PA.25A
PA.25A
    TAOGLASLIMITED
    PA.25A
PA.25A 数据手册
Part No: PA.25A Description: Anam Hexa-Band Cellular SMT Antenna 800 MHz to 2200 MHz Features: Compact High Efficiency Antenna Surface Mount Device Dimensions: 35*5*6mm Manufactured in an IATF16949 Approved Facility RoHS & REACH Compliant SPE-11-8-061-L 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Pattern 7 5. Mechanical Drawing 10 6. Eval Board Drawing 11 7. Antenna Integration Guide 12 8. Recommended Reflow Temperature Profile 20 9. Packaging 21 Changelog 22 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-11-8-061-L www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. The PA.25A is ceramic cellular antenna designed for in-device mounting. The PA.25A is mounted through SMT process and can be used in varying applications based on it’s small form factor of just 35*6*5mm. Introduction Typical Applications Include: - Body Worn Devices - Hand-held IoT Devices - Remote Monitoring Introduction This ceramic multiband cellular antenna uses high grade ceramics which have been developed in Taoglas through years of expertise in delivering the right materials for high performance antennas. Taoglas, through constant research and development have designed a small form factor high efficiency antenna for use across cellular bands from 800MHz to 2170MHz. Introduction The PA.25A is manufactured and tested in our IATF16949 approved facility. Introduction The PA.25 is a unique SMT solution which is delivered on tape and reel. For very detailed integration information additional to this specification please download our comprehensive PA.25 integration application note from our website. For further information, please contact your regional Taoglas customer support team. SPE-11-8-061-L www.taoglas.com 3 2. Specifications Electrical 3. Antenna Characteristics2. Band Frequency (MHz) 4G/3G/NB-IoT/Cat M Band 5,8,18,19,20,26,27 3. 1710~2200 70 -1.55 2.00 VSWR Impedance 58 -2.39 50Ω Polarization Linear Radiation Properties Omnidirectional Max Input Power 5W 3.51 Antenna Radiation Patterns3. Antenna Mechanical Dimensions (mm) 3. Peak Gain (dBi)
PA.25A 价格&库存
很抱歉,暂时无法提供与“PA.25A”相匹配的价格&库存,您可以联系我们找货
