ANT-2.4-CW-CT-SMA
ANT-2.4-CW-CT-SMA
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    ANT-2.4-CW-CT-SMA
ANT-2.4-CW-CT-SMA 数据手册
ANT-2.4-CW-CT-xxx Data Sheet by Product Description 10.0 mm (0.39”) The CT Series ½-wave 2.4GHz antenna delivers outstanding performance in a rugged and cosmetically-attractive package. The antenna’s internal counterpoise eliminates external ground plane dependence and maximizes performance. CT Series antennas attach using a standard SMA or Part 15 compliant RP-SMA connector, though alternate connectors and custom colors are available for volume OEM customers. Features • • • • • • • Internal counterpoise Excellent performance Omni-directional pattern Very low VSWR Fully weatherized Rugged and damage-resistant Standard SMA or Part 15 compliant RP-SMA connector 84.0 mm (3.31”) 113.0 mm (4.44”) Electrical Specifications Center freq. Bandwidth: Wavelength: Peak Gain: VSWR: Impedance: Connector: Oper. Temp. Range: 2.45GHz 150MHz ½-wave 2.8dBi
ANT-2.4-CW-CT-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-CW-CT-SMA”相匹配的价格&库存,您可以联系我们找货
