TG.09.0113
TG.09.0113
    TAOGLASLIMITED
    4G/5G终端安装旋转单极子天线
TG.09.0113 数据手册
SPECIFICATION Part No. : TG.09.0113 Product Name : 4G/3G/2G Cellular Hinged SMA Male Monopole Feature : 700 MHz to 3800MHz LTE*/GSM/CDMA/HSPA/UMTS 700*/850/900/1700/1800/1900/2100/2300/3500/3700 Rotatable hinge design for optimal reception *LTE 700MHz Band Compatible only when connected directly on ground plane lengths of 60mm or more RoHS Compliant SPE-16-8-032/K/NW Page 1 of 37 1. Introduction The TG.09 Penta-band Cellular Hinged Rotatable SMA antenna is a high efficiency monopole antenna. Compared to other much larger antennas on the market, it has superior wide-band high efficiency characteristics. This antenna is used by many of the leading wireless device providers in the world marketplace. The unique rotatable hinge design enables the user to rotate the antenna to the best angle for an optimal cellular signal reception. As the upper antenna element can move in any direction, it also reduces damage from impact force from any angle to the antenna, compared to traditional hinged right angle or fixed fight angle designs or straight antennas. The tiny dimensions of this antenna coupled with excellent RF performance and an aesthetic high end design feel make it the ideal cellular antenna for routers, vehicle tracking devices, telematics devices, remote monitoring systems, and POS devices. The TG.09, as all monopole antennas works best connected directly to the ground-plane of the device main-board. Taoglas offers support services to characterize antenna efficiency on your individual device ground-plane. The TG.09 antenna also supports LTE 700MHz band applications when it is directly connected to ground-planes with lengths above 60mm. Please contact Taoglas regional support center first if you wish to do PTCRB or network approvals with this antenna attached to your device, so we can check RF integration is correct and do a pre-test first to ensure optimized passive and active performance and a smooth and quick certification approval process. This antenna also comes in a white version. TG.09.0113W SPE-16-8-032/K/NW Page 2 of 37 2. Specification ELECTRICAL Communication System Frequency (MHz) Efficiency (free space)* Gain (dBi, free space)* Efficiency (mounted on PCB)* Gain (dBi, mounted on PCB)* Impedance 4G/3G/2G Cellular 700 LTE AMPS GSM DCS PCS UMTS 2300 LTE 2300~ 2400 2700 LTE 2490~ 2690 3500 LTE 3400~ 3600 3700 LTE 3600~ 3800 703~ 803 824 ~ 896 880~ 960 1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 18% 22% 22% 25% 30% 30% 17% 32% 28% 43% -3.0 -2.6 -3.0 0.9 0.9 0.9 -1.3 1.1 1.8 3.1 52% 58% 57% 61% 58% 54% 31% 59% 36% 37% 0.8 1.7 1.8 3.4 3.4 3.4 2.3 3.7 4.3 2.6 50Ω Polarization Linear Radiation Pattern Omni-directional Input Power 10 W Antenna Length MECHANICAL 72 ± 1.5 mm Antenna Diameter 10 ± 0.3 mm Casing POM Connector SMA Male (Brass) Weight 8g Temperature Range Storage Temperature Humidity ENVIRONMENTAL -40°C to 85°C -40℃ ~ +85℃ Non-condensing 65°C 95% RH * Average efficiency and peak gain of antenna sitting 180° in Free Space and on 150*90mm ground plane at the side of the PCB. Please refer to section 3 for testing detail. SPE-16-8-032/K/NW Page 3 of 37 3. Antenna Characteristics 3.1 Test Setup The TG.09 was measured and tested in four different environments a. Free space b. On the edge of a 150*90mm ground plane - common size for IoT devices. TG.09 is mounted on the 90mm edge for testing. c. In the center