FXP75.07.0045B
FXP75.07.0045B
    TAOGLASLIMITED
    FXP75.07.0045B
FXP75.07.0045B 数据手册
Specification Patent Pending Part No. : FXP75.07.0045B Product Name : FXP.75 Atom 2.4GHz Series Ultra-Miniaturized 2dBi Bluetooth Antenna Features : Patent Pending Worldwide smallest cabled 2.4GHz antenna Ideal for Bluetooth earphones Flexible Ultra Low Profile 5.9*4.1*0.24mm Adheres directly to inside of product housing Form factor and cable routing convenient for integration IPEX MHF1 Connector (U.FL compatible) 45mm Ø 0.81mm mini-coaxial cable RoHS Compliant SPE-13-8-067/D/EZ Page 1 of 12 1. Introduction The FXP75 Atom is a super small monopole ultra-low profile antenna for 2.4GHz band that includes Bluetooth, Wi-Fi, ZigBee and ISM bands application. The FXP75 has a peak gain of 2.5dBi at 2.4GHz and efficiencies of 45%. This Taoglas patent pending antenna is unique in the market. Two years of constant research and development have created the world's smallest coax cabled true 2.4GHz antenna. Made from poly-flexible material, the antenna has a tiny form factor of 5.9*4.1*0.24mm and has double-sided 3M tape for easy “peel and stick” mounting. The cable routes conveniently directly out of the bottom of the antenna, reducing the volume the antenna takes up in the device to an absolute minimum compared to other designs. The FXP75 is the ideal all-round antenna solution for fitting into narrow spaces and still maintaining high performance, for example in a Bluetooth earphone where metal and electrical noise degrades onboard SMT antenna performance. The FXP75 is small enough to be routed away from metal and electrical noise to deliver much improved range and reliable sound quality in Bluetooth earphones. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. SPE-13-8-067/D/EZ Page 2 of 12 Due to the potential for detuning in a tiny device environment, Taoglas recommends that you contact us at our regional sales office for integration support and testing and optimization of the antenna in your device before going to production. SPE-13-8-067/D/EZ Page 3 of 12 2. Specification ELECTRICAL Antenna FXP75 Standard 2400-2500MHz Operation Frequency (MHz) 2400-2500 MHz Polarization Linear Impedance 50 Ohms Max VSWR 2:1 Max Return Loss (dB)
FXP75.07.0045B
物料型号:FXP75.07.0045B
器件简介: - 产品名称:FXP75 Atom 2.4GHz Series,超小型2dBi蓝牙天线。 - 特点:专利申请中,全球最小的带电缆2.4GHz天线,非常适合蓝牙耳机。
引脚分配:文档中没有明确提及引脚分配,但提到了IPEX MHF1连接器(兼容U.FL)和45mm直径0.81mm的微型同轴电缆。
参数特性: - 操作频率:2400-2500 MHz - 极化:线性 - 阻抗:50欧姆 - 最大VSWR:2:1 - 最大回波损耗:小于-10dB - 峰值增益:2.5dBi - 效率:45% - 平均增益:-3.4dB - 辐射特性:全向 - 最大输入功率:2W
功能详解: - FXP75天线采用聚柔材料制造,尺寸为5.94.10.24mm,具有双面3M胶带,便于“剥离和粘贴”安装。 - 天线底部直接引出电缆,减少设备内占用体积。
应用信息: - 适用于2.4GHz频段,包括蓝牙、Wi-Fi、ZigBee和ISM频段的应用。 - 特别适合用于狭窄空间,如蓝牙耳机。
封装信息: - 尺寸:5.94.10.24mm - 材料:聚合物 - 电缆:0.81mm同轴电缆 - 连接器:IPEX MHF1 - 环境操作温度:-40°C至85°C - 存储温度:-40°C至85°C - 相对湿度:40%至95% - 符合RoHS标准
FXP75.07.0045B 价格&库存
很抱歉,暂时无法提供与“FXP75.07.0045B”相匹配的价格&库存,您可以联系我们找货
FXP75.07.0045B
  • 20+25.33065
  • 90+24.81074
  • 100+23.42028
库存:792
FXP75.07.0045B
  • 12+62.77670
  • 60+56.48825
库存:492
