FXUB63.07.0150C
Patent Pending
Description:
LTE Wide Band Flex Antenna
698MHz -3000 MHz
Features:
Patent Pending
Ground Plane Independent
698-3000 MHz
>45% Efficiency on All covered bands
5dBi Peak Gain
I-PEX MHF® I (U.FL comp)
150mm Ø1.37 coaxial cable
96*21*0.2 mm size
RoHS & Reach Compliant
SPE-14-8-054-F
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
3D Radiation Patterns
9
5.
Mechanical Drawing
21
6.
Packaging
22
Changelog
23
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
© Taoglas
SPE-14-8-054-F
www.taoglas.com
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The patent pending FXUB63 flexible wideband antenna has been designed to cover all working frequencies
in the 698-3000MHz spectrum, covering all Cellular, 2.4GHz Wi-Fi, ISM and AGPS. The antenna is delivered
with a flexible body with excellent efficiencies on all bands, ground independent, with cable and connector
for easy installation.
Introduction
The FXUB63 flexible polymer antenna, at 96*21*0.2mm, is ultra thin and wideband with high efficiencies
across the bands. It is assembled by a simple “peel and stick” process, attaching securely to non-metal
surfaces via 3M adhesive. It enables designers to use only one antenna that covers all common LTE
frequencies.
Introduction
The FXUB63 antenna is a durable flexible polymer antenna that has a peak gain of 5dBi, an efficiency of more
than 45% across the bands and is designed to be mounted directly onto a plastic or glass cover. It is an ideal
choice for any device maker that needs to keep manufacturing costs down over the lifetime of a product. It
is ground plane independent and delivered with a cable and connector for easy connecting to the wireless
module or customer PCB.
Introduction
Cables and Connectors are customizable. Like all such antennas, care should be taken to mount the antenna
at least 10mm from metal components or surfaces, and ideally 20mm for best radiation efficiency.
SPE-14-8-054-F
www.taoglas.com
2.
Specifications
5G/4G Bands
3.
5GNR / FR1 / LTE / LTE-Advanced
/ WCDMA / HSPA / HSPA+ / TD-SCDMA
Antenna Characteristics2.
Specifications
Band Number
Uplink
Downlink
1
2
3.
3
Antenna
Characteristics
4
5
7
8
4.
9
Antenna
Radiation Patterns3.Antenna
11
12
Characteristics2.
13
Specifications
14
17
18
3.
19
Antenna
Characteristics2.
Specifications
21
22
23
3.
24
Antenna
Characteristics
25
26
27
4.
28
Antenna
29
30
31
Characteristics
32
35
38
4.
39
Antenna
Radiation Patterns
40
41
42
43
4.
48
Antenna
66
71
Characteristics
74/75/76
78
79
85
4.
Covered
Antenna Radiation Patterns3.Antenna
Characteristics2.
SPE-14-8-054-F
Specifications
www.taoglas.com
Electrical
Frequency (MHz)
698-960
1575.42
1710 -1990
1755-2170
2400 -2500
2500-2690
72
71
62
-1.4
-1.5
-2.1
4.7
4.4
4.0
2.0
1.8
1.8
-9.8
-10.7
-10.7
Efficiency (%)
With Ground Plane
(3mm ABS)
52
67
75
Average Gain (dB)
With Ground Plane
(3mm ABS)
-2.9
-1.7
-1.2
Peak Gain (dBi)
With Ground Plane
(3mm ABS)
4.5
2.33
4.6
Max VSWR
With Ground Plane
(3mm ABS)
5.2
2.0
1.9
Max Return Loss (dB)
With Ground Plane
(3mm ABS)
-3.4
-9.7
-10.5
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Input Power
5W Max
Mechanical
Dimensions (mm)
96*21*0.2 mm
Material
Flexible Polymer
Connector
I-PEX MHFI (U.FL Compatible)
Cable Length
150 mm
Cable
1.37 mm mini coax
Environmental
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Relative Humidity
40% to 95%
SPE-14-8-054-F
www.taoglas.com
3.
4.
3.1
Return Loss
Characteristics
Antenna
Radiation Patterns
-5
Return Loss [dB]
4.
4.
-10
-15
Characteristics
-20
4.
-25
600
800
Characteristics
3.2
4.