of a 300*300mm ground plane – simulate the effect of mounting in the center of a big ground plane. d. On the edge of a 300*300mm ground plane - simulates the effect of mounting TG.09 on top of a large gateway/router. Straight Position Free Space 150mm x 90mm Ground Plane 300mm x 300mm Ground Plane Edge Antenna in 90° Bend Position SPE-16-8-032/K/NW Page 4 of 37 300mm x 300mm Ground Pane Center 150mm x 90mm Ground Plane Free Space 300mm x 300mm Ground Plane Edge Y Z Y Z X X Chamber Setup SPE-16-8-032/K/NW 300mm x 300mm Ground Pane Center Page 5 of 37 3.2 Return Loss 0 Return Loss [dB] -5 -10 -15 -20 -25 -30 -35 Free Space Straight Free Space Bend 150mm x 90mm Straight 150mm x 90mm Bend 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 Frequency [MHz] 0 Return Loss [dB] -5 -10 -15 -20 -25 300mm x 300mm Center Straight 300mm x 300mm Center Bend -30 -35 300mm x 300mm Edge Straight 300mm x 300mm Edge Bend 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 Frequency [MHz] SPE-16-8-032/K/NW Page 6 of 37 3.3 VSWR 10 Free Space Straight 9 Free Space Bend 8 150mm x 90mm Straight 150mm x 90mm Bend VSWR 7 6 5 4 3 2 1 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 Frequency [MHz] 10 300mm x 300mm Center Straight 300mm x 300mm Center Bend 300mm x 300mm Edge Straight 300mm x 300mm Edge Bend 9 8 VSWR 7 6 5 4 3 2 1 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 Frequency [MHz] SPE-16-8-032/K/NW Page 7 of 37 3.4 Efficiency 100 Free Space Straight Free Space Bend 150mm x 90mm Straight 150mm x 90mm Bend 90 Efficiency [%] 80 70 60 50 40 30 20 10 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] 100 90 Efficiency [%] 80 70 60 50 40 30 300mm x 300mm Center Straight 300mm x 300mm Center Bend 300mm x 300mm Edge Straight 300mm x 300mm Edge Bend 20 10 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] SPE-16-8-032/K/NW Page 8 of 37 Peak Gain Gain [dBi] 3.5 6 5 4 3 2 1 0 -1 -2 -3 -4 -5 -6 -7 -8 -9 Free Space Straight Free Space Bend 150mm x 90mm Straight 150mm x 90mm Bend 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] 8 7 6 5 Gain [dBi] 4 3 2 1 0 -1 300mm x 300mm Center Straight 300mm x 300mm Center Bend 300mm x 300mm Edge Straight 300mm x 300mm Edge Bend -2 -3 -4 -5 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] SPE-16-8-032/K/NW Page 9 of 37 3.6 Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 Free Space Straight Free Space Bend 150mm x 90mm Straight 150mm x 90mm Bend -10 -11 -12 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] 0 -1 Aver Gain [dB] -2 -3 -4 -5 -6 -7 300mm x 300mm Center Straight 300mm x 300mm Center Bend 300mm x 300mm Edge Straight 300mm x 300mm Edge Bend -8 -9 -10 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] SPE-16-8-032/K/NW Page 10 of 37 4. Radiation Patterns 4.1 TG.09 in Free Space – Straight SPE-16-8-032/K/NW Page 11 of 37 4.2 TG.09 in Free Space – 90° SPE-16-8-032/K/NW Page 12 of 37 4.3 TG.09 on 150*90mm Ground Plane – Straight SPE-16-8-032/K/NW Page 13 of 37 4.4 TG.09 on 150*90mm Ground Plane – 90° SPE-16-8-032/K/NW Page 14 of 37 4.5 TG.09 on 300*300mm Ground Plane Center – Straight SPE-16-8-032/K/NW Page 15 of 37 4.6 TG.09 on 300*300mm Ground Plane Center – 90° SPE-16-8-032/K/NW Page 16 of 37 4.7 TG.09 on 300*300mm Ground Plane Edge – Straight SPE-16-8-032/K/NW Page 17 of 37 4.8 TG.09 on 300*300mm Ground Plane Edge – 90° SPE-16-8-032/K/NW Page 18 of 37 5. 