SPECIFICATION
FXP.810 2.4/4.9-6GHz Dual-band Antenna
Part No.
FXP.810.07.0100C
Product Name
FXP.810 Freedom Wi-Fi 2.4/4.9-6GHz Series
PIFA Antenna
Feature
Very High Efficiency
Ground-plane Independent
IPEX MHF1 Connector (U.FL compatible)
1.37mm Diameter Micro Cable - 100 mm
31*31*0.1mm
RoHS Compliant
SPE-11-8-050/F
Page 1 of 12
1. Introduction
The FXP810 has a peak gain of 1.5dBi at 2.4GHz and efficiencies of 60-70%,
increasing to 5dBi and 80-90% along bands 4.9GHz to 6GHz.
At 31*31*0.1mm in size this antenna is uniquely valuable for small tag type mobile
devices in that it can slip between the battery and the main PCB ground of
small devices to get increased performance from the ground coupling effect. Only the
top 6.5mm radiating element needs to protrude out from the side of the main board,
allowing such devices to have the highest possible performance at smallest possible
dimensions, it accomplishes this because it does not need clearance or footprint space
on the device board itself that all on-board chip, loop and patch antennas need.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least
1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this effect,
giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our antennas’
peak gain will be below the peak gain limits. Taoglas can then issue a specification
and/or report for the selected antenna in your device that will clearly show it
complying with the peak gain limits, so you can be assured you are meeting regulatory
requirements for that module.
For example, a module manufacturer may state that the antenna must have less than
2dBi peak gain, but you don’t need to select an embedded antenna that has a peak
gain of less than 2dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once
that antenna gets integrated into your device, performance will degrade below this
SPE-11-8-050/F
Page 2 of 12
2dBi peak gain due to the effects of GND plane, surrounding components, and device
housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing
a Taoglas antenna with a higher peak gain than what is specified by the module
manufacturer and enlisting our help will ensure you are getting the best performance
possible without exceeding the peak gain limits.
SPE-11-8-050/F
Page 3 of 12
2. Specification
ELECTRICAL
Frequency
2.4 ~ 2.5GHz,
4.9 ~ 5.8GHz
Peak Gain (free space)
1.5dBi
5.1dBi
Peak Gain (on plastic*)
2.4dBi
5.0dBi
Average Gain (free space)
-2.6dBi
-1.1dBi
Average Gain (on plastic)
-1.2dBi
-0.8dBI
Efficiency (free space)
56%
78%
Efficiency (on plastic)
76%
84%
VSWR
≦1.7 : 1
Impedance
50 Ohms
Polarization
Linear
Radiation Pattern
Omni
Input Power
2W max.
MECHANICAL
Dimensions
31mm*31mm*0.1mm
Antenna Body Material
Polymer
Cable
Gray 100mm 1.37 co-axial
Connector
IPEX MHFI
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
* On ABS Plastic 4mm
SPE-11-8-050/F
Page 4 of 12
3. Electrical Property
3.1 S11 Measurement
Free Space:
Plastic 1.5mm:
SPE-11-8-050/F
Page 5 of 12
3.2 Efficiency
FXP. 810
100
Efficiency (Free space)
90
80
70
60
50
40
30
2300
2400
2500
2600
2700
2800
2900
3000
5000
5200
5400
5600
5800
Frequency (MHz)
3.3 Gain
FXP. 810
8
7
6
Gain (dBi)
5
4
3
2
1
-2
-3
-4
-5
2200
2300
2400
2500
2600
2700
2800
2900
3000
5000
5200
5400
5600
5800
Frequency (MHz)
SPE-11-8-050/F
Page 6 of 12
3.4 Radiation Pattern
Y
Z
X
SPE-11-8-050/F
Page 7 of 12
2450MHz Pattern
4900 MHz Pattern
SPE-11-8-050/F
Page 8 of 12
5500 MHz Pattern
5900 MHz Pattern
SPE-11-8-050/F
Page 9 of 12
4. Mechanical Drawing.
SPE-11-8-050/F
Page 10 of 12
5. Packaging
SPE-11-8-050/F
Page 11 of 12
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-050/F
Page 12 of 12
很抱歉,暂时无法提供与“FXP810.07.0100C”相匹配的价格&库存,您可以联系我们找货
