CGGBP.35.6.A.02
CGGBP.35.6.A.02
    TAOGLASLIMITED
    CGGBP.35.6.A.02
CGGBP.35.6.A.02 数据手册
GPS/GLONASS/BeiDou Patch Part No: CGGBP.35.6.A.02 Description: GPS/GLONASS/Galileo/BeiDou Embedded Patch Antenna Features: Dielectric Ceramic BeiDou 1561MHz / GPS-Galileo 1575MHz / GLONASS 1602MHz Pin Mount Dimensions: 35mm*35mm*6.5mm RoHS & Reach Compliant SPE-14-8-018-G 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. 2D Radiation Patterns 9 5. Mechanical Drawing 12 6. Evaluation Board Drawing 13 7. Footprint 14 8. Packaging 15 Changelog 17 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. © Taoglas SPE-14-8-018-G www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. Introduction The Taoglas CGGBP.35.6.A.02 is a Circularly Polarized embedded GNSS patch designed for use across the full single band GNSS spectrum. This 35mm square ceramic GPS/GLONASS/Galileo/BeiDou patch antenna's wide band of operation leads to excellent gain and radiation pattern stability on all GNSS system bands. Introduction 1. Typical applications include: - Agriculture - Asset tracking systems - Navigation 1. Compared to using a smaller antenna, this will translate into the GNSS system having much higher location accuracy, improved reliability of lock in urban areas, better signal reception, with more satellites acquired and a quicker time to first fix. Introduction Introduction The patch is mounted via pin and double-sided adhesive and can be custom tuned to a device subject to NRE, for further information please contact your regional Taoglas customer support team. SPE-14-8-018-G www.taoglas.com 3 2. Specifications GNSS Frequency Bands Covered L1 L2 L5 L6 3. GPS/QZSS Antenna Characteristics2. 1575.42MHz 1227.6MHz 1176.45MHzSpecifications 1278.75MHz GLONASS 3. ■ □ □ □ L5R 1176.45MHz L3PT 1201.5MHz L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ ■ ■ E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz L1 1575.42MHz □ ■ ■ Antenna□ Characteristics □ Galileo E5a 1176.45MHz E5b 1201.5MHz □ □ □ Antenna□ Radiation Patterns3.Antenna 4. BeiDou B1 1561MHz B2 1207.14MHz E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz Characteristics2. ■ Compass B3 1268.52MHz Specifications □ □ ■ Antenna□ Characteristics2. 3. SBAS Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ ■ Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-018-G Specifications www.taoglas.com 4 GNSS Electrical Frequency (MHz) 1561 1575.42 1602 Average Gain (dB) -0.2 -0.3 -0.2 Efficiency (%) 97 94 95 Peak Gain (dBi) 5.8 5.5 5.6 Axial Ratio (dB) 13 9 3 Polarization RHCP Impedance 50Ω Mechanical Dimensions 35 x 35 x 6.5mm Material Ceramic Pin Diameter 0.9mm Pin Length 2.4mm Weight 29g Environmental Temperature Range SPE-14-8-018-G -40°C to 85°C www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 0 4. 4. Return Loss [dB] -5 Antenna Radiation Patterns -10 -15 Antenna Radiation Patterns3.Antenna -20 Characteristics -25 1500 1525 1550 1575 1600 1625 1650 1675 1700 Frequency [MHz] Antenna Radiation Patterns3.Antenna 4. Characteristics 3.2 Efficiency 100 4. 90 Antenna Radiation Patterns 80 4. 4. Efficiency [%] 70 60 Antenna Radiation Patterns 50 40 30 Antenna Radiation Patterns 20 10 4. 0 Antenna 1300 1350Radiation 1400 1450Patterns3.Antenna 1500 1550 1600 1650 Characteristics 4. 1750 1800 1850 1900 Frequency [MHz] Antenna Radiation Patterns3.Antenna SPE-14-8-018-G 1700 www.taoglas.com 6 3.3 Average Gain 0 -1 Aver Gain [dB] -2 -3 -4 -5 -6 -7 -8 1300 1350 1400 1450 1500 1550 1600 1650 1700 1750 1700 1750 1800 1850 1900 Frequency [MHz] 3.4 Peak Gain 7 6 5 Gain [dBi] 4 3 2 1 0 -1 -2 1300 1350 1400 1450 1500 1550 1600 1650 1800 1850 1900 Frequency [MHz] SPE-14-8-018-G www.taoglas.com 7 3.5 VSWR 11 VSWR 9 7 5 3 1 1500 1550 1600 1650 1700 Frequency [MHz] 3.6 Axial Ratio SPE-14-8-018-G www.taoglas.com 8 4. 2D Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y X Z On Evaluation Board SPE-14-8-018-G www.taoglas.com 9 XY Plane XZ Plane SPE-14-8-018-G www.taoglas.com 10 YZ Plane SPE-14-8-018-G www.taoglas.com 11 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-018-G Mechanical Drawing www.taoglas.com 12 6. Evaluation Board Drawing 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-018-G www.taoglas.com 13 7. Footprint 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-018-G www.taoglas.com 14 8. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 12 pieces per tray 6 Trays per Inside Box = 72 7.4 InsideApplication Packaging Boxes per OuterNote6. Carton -Outer Carton contains 288 pieces 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-018-G Mechanical Drawing www.taoglas.com 15 SPE-14-8-018-G www.taoglas.com 16 Changelog for the datasheet SPE-14-8-018 – CGGBP.35.6.A.02 Revision: G (Current Version) Date: Changes: Changes Made by: 2021-06-08 Pin Length changed to 2.4mm Drawing updated Dan Cantwell Previous Revisions Revision: F Revision: A (Original First Release) Date: Changes: Changes Made by: 2020-01-27 Installation Guide Amended Jack Conroy Date: Notes: 2014-03-04 Author: Aine Doyle Revision: E Date: Changes: Changes Made by: 2018-03-27 Installation Guide Amended Jack Conroy Revision: D Date: Changes: Changes Made by: 2017-06-27 David Connolly Revision: C Date: Changes: Changes Made by: 2015-01-06 PCB Footprint Made by Andy Mahoney Revision: B Date: Changes: Changes Made by: SPE-14-8-018-G 2014-11-17 Evaluation Board Added Aine Doyle www.taoglas.com 17 www.taoglas.com © Taoglas SPE-14-8-018-G www.taoglas.com 18
CGGBP.35.6.A.02 价格&库存
很抱歉,暂时无法提供与“CGGBP.35.6.A.02”相匹配的价格&库存,您可以联系我们找货
CGGBP.35.6.A.02
