Specification
Part No.
GW.11.A153
Product Name
2.4GHz 2.3dBi Terminal Mount Dipole
Antenna
Description
Connector Mount Terminal Antenna
90 Degree Hinged Connector
Black TPE Housing
Straight Length: 84mm
Connector : RP-SMA(M)
ROHS Compliant
SPE-11-8-128-G
Page 1 of 13
1. Introduction
The GW.11 2.4 GHz dipole RP-SMA terminal mount antenna is ideal for 2.4GHz wireless
applications such as Bluetooth and Wireless LAN. At only 84mm in length omnidirectional 2.3dBi gain across all bands ensures constant reception and transmission.
The antenna structure is designed for robust handling and the housing is made with
TPE giving superior environmental reliability and a quality finish. The antenna can be
rotated 90 degrees on the base hinge for ease of placement.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions.
In practice, the peak gain of an antenna tested in free-space can degrade by at least
1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak
gain antenna than mentioned on the module specification to compensate for this
effect, giving you better performance. Upon testing of any of our antennas with your
device and a selection of appropriate layout, integration technique, or cable, Taoglas
can make sure any of our antennas’ peak gain will be below the peak gain limits.
Taoglas can then issue a specification and/or report for the selected antenna in your
device that will clearly show it complying with the peak gain limits, so you can be
assured you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than
2dBi peak gain, but you don’t need to select an embedded antenna that has a peak
gain of less than 2dBi in free-space. This will give you a less optimized solution. It is
better to go for a slightly higher free-space peak gain of 3dBi or more if available.
Once that antenna gets integrated into your device, performance will degrade below
this 2dBi peak gain due to the effects of GND plane, surrounding components, and
device housing. If you want to be absolutely sure, contact Taoglas and we will test.
Choosing a Taoglas antenna with a higher peak gain than what is specified by the
module manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
It is better not to select an embedded antenna with very low free-space peak gain
很抱歉,暂时无法提供与“GW.11.A153”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+53.724291+6.98254
