SPECIFICATION
Part No.
: GW26.0151
Product Name
: 2.4GHz Miniature Screw mount Monopole
Antenna
: RP-SMA(M) Connector
IP65
Peak Gain Max 1.8dBi
Height 30.3mm Diameter 7.9mm
ROHS Compliant
Feature
SPE-11-8-003/I/SS Page 1 of 13
1 Introduction
The GW.26 2.4 GHz Monopole RP-SMA(M) mount antenna is ideal for 2.4 GHz wireless
applications such as Bluetooth and Wireless LAN.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least 1
or 2dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this
effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our antennas’
peak gain will be below the peak gain limits. Taoglas can then issue a specification
and/or report for the selected antenna in your device that will clearly show it
complying with the peak gain limits, so you can be assured you are meeting
regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than
2dBi peak gain, but you don’t need to select an embedded antenna that has a peak
gain of less than 2dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3dBi or more if available.
Once that antenna gets integrated into your device, performance will degrade below
this 2dBi peak gain due to the effects of GND plane, surrounding components, and
device housing. If you want to be absolutely sure, contact Taoglas and we will test.
Choosing a Taoglas antenna with a higher peak gain than what is specified by the
module manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
Connector mount is fully customizable.
SPE-11-8-003/I/SS Page 2 of 13
2 Specification
Frequency
Bandwidth
Peak Gain
Radiation Efficiency
Radiation
Polarization
Power Handling 1W
Max
Electrical Wave
Impedance
Operating
Temperature
Storage Temperature
Wi-Fi 2.4GHz
2400~2500MHz
100MHz
Max 1.8dBi
> 40%
Omni-directional
Vertical
Power Handling 1W Max
½ Monopole
50Ω
-40°C ~ +85°C
-40°C ~ +85°C
3 Mechanical Properties
Colour
IP rating
Connector
Black and Green
IP-65
RP-SMA(M)
SPE-11-8-003/I/SS Page 3 of 13
4 Antenna Characteristics
4.1 Antenna S11
SPE-11-8-003/I/SS Page 4 of 13
4.2 Antenna Peak Gain
3
Peak Gain (dBi)
2
Peak Gain(dBi)
1
-2
-3
-4
2350 2360 2370 2380 2390 2400 2410 2420 2430 2440 2450 2460 2470 2480 2490 2500 2510 2520 2530 2540 2550
Freq(MHz)
4.3 Antenna Efficiency
60
Efficiency (%)
50
Efficiency(%)
40
30
Freq(MHz)
SPE-11-8-003/I/SS Page 5 of 13
SPE-11-8-003/I/SS Page 6 of 13
4.4 Antenna pattern (XY plane)
Y
Z
X
SPE-11-8-003/I/SS Page 7 of 13
4.5 Antenna pattern (XY plane)
330
30
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-11-8-003/I/SS Page 8 of 13
4.6 Antenna pattern (XZ plane)
30
-5
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-11-8-003/I/SS Page 9 of 13
4.7 Antenna pattern (YZ plane)
30
-5
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-11-8-003/I/SS Page 10 of 13
5. Outline Drawings and Structure
SPE-11-8-003/I/SS Page 11 of 13
6. Packaging
SPE-11-8-003/I/SS Page 12 of 13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or disclosure
to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-003/I/SS Page 13 of 13
很抱歉,暂时无法提供与“GW.26.0151”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+33.99176100+4.39736
- 1000+32.978621000+4.26629
- 国内价格 香港价格
- 15+59.3652315+7.67980
- 25+56.7047425+7.33563
- 100+39.61527100+5.12484
- 国内价格 香港价格
- 100+34.58464100+4.47405
- 1000+33.553831000+4.34070
