GW.05.0153
GW.05.0153
    TAOGLASLIMITED
    GW.05.0153
GW.05.0153 数据手册
Part No: GW.05.0153 Description: Dual-Band Wi-Fi 2.4~2.5GHz/5.15~5.85GHz Terminal Mount Monopole Antenna Also Covering Wi-Fi 6 Frequencies Features: High Efficiency – with and without ground plane Wi-Fi 2.4/5.8/7.1GHz Covers Wi-Fi 6 Frequencies: 5.9-7.1GHz Extremely Compact - 62.3mm ± 1.5mm Aesthetic look and feel Unique can rotate 360 degrees and articulate through 180 degrees Max Peak Gain compliant with most Wi-Fi modules Connector: RP-SMA(M) Dimensions: 62.3*Ø10mm CE Certified RoHS & Reach Compliant SPE-14-8-105-F 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 8 4. Radiation Patterns 12 5. Mechanical Drawing 22 6. Installation 23 7. Packaging 24 Changelog 25 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-105-F www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. Introduction The GW.05 dual band Wi-Fi Hinged Rotatable Antenna is a high efficiency monopole antenna with the capacity to cover Wi-Fi 6 frequencies up to 7.125GHz. Compared to other much larger antennas on the market, it has superior wide-band high efficiency characteristics. The bright green colour of the antenna adds a unique quality look and feel to any modern Wi-Fi application point, device or router. It also provides differentiation if using Taoglas other similar looking antennas (such as the black color Taoglas TG.09 cellular antenna) on same device. Introduction The GW.05, as all monopole antennas, works best connected directly to the ground-plane of the device main PCB or to the outside of a metal housing. However, it still has very good performance (>50%) even without connecting to a ground-plane, making it the best all round small Wi-Fi terminal antenna on the market. Introduction In the un-grounded installation condition, it also comes below the max peak gain requirements for most Wi-Fi modules which are usually 2dBi, so it can comply with FCC regulations. The GW.05 is for Wi-Fi, WLAN, Zigbee, Bluetooth, and 802.11a/b/g/n/ac applications. 1. Introduction Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. SPE-14-8-105-F www.taoglas.com 3 For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. It is better not to select an embedded antenna with very low free-space peak gain (
GW.05.0153 价格&库存
很抱歉,暂时无法提供与“GW.05.0153”相匹配的价格&库存,您可以联系我们找货
GW.05.0153
    GW.05.0153
    • 100+51.01194
    库存:43
    GW.05.0153
      GW.05.0153