3D Radiation Pattern 5.1 Free Space – Straight 704MHz 751MHz 824MHz 960MHz 1710MHz 1880MHz 1990MHz 2170MHz 2300MHz 3400MHz SPE-16-8-032/K/NW 2500MHz 3500MHz Page 19 of 37 2690MHz 3600MHz 5.2 Free Space – 90° 704MHz 751MHz 824MHz 1710MHz 1880MHz 1990MHz 2300MHz 2500MHz 3400MHz SPE-16-8-032/K/NW 3500MHz Page 20 of 37 2690MHz 3600MHz 960MHz 5.3 150*90mm Ground Plane – Straight 704MHz 751MHz 824MHz 960MHz 1710MHz 1880MHz 1990MHz 2170MHz 2300MHz 2500MHz 2690MHz 2300MHz 2500MHz 2690MHz SPE-16-8-032/K/NW Page 21 of 37 5.4 150*90mm Ground Plane – 90° 704MHz 751MHz 824MHz 960MHz 1710MHz 1880MHz 1990MHz 2170MHz 2300MHz 2500MHz 2690MHz 3400MHz 3500MHz 3600MHz SPE-16-8-032/K/NW Page 22 of 37 5.5 300*300mm Ground Plane Center – Straight 704MHz 1710MHz 2300MHz 3400MHz SPE-16-8-032/K/NW 751MHz 824MHz 960MHz 1880MHz 1990MHz 2170MHz 2500MHz 3500MHz Page 23 of 37 2690MHz 3600MHz 5.6 300*300mm Ground Plane Center – 90° 704MHz 1710MHz 751MHz 1880MHz 824MHz 960MHz 1990MHz 2170MHz 2300MHz 2500MHz 2690MHz 3400MHz 3500MHz 3600MHz SPE-16-8-032/K/NW Page 24 of 37 5.7 300*300mm Ground Plane Edge – Straight 704MHz 751MHz 824MHz 960MHz 1710MHz 1880MHz 1990MHz 2170MHz 2300MHz 3400MHz SPE-16-8-032/K/NW 2500MHz 3500MHz Page 25 of 37 2690MHz 3600MHz 5.8 300*300mm Ground Plane Edge – 90° 704MHz 751MHz 824MHz 960MHz 1710MHz 1880MHz 1990MHz 2170MHz 2300MHz 3400MHz SPE-16-8-032/K/NW 2500MHz 3500MHz Page 26 of 37 2690MHz 3600MHz 6. Mechanical Drawing (unit: mm) 1 Housing POM Black 2 Hinge Brass Ni Plated 3 Cap POM Black 4 Connector SMA Male (Brass) SPE-16-8-032/K/NW Page 27 of 37 7. Installation SPE-16-8-032/K/NW Page 28 of 37 8. Minimum Ground Plane for LTE Efficiency Different Ground Plane lengths were considered for acceptable efficiency for LTE bands. Three different ground planes were chosen. They were all 30mm wide and the lengths were varied beginning at 90mm then 70mm and finally 60mm 90*30mm 70*30mm 60*30mm It was also considered whether the TG.09 antenna was positioned straight or at an angle of 90°. The antenna was positioned on the edge of the Ground Plane for all tests. SPE-16-8-032/K/NW Page 29 of 37 Parameter Straight Pose 700 Band LTE Frequency (MHz) Average Gain (dBi) Efficiency (%) Peak Gain (dBi) 90mm x 30mm Ground Return Loss (dB) Efficiency (%) Peak Gain (dBi) 70mm x 30mm Ground Return Loss (dB) Average Gain (dBi) Efficiency (%) Peak Gain (dBi) 60mm x 30mm Ground Return Loss (dB) DCS PCS 1710 1850 ~188 ~199 0 0 UMTS/ 2300 2700 3500 HSPA LTE LTE LTE 2300 2490 3400~ ~240 ~269 3600 0 0 824~ 803 960 -1.4 -3.2 -3.2 -1.9 -2.3 -5.1 -2.0 -3.8 -2.9 72% 49% 48% 64% 59% 31% 63% 42% 54% 2.0 1.9 2.7 3.2 3.6 1.3 5.2 2.7 4.2 4.8 5.1 11.4 -2.7 -2.7 -3.4 -2.2 53% 54% 45% 1.8 2.0 1.5 1920~ 3700LTE 703~ 9 Average Gain (dBi) GSM 2170 11.1 3600~ 3800 5.3 9.6 -1.8 -5.7 -1.5 -3.9 -2.0 60% 67% 28% 70% 42% 62% 3.5 4.3 1.7 4.3 3.7 5.0 7.3 7.1 4.2 7.3 -2.9 -2.9 -2.4 -1.6 -7.3 -1.4 -4.3 -3.0 41% 50% 51% 58% 69% 20% 72% 37% 49% 1.1 1.3 2.1 3.0 4.1 0.4 4.5 3.0 4.5 7.7 5.0 6.4 9.9 4.4 3.4 14.7 7.9 -3.9 6.5 12.4 9.5 12.4 8.9 9.9 6.3 6.4 90° Bend Pose Average Gain (dBi) Efficiency (%) Peak Gain (dBi) 90mm x 30mm Ground Return Loss (dB) Average Gain (dBi) Efficiency (%) Peak Gain (dBi) 70mm x 30mm Ground Return Loss (dB) Peak Gain (dBi) -2.4 -3.5 -2.1 -2.1 -5.3 -2.1 -3.3 -2.6 68% 58% 45% 61% 61% 30% 61% 47% 54% 2.7 2.5 2.1 3.1 3.5 1.6 5.2 3.4 4.3 7.5 7.6 4.5 9.1 -4.2 -2.3 -3.7 -2.5 39% 59% 42% 1.4 1.7 1.4 4.9 Average Gain (dBi) Efficiency (%) -1.7 60mm x 30mm Ground Return Loss (dB) SPE-16-8-032/K/NW 11.2 5.1 8.7 -1.8 -4.6 -1.5 -3.4 -2.0 56% 67% 35% 70% 46% 62% 3.2 4.3 2.1 4.1 4.1 5.1 3.9 6.4 12.5 13.5 5.2 12.6 12.3 7.8 10.6 9.5 -5.6 -3.0 -3.2 -2.6 -1.7 -5.9 -1.4 -3.9 -3.1 28% 50% 47% 54% 68% 26% 73% 41% 49% 0.0 1.0 1.8 3.0 3.8 1.1 4.3 3.3 4.5 4.4 11.5 4.6 Page 30 of 37 6.0 10.8 3.9 11.2 7.0 6.2 8.1 Return Loss 0 Return Loss [dB] -5 -10 -15 -20 90mm x 30mm Straight -25 70mm x 30mm Straight 60mm x 30mm Straight -30 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] 0 -5 Return Loss [dB] -10 -15 -20 -25 -30 -35 -40 -45 90mm x 30mm Bend 70mm x 30mm Bend 60mm x 30mm Bend -50 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] SPE-16-8-032/K/NW Page 31 of 37 8.2 VSWR 30 90mm x 30mm Straight 70mm x 30mm Straight 25 60mm x 30mm Straight VSWR 20 15 10 5 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] 25 90mm x 30mm Bend 70mm x 30mm Bend VSWR 20 60mm x 30mm Bend 15 10 5 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 3900 Frequency [MHz] SPE-16-8-032/K/NW Page 32 of 37 8.3 Efficiency for Straight Antenna 100 90 80 Efficiency [%] 70 60 50 40 30 90mm x 30mm Straight 20 70mm x 30mm Straight 10 60mm x 30mm Straight 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] 8.4 Peak Gain for Straight Antenna 6 5 4 Gain [dBi] 3 2 1 0 -1 90mm x 30mm Straight -2 70mm x 30mm Straight -3 60mm x 30mm Straight -4 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] SPE-16-8-032/K/NW Page 33 of 37 8.5 Average Gain for Straight Antenna 0 -1 Aver Gain [dB] -2 -3 -4 -5 -6 -7 90mm x 30mm Straight -8 70mm x 30mm Straight 60mm x 30mm Straight -9 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] 8.6 Efficiency for 90° Bend 100 90 Efficiency [%] 80 70 60 50 40 30 90mm x 30mm Bend 20 70mm x 30mm Bend 10 60mm x 30mm Bend 0 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] SPE-16-8-032/K/NW Page 34 of 37 8.7 Peak Gain for 90° Bend 6 5 4 3 Gain [dBi] 2 1 0 -1 -2 -3 -4 -5 -6 -7 90mm x 30mm Bend 70mm x 30mm Bend 60mm x 30mm Bend 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] 8.8 Average Gain for 90° Bend 0 -1 Aver Gain [dB] -2 -3 -4 -5 -6 -7 90mm x 30mm Bend -8 70mm x 30mm Bend -9 60mm x 30mm Bend -10 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 3100 3300 3500 3700 Frequency [MHz] SPE-16-8-032/K/NW Page 35 of 37 9. Packaging SPE-16-8-032/K/NW Page 36 of 37 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-16-8-032/K/NW Page 37 of 37
TG.09.0113
物料型号:TG.09.0113
器件简介:TG.09是一款高效率的单极天线,具有优越的宽带高效率特性,与市场上其他较大型天线相比,它具有更出色的性能。这款天线被世界上许多领先的无线设备提供商使用。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 通信系统:4G/3G/2G Cellular - 频率范围:703~3800MHz,支持LTE、AMPS、GSM、DCS、PCS、UMTS等多个频段 - 天线效率(自由空间):18%~43% - 增益(自由空间):-3.0~3.1 dBi - 阻抗:50欧姆线性 - 极化:未明确指出 - 辐射模式:全向 - 输入功率:10W
功能详解:TG.09天线具有独特的可旋转铰链设计,用户可以旋转天线以获得最佳的蜂窝信号接收角度。与传统的直角或固定角度设计或直线天线相比,这种设计还减少了来自任何角度的冲击力对天线的损害。
应用信息:这款天线非常适合路由器、车辆跟踪设备、远程监控系统、远程监测系统和POS设备等。
封装信息:天线长度72±1.5mm,直径10±0.3mm,外壳材料为POM,连接器为SMA Male(黄铜),重量为8g。
环境规格:工作温度范围-40°C至85°C,存储温度-40°C至+85°C,湿度为65°C下95%RH非凝结。
TG.09.0113 价格&库存
很抱歉,暂时无法提供与“TG.09.0113”相匹配的价格&库存,您可以联系我们找货
TG.09.0113
  • 10+127.0452010+16.46748
  • 25+73.7265625+9.55637
  • 50+65.0872050+8.43654
  • 100+61.39897100+7.95848
库存:150
TG.09.0113
    TG.09.0113
    • 1+91.804911+11.89967
    TG.09.0113
      TG.09.0113
      • 1+107.062351+13.87732
      • 10+81.2295010+10.52889
      • 25+81.2069325+10.52597
      • 100+52.26466100+6.77450
      • 300+51.74784300+6.70751
      • 500+49.92843500+6.47168
      • 1000+47.917851000+6.21107
      库存:139
