FXP14 Flexible PCB Cellular Antenna
Part No:
FXP14.07.0100A
Description:
5G/4G Cellular Flexible PCB with 100mm 1.13 & IPEX MHFI Connector
Features:
Flexible PCB Antenna
Dimensions: 70x20x0.2mm
Connector: I-PEX MHF® I (U.FL Compatible)
Cable: 100mm of Ø1.13
Peel and Stick Mounting
3M 467 Adhesive
CE Certified
RoHS & REACH Compliant
SPE-12-8-050-F
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
8
5.
Mechanical Drawing
23
6.
Packaging
24
Changelog
25
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-12-8-050-F
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The Taoglas FXP14 Flexible Wideband Cellular Antenna covers all world-wide 5G/4G bands. The antenna
has been designed in a flexible material with a rectangular form-factor and cable connection for an easy
installation. The antenna works on different plastic materials and thickness. We have selected a piece of
ABS with 2 mm of thickness as a baseline for testing.
Introduction
Typical Applications Include:
• Security
• Remote Monitoring
• Connected Health
Introduction
The antenna has been designed using a super thin flexible polymer substrate with a rectangular form-factor
and cable connection for ease of installation. The antenna radiates well on different plastic materials and
thickness. We have selected ABS plastic mounting with 2 mm of thickness as a baseline for testing. Best in
class efficiency on lower and upper bands (above 40%) make it an ideal antenna for devices where space
for onboard SMD cellular antennas is not available.
Introduction
The antenna is mounted via automotive quality 3M 467 adhesive and has excellent reliability. The FXP14
has its own ground-plane, therefore it does not need to connect to the ground-plane of the main-board of
the device for improved radiation efficiency.
For more information or installation instructions, please contact your regional Taoglas customer support
team.
SPE-12-8-050-F
www.taoglas.com
3
2.
Specifications
3.
MIMO
Antenna Characteristics2.5G/4GSpecifications
Efficiency
Average Gain
Peak Gain
(dB)
(dBi)
617~960
43
-3.9
3.8
1427~1518
55
-2.7
2.8
Band
Frequency (MHz)
5GNR/4G
Band
5,8,12,13,14,17,18,20,
26,27,28, 29,71
5GNR/4G
Band 21,32,74,75,76
3.
4.
1710~2200
Characteristics2.
4G/3G
Band 7,38,41
3.
Impedance
Polarization
Radiation
Pattern
Input Power
50Ω
Linear
Omni Directional
5W
Antenna
Radiation Patterns3.Antenna
4G/3G
Band
1,2,3,4,9,23,25,35,39,66
3.
VSWR
2490~2690
67
-1.8
5.5
Specifications
53
-2.8
5GNR/4G
Band
22,42,43,48,77,78,79
3300~5000
55
-2.8
LTE5200/
Wi-Fi 5800
5150~5925
46
-3.4
很抱歉,暂时无法提供与“FXP14.07.0100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+45.647451+5.90572
- 85+30.3532385+3.92700
- 100+28.32427100+3.66450
- 国内价格 香港价格
- 1+50.906881+6.58617
- 10+41.8280810+5.41158
- 25+41.4154125+5.35819
- 100+27.48774100+3.55628
- 300+27.20855300+3.52016
- 500+25.64512500+3.31788
- 1000+25.389861000+3.28486
- 2500+25.134612500+3.25184
- 国内价格 香港价格
- 20+46.0597920+5.95907
- 50+42.4865850+5.49678
- 100+30.75253100+3.97866
- 国内价格 香港价格
- 2+43.698822+5.65361
- 10+38.4988910+4.98086
- 25+38.1220825+4.93211
- 100+26.42517100+3.41880
- 300+26.16546300+3.38520
- 500+25.17533500+3.25710
- 1000+24.923741000+3.22455
- 2500+24.842582500+3.21405
- 国内价格 香港价格
- 3+51.794793+6.70104
- 10+42.5576410+5.50597
- 25+42.1377725+5.45165
- 100+27.96717100+3.61830
- 300+27.68312300+3.58155
- 500+26.09242500+3.37575
- 1000+25.832711000+3.34215
- 2500+25.573002500+3.30855
