Warrior
Part No:
PA.710.A
Description:
Warrior LTE/Cellular SMD Antenna
For 4G/3G/2G Applications
Features:
698MHz to 960MHz, 1710MHz to 2690MHz
High Efficiency Wideband Antenna
Manufactured in an IATF16949 Certified Facility
Surface Mount Distribution
Dimensions: 40 x 5 x 6 mm
RoHS & REACH Compliant
SPE-12-8-126-L
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
9
5.
Mechanical Drawing
26
6.
Antenna Integration Guide
27
7.
Packaging
35
Changelog
36
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-12-8-126-L
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
Introduction
The Warrior, the revolutionary patent pending PA.710A is a 4G/3G/2G, High Efficiency SMD Ceramic antenna,
operating at 698MHz to 960MHz and 1710MHz to 2690MHz. It uses high grade custom ceramic material and
new design techniques to deliver the highest efficiencies on all bands when mounted on the device’s main
PCB. The exceptional wide-band response means it is the ideal antenna for all LTE applications that also need
high efficiency and backward compatibility for 3G and 2G globally on all lower and upper bands. The PA.710
is delivered on tape and reel and mounted securely during the device PCB reflow process. The PA.710 also
operates with great efficiency on worldwide NB-IoT and CAT-M frequency bands. For further information
please contact your regional Taoglas customer support team.
Introduction
1.
Introduction
1.
Introduction
SPE-12-8-126-L
www.taoglas.com
3
1.1
Key Advantages
1. Highest efficiency in a small size, i.e. 40mm*5mm*6mm. A comparative antenna, for example
metal/FR4/FPC/whip/rod/helix, would have much reduced efficiency in this configuration due to their
different dielectric constants. Very high efficiency antennas are critical to 3G and 4G devices ability to
deliver the stated data-speed rates of systems such as HSPA and LTE.
2. More resistant to detuning compared to other antenna integrations. If tuning is required it can be
tuned for the device environment using a matching circuit, or other techniques on the main PCB itself.
There is no need for new tooling, thereby saving money if customization is required.
3. Highly reliable and robust– its predecessors the PA.25A and PA700A antennas are used by the world’s
leading automotive makers in extremely challenging environments. The antenna meets all
temperature and mechanical specs required (vibration, drop tests, etc)
4. Easy to integrate. Other antenna designs come in irregular shapes and sizes making them more
difficult to integrate.
5. Surface Mount Distribution (Directly On-Board) antenna saves on labor, cable and connector costs,
leads to higher integration yield rates, and reduces losses in transmission.
6. Minimum Transmission and Reception Losses - these are kept to absolute minimum resulting in much
improved OTA (over the air), i.e. TRP (Total Radiated Power)/TIS (Total Isotropic Radiation), device
performance compared to similar efficiency cable and connector antenna solutions. This means it is an
ideal antenna to be used for devices that need to pass for example USA carrier network approvals
7. RSE Reductions – will help to eliminate radiated spurious emission failures compared to other antenna
technologies as the required layout for the antenna can deliver natural isolation between the onboard
noise and the antenna itself. Also the antenna can be matched better to the system with the matching
circuit function.
8. High Gain in Both Polarization Planes - Achieves moderate to high gain in both vertical and horizontal
polarization planes. This feature is very useful in certain wireless communications where the antenna
orientation is not fixed and the reflections or multipath signals may be present from any plane. In
those cases, the important parameter to be considered is the total field strength, which is the vector
sum of the signal from the horizontal and vertical polarization planes at any instant in time.
SPE-12-8-126-L
www.taoglas.com
4
2.
Specifications
3. Operation
Antenna
Characteristics2.
Frequency
4.
Specifications
698~960
1710 ~2170
2300 ~2400MHz
2490 ~2690MHz
Peak Gain
1.0dBi
3.2dBi
3.5dBi
3.5dBi
Average Gain
-2.3dB
-1.5dB
-1.8dB
-1.5dB
70%
65%
70%
(MHz)
3.
Electrical
Antenna
Characteristics
Efficiency
60%
VSWR
很抱歉,暂时无法提供与“PA.710.A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 450+53.42952450+6.94454
- 900+51.47551900+6.69056
- 1350+50.385831350+6.54893
