SPECIFICATION
Part No.
TG.08.0113
Description
Monopole Passive Antenna
Broadband frequency range for cellular and GNSS
Features
High efficiency at 698 to 960MHz, 1561MHz,
1575.42MHz, 1602MHz, 1710 to 2700MHz.
360∘rotatable with durable brass hinge.
Compatible with :
- 2G ( GSM / DCS / PCS )
- 3G ( CDMA / WCDMA / UMTS / HSPA )
- 4G (700LTE / 2700LTE )
- GNSS ( GPS / GLONASS / BEIDOU )
Standard with SMA(M) connector
Low profile with 72 ± 1.5mm Length
ROHS Compliant
Photo:
SPE-14-8-116/C/EW
Page 1 of 62
1. Introduction
The compact TG.08 with hinged rotatable SMA connector, is an impressively
high efficiency monopole antenna, which provides wide coverage among
cellular and GNSS frequencies.
With its cellular and GNSS function, plus compact design, TG.08 can fit and
function perfectly with routers, vehicle tracking devices, telematics devices,
and remote monitoring systems. It is also ideal for use with cellular modules
with Assisted GPS functionality that can be implemented in various devices.
This 72mm long monopole antenna works efficiently from 700MHz to 2700MHz,
widely covering 2G/3G/4G bands, as well as GPS/GLONASS/BEIDOU. At its
maximum efficiency when connected to ground plane, it can achieve 73% and
67% at GPS and LTE bands, respectively.
As all monopole antennas, TG.08 works best while connecting directly to the
ground-plane of the device main-board, or with the device's metal enclosure.
The robust brass hinge enables TG.08 to be oriented in all directions, providing
users to maximize performance with minimum effort.
TG.08, the small antenna with surprisingly large efficiency, is surely the best
candidate in the market for Cellular/GNSS combination terminal antennas.
SPE-14-8-116/C/EW
Page 2 of 62
2. Specification
Parameter
Straight Position
Band
700LTE
GSM
Frequency (MHz)
703~
824~
803
960
-9.69
Average Gain
(dBi)
Efficiency (%)
Peak Gain (dBi)
Return Loss (dB)
Average Gain
(dBi)
Efficiency (%)
Peak Gain (dBi)
Return Loss (dB)
Average Gain
(dBi)
Efficiency (%)
Peak Gain (dBi)
Return Loss (dB)
Average Gain
(dBi)
Efficiency (%)
Peak Gain (dBi)
Return Loss (dB)
In Free
Space
With
15x9cm
Ground
BEIDOU
GPS
GLONASS
1561
1575.42
1602
-8.70
-5.77
-5.44
10.75
13.50
26.48
-6.46
-4.93
< -2
PCS
1710~
1850~
1920~
2490~
1880
1990
2170
2690
-4.92
-3.84
-3.45
-3.62
-4.39
28.56
32.24
41.40
45.18
43.46
36.73
-1.42
-1.07
-0.61
-0.02
0.66
0.33
0.36
< -3
< -6
< -6
< -10
< -10
< -10
< -8
很抱歉,暂时无法提供与“TG.08.0113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 6+135.01602
- 24+121.49285
