71797
- 25+74.0814025+9.60236
- 100+51.85234100+6.72105
- 300+51.51211300+6.67695
- 500+49.68136500+6.43965
- 1000+49.106221000+6.36510
- 国内价格 香港价格
- 1+70.922151+9.19286
- 50+52.4922950+6.80400
- 100+49.49505100+6.41550
- 国内价格 香港价格
- 8+103.610818+13.42994
- 国内价格 香港价格
- 国内价格
- 10+45.96999
- 50+45.09944
- 100+42.57242
- 国内价格
- 1+124.76160
- 200+49.78800
- 500+48.12480
- 1000+47.30400
