ANT-868-CW-HWR-RPS
ANT-868-CW-HWR-RPS
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    HWR系列V2波中心馈电偶极子天线,具有出色的性能,坚固耐用且外观美观。可倾斜90度并旋转360度。内部对地平衡消除了对外部地面平面的依赖,最大化性能。HWR系列天线通过标准SMA或Part 15合规...
ANT-868-CW-HWR-RPS 数据手册
ANT-868-CW-HWR-ccc Data Sheet by Product Description 8.2 mm (0.32") HWR Series ½-wave center-fed dipole antennas deliver outstanding performance in a rugged and cosmetically attractive package. The articulating base allows the antenna to tilt 90 degrees and rotate 360 degrees. The antenna’s internal counterpoise eliminates external ground plane dependence and maximizes performance. HWR Series antennas attach via a standard SMA or Part 15 compliant RP-SMA connector. Custom colors and connectors are available for volume OEM customers. Features 142 mm (5.59") • • • • • • • Internal counterpoise Low cost Tilts and rotates Omni-directional pattern Outstanding VSWR Rugged & damage-resistant Standard SMA or Part 15 compliant RP-SMA connector • Custom colors and terminations for volume OEMs • Internal O-ring seal on connector 26 mm (1.02") Electrical Specifications Center Frequency: Recom. Freq. Range: Bandwidth: Wavelength: VSWR: Peak Gain: Impedance: Connection: Oper. Temp. Range: 116 mm (4.57") 10 mm (0.39") 868MHz 853–883MHz 30MHz ½-wave ≤ 2.0 typical –2.3dBi 50-ohms RP-SMA or SMA –30°C to +80°C 30 mm (1.18") Ordering Information ANT-868-CW-HWR-RPS (with RP-SMA connector) ANT-868-CW-HWR-SMA (with SMA connector) Electrical specifications and plots measured with a 10.16 cm x 10.16 cm (4.00” x 4.00”) reference ground plane –1– Revised 8/1/2017 VSWR Graph VSWR 1.125 3:1 Reflected Power 25% 11% 2:1 1:1 768MHz 868MHz 0% 968MHz What is VSWR? The Voltage Standing Wave Ratio (VSWR) is a measurement of how well an antenna is matched to a source impedance, typically 50-ohms. It is calculated by measuring the voltage wave that is headed toward the load versus the voltage wave that is reflected back from the load. A perfect match has a VSWR of 1:1. The higher the first number, the worse the match, and the more inefficient the system. Since a perfect match cannot ever be obtained, some benchmark for performance needs to be set. In the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the energy sent to the antenna by the transmitter is radiated into free space and 11.1% is either reflected back into the source or lost as heat on the structure of the antenna. In the other direction, 88.9% of the energy recovered by the antenna is transferred into the receiver. As a side note, since the “:1” is always implied, many data sheets will remove it and just display the first number. How to Read a VSWR Graph VSWR is usually displayed graphically versus frequency. The lowest point on the graph is the antenna’s operational center frequency. In most cases, this is different than the designed center frequency due to fabrication tolerances. The VSWR at that point denotes how close to 50-ohms the antenna gets. Linx specifies the recommended bandwidth as the range where the typical antenna VSWR is less than 2:1. Copyright © 2017 Linx Technologies 159 Ort Lane, Merlin, OR 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com – 2 – ANT-868-CW-HWR-ccc Data Sheet by
ANT-868-CW-HWR-RPS 价格&库存
很抱歉,暂时无法提供与“ANT-868-CW-HWR-RPS”相匹配的价格&库存,您可以联系我们找货