1000
1200
1400
1600
1800
2000
2200
2400
2200
2400
2600
2800
3000
Frequency [MHz]
VSWR
Antenna
Radiation Patterns
15.0
13.0
4.
Antenna
Radiation Patterns
11.0
VSWR
4.
9.0
Antenna
Radiation Patterns
7.0
5.0
4.
Antenna
3.0
Characteristics
1.0
600
800
1000
1200
1400
1600
1800
2000
2600
2800
3000
Frequency [MHz]
4.
SPE-14-8-054-F
www.taoglas.com
3.3
Peak Gain
5
3
1
Gain [dBi]
-1
-3
-5
-7
-9
-11
-13
-15
600
3.4
750
900
1050
1200
1350
1500
1650
1800
1950
2100
2250
2400
2550
2700
1950
2100
2250
2400
2550
2700
Frequency [MHz]
Average Gain
-1
-3
Aver Gain [dB]
-5
-7
-9
-11
-13
-15
600
750
900
1050
1200
1350
1500
1650
1800
Frequency [MHz]
SPE-14-8-054-F
www.taoglas.com
3.5
Efficiency
100
90
80
Efficiency [%]
70
60
50
40
30
750
900
1050
1200
1350
1500
1650
1800
1950
2100
2250
2400
2550
2700
Frequency [MHz]
SPE-14-8-054-F
www.taoglas.com
4.
Radiation Patterns
4.1
Test Setup
4.
4.
4.
Y
4.
4.
4.
VNA Set-Up
4.
Chamber Set-Up
SPE-14-8-054-F
www.taoglas.com
750MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
850MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
925MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
1400MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
1575MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
1750MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
1850MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
1950MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
2100MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
2450MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
2600MHz
XY Plane
SPE-14-8-054-F
XZ Plane
YZ Plane
www.taoglas.com
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
SPE-14-8-054-F
Packaging5.
Mechanical Drawing
www.taoglas.com
6.
6.
6.
7.
Packaging
100pcs FXUB63.07.0150C per PE Bag
Dimensions - 300*100
Weight - 150g
Packaging5.
Mechanical Drawing
Packaging
1000pcs FXUB63.07.0150C per Large PE Bag
Dimensions - 450*280mm
Weight - 1.5Kg
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
5000pcs FXUB63.07.0150C per carton
Dimensions - 320*250*230mm
Weight - 6Kg
6.
Packaging
7.
7. PalletApplication
Note
Dimensions:
1100*1100*1300mm
65 Cartons Per Pallet
13 Cartons Per Layer
5 Layers
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-054-F
Mechanical Drawing
www.taoglas.com
Changelog for the datasheet
SPE-14-8-054 – FXUB63.07.0150C
Revision: F (Current Version)
Date:
Notes:
Author:
2021-07-16
Updated Mechanical Drawing
Gary West
Previous Revisions
Revision: E
Date:
Notes:
Author:
2021-02-12
Updated RF Data and Datasheet Template.
Gary West
Revision: D
Date:
Notes:
Author:
2019-12-15
Updated Images Reference ECR-18-8-259
Russell Meyler
Revision: C
Date:
Notes:
Author:
2017-05-07
Updated as per PCN
Andy Mahoney
Revision: B
Date:
Notes:
Author:
2017-04-05
Updated as per PCN request
Andy Mahoney
Revision: A (Original First Release)
Date:
2014-05-28
Notes:
First Release
Author:
Jack Conroy
SPE-14-8-054-F
www.taoglas.com
SPE-14-8-054-F
© Taoglas
www.taoglas.com
很抱歉,暂时无法提供与“FXUB63.07.0150C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+56.364512+7.29161
- 10+46.2006010+5.97676
- 25+41.0109725+5.30540
- 100+28.69202100+3.71175
- 300+28.40794300+3.67500
- 500+28.31866500+3.66345
- 1000+27.920951000+3.61200
- 国内价格 香港价格
- 1+42.421431+5.48786
- 80+31.4922380+4.07400
- 100+29.62542100+3.83250
- 国内价格
- 8+95.11730
- 40+84.07358
- 80+82.52842
- 100+79.35425
- 国内价格
- 20+27.42240
- 80+26.98712
- 100+25.41529
- 国内价格 香港价格
