GW.15.2113
GW.15.2113
    TAOGLASLIMITED
    GW.15.2113
GW.15.2113 数据手册
Specification Part No. : GW.15.2113 Product Name : 2.4GHz 3dBi Terminal Mount Dipole Antenna Description : SMA Male Straight Connector Peak Gain 3dBi High Efficiency up to 85% Works well with or without ground plane Hinged Design for Straight or 90° Degree Mounting Robust TPU Housing Dimensions: 108.5 x 10mm RoHS & REACH Compliant SPE-13-8-034/G/SS Page 1 of 48 1. Introduction The GW.15 2.4GHz dipole SMA terminal mount antenna is ideal for 2.4GHz wireless applications such as Bluetooth and Wireless LAN. At only 108mm in length, an omnidirectional 3dBi gain across all bands ensures constant reception and transmission. The antenna structure is designed for robust handling and the housing is made with TPU giving superior environmental reliability and a quality finish. The antenna can be rotated 90 degrees on the base hinge for ease of placement. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. It is better not to select an embedded antenna with very low free-space peak gain (
GW.15.2113 价格&库存
很抱歉,暂时无法提供与“GW.15.2113”相匹配的价格&库存,您可以联系我们找货
GW.15.2113
    • 100+26.42524100+3.38496
    • 300+24.97507300+3.19920
    • 500+24.30639500+3.11355
    • 1000+23.565191000+3.01860
    • 2500+22.807882500+2.92160
    库存:5000
    GW.15.2113
      • 1+38.709901+4.95858
      • 100+24.01720100+3.07650
      库存:223
      GW.15.2113
      • 20+26.29225
      • 100+21.62730
      库存:223
      GW.15.2113
        • 100+26.88614100+3.44400
        • 300+25.41069300+3.25500
        • 500+24.73034500+3.16785
        • 1000+23.976211000+3.07125
        • 2500+23.205692500+2.97255
        库存:5000
        GW.15.2113
          • 1+47.561731+6.09246
          GW.15.2113
