TG.22.0111
TG.22.0111
    TAOGLASLIMITED
    TG.22.0111
TG.22.0111 数据手册
SPECIFICATION Part No. : TG.22.0111 Product Name : TG22 2G/3G Cellular Connector Mount Monopole Antenna GPRS-GSM-DCS-PCS-UMTS-CDMA- EDGE-HSPA 824MHz ~2170 MHz Features : Ground dependent (Needs mounting to ground-plane) 3dBi Gain 30%+ Efficiency Dimensions - 49mm * 8mm 50 Ohms Straight SMA Male Connector customizable ROHS Compliant SPE-11-8-109/I/SS Page 1 of 33 1. Introduction The TG.22.0111 2G/3G monopole helical antenna operates from 824MHz to 2170MHz on GSM-DCS-PCS-UMTS-CDMA-GPRS-EDGE-HSPA. Once mounted to an adequate ground-plane it is a compact robust terminal antenna with high gain and stable efficiency in a small form factor. Connection is made via straight SMA(M) connector. Typical applications - Remote monitoring At only 49mm in height, with a hardened TPEE casing, this antenna is the ideal GPRS/UMTS antenna for telematics devices where larger antennas cannot be used. Like all small monopole antennas, it must be mounted on a ground-plane to radiate efficiently. The antenna should be mounted at the edge of the ground-plane of the mainboard of the device. See below charts for analysis of performance. A larger ground-plane of more than 100mm is needed for stable performance on all bands. Also no metal should be used near the antenna, with at least 20mm of clearance required, the more clearance the better. For devices with ground-planes smaller than 100mm in length or where metal clearance is not adequate, alternative larger antennas should be considered such as the TG.30. If small size is needed, a custom tuned solution or a new design may also be necessary. Contact your Taoglas regional sales office for support. SPE-11-8-109/I/SS Page 2 of 33 2. Electrical Specification Parameter Specification Bands GSM850 GSM900 DCS PCS WCDMA I 1850~1990MHz 1920~2170MHz Frequency Range 824~896MHz 880~960MHz 1710~1880MHz Return Loss ≦-5dB VSWR ≦3.5 Peak Gain 1.42dBi 1.91dBi 2.51dBi 3.23dBi 2.89dBi Efficiency 64.40% 68.29% 70.67% 72.61% 68.48% Average Gain -1.92dBi -1.66dBi -1.51dBi -1.39dBi -1.67dBi Polarization Linear Power handling 20 W Impedance 50 Ohms Connector Straight SMA(M) *All the antenna characteristics were measured with 150mm*90mm ground plane Environmental & Mechanical Characteristics Parameter Specification Temperature -40˚C to +85˚C Radome color Black Radome material TPEE Weight 6g SPE-11-8-109/I/SS Page 3 of 33 3. TEST SET UP Figure 1. Impedance and VSWR measurements SPE-11-8-109/I/SS Page 4 of 33 4. ANTENNA PARAMETERS 4.1. Return Loss Figure 2. Return Loss of TG.22.0111 4.2. VSWR Figure 3. VSWR of TG.22.0111 SPE-11-8-109/I/SS Page 5 of 33 4.3 Efficiency (%) Figure 4. Efficiency of TG.22.0111 4.4 Peak Gain(dBi) Figure 5. Peak Gain of TG.22.0111 SPE-11-8-109/I/SS Page 6 of 33 4.5 Average Gain(dBi) Figure 6. Average Gain of TG.22.0111 4.6 