SPECIFICATION
Part No.
TS.07.0113
Product Name
Orange Straight TS.07
GPS/GLONASS/GALILEO/BeiDou Monopole
Passive Antenna
Features
1561-1610 MHz
72 ± 1.5mm Length
Standard with SMA(M) connector
Low profile
Extended operation temperature range (-40 to
+85C)
Top quality housing with brass hinge and
connector
Antenna must have a view of the Sky
ROHS Compliant
SPE-14-8-115/A/EW
Page 1 of 30
1. Introduction
The compact TS.07, with hinged rotatable SMA connector, is an impressively
high efficiency monopole antenna, providing coverage among GPS, GLONASS,
GAILEO, and BeiDou frequencies.
With its navigation system frequency range, plus compact design, TS.07 can fit
and function perfectly with vehicle tracking devices, telematics devices, and
other remote monitoring systems.
This 72mm long monopole antenna performs efficiently from 1561 MHz to 1610
MHz, covering GPS, GLONASS, GAILEO, and BeiDou frequencies. When
connected to the device ground-plane, the TS.07 is capable of achieving more
than 70% efficiency.
The TS.07, as all monopole antennas, works best when connected directly to
the ground-plane of the device main-board or the device's metal enclosure. As
with all passive antennas, using a coax with more than ~1.5 dB of loss will
result in reduced receiver sensitivity. Taoglas recommends connecting the
TS.07 directly to the device ground-plane for best performance.
The robust brass hinge enables the TS.07 to be oriented in all directions,
providing user to maximize performance with minimum effort.
SPE-14-8-115/A/EW
Page 2 of 30
2. Specification
ELECTRICAL
Straight Position
Band
BEIDOU
GPS/GAILEO
GLONASS
Frequency (MHz)
1561
1575.42
1602
-4.70
-4.48
-4.13
33.89
35.65
38.66
-0.79
-0.55
-0.23
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
In Free Space
Return Loss (dB)
< -7
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
With 15x9cm
Ground Plane
-1.53
-1.50
-1.41
70.29
70.78
72.23
1.99
1.94
1.96
-1.35
-1.41
-1.50
73.20
72.35
70.81
4.05
4.04
3.98
Return Loss (dB)
< -10
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
On 30x30cm
Metal Plane
Edge
Return Loss (dB)
< -10
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
Return Loss (dB)
On 30x30cm
Metal Plane
Center
-2.10
-2.22
-2.36
61.66
60.02
58.05
2.26
2.15
2.21
< -4
SPE-14-8-115/A/EW
Page 3 of 30
Bent Position
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
In Free Space
-5.31
-5.06
-4.68
29.48
31.17
34.02
-0.82
-0.59
-0.16
Return Loss (dB)
< -7
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
With 15x9cm
Ground Plane
-1.53
-1.50
-1.41
70.29
70.78
72.23
1.99
1.94
1.96
Return Loss (dB)
< -10
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
On 30x30cm
Metal Plane
Edge
-1.12
-1.14
-1.17
77.26
76.86
76.32
4.39
4.37
4.31
Return Loss (dB)
< -10
Average Gain (dBi)
Efficiency (%)
Peak Gain (dBi)
On 30x30cm
Metal Plane
Center
-2.50
-2.60
-2.73
56.19
54.96
53.33
2.04
1.91
1.79
Return Loss (dB)
< -4
Radiation
Omni-directional
Polarization
Linear
Impedance
50 Ω
Input Power
10W
MECHANICAL
Antenna Length
72mm
Antenna Diameter
10mm
Casing
POM
Connector
SMA(M)
Weight
6g
Recommended Torque for Mounting
0.9N·m
Max. Torque for Mounting
1.176N·m
ENVIRONMENTAL
Operation Temperature
-40°C ~ + 85°C
Storage Temperature
-40°C ~ + 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-14-8-115/A/EW
Page 4 of 30
3. Antenna Characteristics
3.1 Testing setup
Antenna Straight Position
a)In free space
b)with 15*9cm
c)with 30*30cm
d)with 30*30cm
Ground
Ground Metal Edge
Ground Metal Center
Antenna bent Position
a)In free space
b)with 15*9cm
c)with 30*30cm
d)with 30*30cm
Ground
Ground Metal Edge
Ground Metal Center
Figure.1 Measurement environments
SPE-14-8-115/A/EW
Page 5 of 30
3.2 Return loss
Figure2. Return loss of TS.07 antenna with straight Position
Figure3. Return loss of TS.07 antenna with bent Position
SPE-14-8-115/A/EW
Page 6 of 30
3.3 Efficiency
Figure4. Efficiency of TS.07 antenna with straight Position
Figure5. Efficiency of TS.07 antenna with bent Position
SPE-14-8-115/A/EW
Page 7 of 30
3.4 Peak gain
Figure6. Peak gain of TS.07 antenna with straight Position
Figure7. Peak gain of TS.07 antenna with bent Position
SPE-14-8-115/A/EW
Page 8 of 30
3.5 Average gain
Figure8. Average gain of TS.07 with antenna straight Position
Figure9. Average gain of TS.07 antenna with bent Position
SPE-14-8-115/A/EW
Page 9 of 30
4. Antenna Radiation Patterns
The antenna radiation patterns were measured in a CTIA certified ETS Anechoic
Chamber. The measurement setups are shown below.
Antenna with Straight Position
Y
Y
X
X
Z
Z
In free space
On 15x9cm ground plane
Y
Y
X
X
Z
Z
On 30x30cm metal ground center
On 30x30cm metal ground edge
SPE-14-8-115/A/EW
Page 10 of 30
Antenna Bent Position
Y
Y
X
Z
In free space
Y
X
Z
Y
X
X
Z
Z
Figure.10. Testing Setup in ETS Anechoic Chamber
SPE-14-8-115/A/EW
Page 11 of 30
4.1 2D Radiation pattern (Straight Position in free space)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 12 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 13 of 30
4.2 2D Radiation pattern (Straight Position with 15x9cm ground plane)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 14 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 15 of 30
4.3 2D Radiation pattern (Straight Position with 30x30cm ground
plane edge)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 16 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 17 of 30
4.4 2D Radiation pattern (Straight Position with 30x30cm ground
plane center)
X
XY Plane
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 18 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 19 of 30
4.5 2D Radiation pattern (Bent Position in free space)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 20 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 21 of 30
4.6 2D Radiation pattern (Bent Position with 15x9cm ground plane)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 22 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 23 of 30
4.7 2D Radiation pattern (Bent Position with 30x30cm ground plane
edge)
XY Plane
X
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 24 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 25 of 30
4.8 2D Radiation pattern (Bent Position with 30*30cm ground plane_
center)
X
XY Plane
Y
XZ Plane
Z
X
SPE-14-8-115/A/EW
Page 26 of 30
YZ Plane
Z
Y
SPE-14-8-115/A/EW
Page 27 of 30
5. Installation
SPE-14-8-115/A/EW
Page 28 of 30
6. Drawing
Pin
SPE-14-8-115/A/EW
Page 29 of 30
7. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-115/A/EW
Page 30 of 30
很抱歉,暂时无法提供与“TS.07.0113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+83.79815
- 35+71.57402
- 65+69.63233
- 100+58.11649
