ANT-868-CW-HWR-ccc
Data Sheet
by
Product Description
8.2 mm
(0.32")
HWR Series ½-wave center-fed dipole antennas
deliver outstanding performance in a rugged and
cosmetically attractive package. The articulating
base allows the antenna to tilt 90 degrees and
rotate 360 degrees. The antenna’s internal
counterpoise eliminates external ground plane
dependence and maximizes performance. HWR
Series antennas attach via a standard SMA or Part
15 compliant RP-SMA connector. Custom colors
and connectors are available for volume OEM
customers.
Features
142 mm
(5.59")
Internal counterpoise
Low cost
Tilts and rotates
Omni-directional pattern
Outstanding VSWR
Rugged & damage-resistant
Standard SMA or Part 15 compliant RP-SMA
connector
• Custom colors and terminations for volume
OEMs
• Internal O-ring seal on connector
26 mm
(1.02")
Electrical Specifications
Center Frequency:
Recom. Freq. Range:
Bandwidth:
Wavelength:
VSWR:
Peak Gain:
Impedance:
Connection:
Oper. Temp. Range:
116 mm
(4.57")
10 mm
(0.39")
868MHz
853–883MHz
30MHz
½-wave
≤ 2.0 typical
–2.3dBi
50-ohms
RP-SMA or SMA
–30°C to +80°C
30 mm
(1.18")
Ordering Information
ANT-868-CW-HWR-RPS (with RP-SMA connector)
ANT-868-CW-HWR-SMA (with SMA connector)
Electrical specifications and plots measured with a 10.16 cm x
10.16 cm (4.00” x 4.00”) reference ground plane
–1–
Revised 8/1/2017
VSWR Graph
VSWR
1.125
3:1
Reflected Power
25%
11%
2:1
1:1
768MHz
868MHz
0%
968MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source
impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher
the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this
is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free
space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In
the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side
note, since the “:1” is always implied, many data sheets will remove it and just display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s
operational center frequency. In most cases, this is different than the designed center frequency due to
fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx
specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1.
Copyright © 2017 Linx Technologies
159 Ort Lane, Merlin, OR 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
– 2 – ANT-868-CW-HWR-ccc Data Sheet
by
很抱歉,暂时无法提供与“ANT-868-CW-HWR-SMA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+233.37720
- 200+93.12840
- 500+90.00720
- 1000+88.47360