Radiation Pattern Data Y X Z SPE-11-8-109/I/SS Page 7 of 33 4.6.1 XY Plane Radiation Pattern X Y X Y SPE-11-8-109/I/SS Page 8 of 33 X Y XZ Plane X SPE-11-8-109/I/SS Page 9 of 33 X X SPE-11-8-109/I/SS Page 10 of 33 YZ-Plane Y Y SPE-11-8-109/I/SS Page 11 of 33 Y SPE-11-8-109/I/SS Page 12 of 33 5. Drawing and Dimensions (unit: mm) SPE-11-8-109/I/SS Page 13 of 33 6. Packaging SPE-11-8-109/I/SS Page 14 of 33 7. Installation SPE-11-8-109/I/SS Page 15 of 33 8. Application Note This section, Taogals provides the ground variation effects to TG.22.0111 antenna. Detail setup is setup as below. 8.1 Ground Plane Dimensions: 30*30cm 20*20cm 10cm*4cm 8.2 Return Loss: SPE-11-8-109/I/SS Page 16 of 33 8.3 Efficiency: 8.4 Peak Gain: SPE-11-8-109/I/SS Page 17 of 33 8.5 Radiation Pattern Measurement Setup: 8.5.1 30cm*30cm Ground Plane Setup Y X Z XY-Plane X Y SPE-11-8-109/I/SS Page 18 of 33 X Y X Y SPE-11-8-109/I/SS Page 19 of 33 XZ-Plane Z X Z X SPE-11-8-109/I/SS Page 20 of 33 Z X YZ-Plane Z Y SPE-11-8-109/I/SS Page 21 of 33 Z Y Z Y SPE-11-8-109/I/SS Page 22 of 33 8.5.2 20*20cm Ground Plane Setup Y Z XY-Plane X X Y SPE-11-8-109/I/SS Page 23 of 33 X Y X Y SPE-11-8-109/I/SS Page 24 of 33 XZ-Plane Z X Z X SPE-11-8-109/I/SS Page 25 of 33 Z X YZ-Plane Z Y SPE-11-8-109/I/SS Page 26 of 33 Z Y Z Y SPE-11-8-109/I/SS Page 27 of 33 8.5.3 10cm*4cm Ground Plane Setup Y Z XY-Plane X X Y SPE-11-8-109/I/SS Page 28 of 33 X Y X Y SPE-11-8-109/I/SS Page 29 of 33 XZ-Plane Z X Z X SPE-11-8-109/I/SS Page 30 of 33 Z X YZ-Plane Z Y SPE-11-8-109/I/SS Page 31 of 33 Z Y Z Y SPE-11-8-109/I/SS Page 32 of 33 SPE-11-8-109/I/SS Page 33 of 33
TG.22.0111 价格&库存
很抱歉,暂时无法提供与“TG.22.0111”相匹配的价格&库存,您可以联系我们找货
TG.22.0111
    • 12+65.5063912+8.47500
    • 55+57.8203155+7.48060
    库存:67
    TG.22.0111
    • 1+59.498931+7.69778
    • 10+45.2776010+5.85787
    • 25+44.8226025+5.79900
    • 100+30.35137100+3.92676
    • 300+30.04826300+3.88755
    • 500+29.54573500+3.82253
    • 1000+28.668291000+3.70901
    • 2500+28.532692500+3.69147
    库存:4500
    TG.22.0111
    • 12+60.81231
    • 55+53.70935
    库存:67
    TG.22.0111
    • 15+41.78651
    • 65+35.69264
    • 100+28.99423
    库存:81
    TG.22.0111
    • 2+60.536702+7.83204
    • 10+46.0673210+5.96004
    • 25+45.6043925+5.90015
    • 100+30.88076100+3.99525
    • 300+30.57236300+3.95535
    • 500+30.06106500+3.88920
    • 1000+29.168321000+3.77370
    • 2500+29.030352500+3.75585
    库存:4500
    TG.22.0111
      TG.22.0111
      • 100+39.63775100+5.12820
      库存:100
      TG.22.0111
      • 1+61.620321+7.97224
      • 10+47.4345910+6.13693
      • 25+43.8831725+5.67746
      • 100+39.97966100+5.17244
      • 300+37.80393300+4.89095
      • 500+36.99923500+4.78684
      • 1000+36.076391000+4.66745
      • 2500+35.102292500+4.54142
      库存:1239
      TG.22.0111
      • 1+64.595451+8.35715
      • 65+41.6342465+5.38650
      库存:75
