ANT-418-CW-QW
ANT-418-CW-QW
    LINXTECHNOLOGIES(灵思)
    ANT-418-CW-QW
ANT-418-CW-QW 数据手册
ANT-418-CW-QW Data Sheet by Product Description 7.8 mm (0.31") CW Series ¼-wave antennas deliver outstanding performance in a rugged and cosmetically attractive package. These antennas are available with standard SMA or FCC Part 15 compliant RP-SMA connectors. RP-SMA connectors allow for easy field replacement while complying with FCC requirements. A wide variety of matching connectors permit numerous mounting options. 13.0 mm (0.51") Features • • • • • • • • • • Low cost Excellent performance Omni-directional pattern Wide bandwidth Very low VSWR Fully weatherized Flexible main shaft Rugged & damage-resistant SMA or Part 15 compliant RP-SMA connector Use with plastic* or metal enclosures 178.0 mm (7.01") 6.0 mm (0.24") 14.5 mm (0.57") *Requires proximity ground plane 52.0 mm (2.05") Electrical Specifications Center Frequency: Recom. Freq. Range: Wavelength: Peak Gain: VSWR: Impedance: Connector: Oper. Temp. Range: 418MHz 380–450MHz ¼-wave 2.9dBi
ANT-418-CW-QW 价格&库存
很抱歉,暂时无法提供与“ANT-418-CW-QW”相匹配的价格&库存,您可以联系我们找货
ANT-418-CW-QW
    • 5+235.655185+30.59866
    • 10+169.6343810+22.02618
    • 25+157.8054325+20.49025
    • 50+153.0172650+19.86853
    库存:100
