SPECIFICATION
Part No.
TG.22.0112
Product Name
Penta-Band Cellular Connector Mount Monopole Helical
GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA
824MHz ~2170 MHz
Features
2.5dBi Gain
SMA(M) Fixed Right Angle plug
50 Ohms
ROHS & REACH Compliant
SPE-11-8-110-G
Page 1 of 43
1. Introduction
The TG.22.0112 Penta-band GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA 824MHz to
2170MHz monopole helical antenna is a quality robust antenna with high gain in small
form factor.
Connection is made via fixed right angle SMA(M) connector with a hardened waterproof
PU casing, this antenna is the ideal GSM antenna for telematics devices.
2. Antenna Performance
2.1 Electrical Specifications
Parameter
Bands
Specification
GSM850
GSM900
DCS
PCS
WCDMA I
824~896MHz
880~960MHz
1710~1880MHz
1850~1990MHz
1920~2170MHz
Frequency
Range
Return Loss
≦-5dB
VSWR
≦3.5
Peak Gain
1.49dBi
1.93dBi
2.37dBi
2.58dBi
2.23dBi
Efficiency
66.24%
70.86%
70.47%
68.87%
65.40%
Average Gain
-1.81dBi
-1.50dBi
-1.52dBi
-1.63dBi
-1.89dBi
Polarization
Linear
Power handling
20 W
Impedance
50 Ohms
Connector
SMA(M) Right Angle
*All the antenna characteristics were measured with 150mm*90mm ground plane
2.2 Environmental & Mechanical Characteristics
Parameter
Specification
Temperature
-40°c to +85°c
Radome Colour
Black
Radome Material
TPEE
Weight
8g
SPE-11-8-110-G
Page 2 of 43
3. Test Set Up
Figure 1. Impedance and VSWR measurements
SPE-11-8-110-G
Page 3 of 43
4. Performance Measurements
4.1 Return Loss
Figure 2. Return Loss of TG.22.0112
4.2 VSWR
Figure 3. VSWR of TG.22.0112
SPE-11-8-110-G
Page 4 of 43
4.3
Efficiency (%)
Figure 4. Efficiency of TG.22.0112
4.4
Peak Gain(dBi)
Figure 5. Peak Gain of TG.22.0112
SPE-11-8-110-G
Page 5 of 43
4.5
Average Gain(dBi)
Figure 6. Average Gain of TG.22.0112
SPE-11-8-110-G
Page 6 of 43
4.6
Radiation Pattern Data
Y
X
Z
SPE-11-8-110-G
Page 7 of 43
4.6.1
XY-Plane
Radiation Pattern
X
Y
X
Y
SPE-11-8-110-G
Page 8 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 9 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 10 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 11 of 43
Z
Y
SPE-11-8-110-G
Page 12 of 43
5. Mechanical Drawing
unit:mm
SPE-11-8-110-G
Page 13 of 43
6. Packaging
1pcs antennas per small PE bag.
100 small PE bags per big PE bag.
100pcs antennas per big sealed PE bag.
SPE-11-8-110-G
Page 14 of 43
7. Installation
SPE-11-8-110-G
Page 15 of 43
8. Application Note
This section, Taogals provides the ground variation effects to TG.22.0112 antenna. Detail
setup is setup as below.
Ground Plane Dimensions:
10cm*4cm
20cm*20cm
40cm*40cm
30cm*30cm
50cm*50cm edge
SPE-11-8-110-G
Page 16 of 43
Return Loss:
Efficiency:
SPE-11-8-110-G
Page 17 of 43
Peak Gain:
Radiation Pattern Measurement Setup:
10cm*4cm Ground Plane
Setup
Y
Z
X
SPE-11-8-110-G
Page 18 of 43
XY-Plane
X
Y
X
Y
SPE-11-8-110-G
Page 19 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 20 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 21 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 22 of 43
Z
Y
20cm*20cm Ground Plane
Setup
Y
Z
X
SPE-11-8-110-G
Page 23 of 43
XY-Plane
X
Y
X
Y
SPE-11-8-110-G
Page 24 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 25 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 26 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 27 of 43
Z
Y
30cm*30cm Ground Plane
Setup
Y
Z
X
SPE-11-8-110-G
Page 28 of 43
XY-Plane
X
Y
X
Y
SPE-11-8-110-G
Page 29 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 30 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 31 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 32 of 43
Z
Y
40cm*40cm Ground Plane
Setup
Y
Z
X
SPE-11-8-110-G
Page 33 of 43
XY-Plane
X
Y
X
Y
SPE-11-8-110-G
Page 34 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 35 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 36 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 37 of 43
Z
Y
50cm*50cm Ground Plane Edge
Setup
Y
Z
X
SPE-11-8-110-G
Page 38 of 43
XY-Plane
X
Y
X
Y
SPE-11-8-110-G
Page 39 of 43
X
Y
XZ-Plane
Z
X
SPE-11-8-110-G
Page 40 of 43
Z
X
Z
X
SPE-11-8-110-G
Page 41 of 43
YZ-Plane
Z
Y
Z
Y
SPE-11-8-110-G
Page 42 of 43
Z
Y
SPE-11-8-110-G
Page 43 of 43
很抱歉,暂时无法提供与“TG.22.0112”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+116.95320
- 200+46.66680
- 500+45.11160
- 1000+44.34480
