AP.25E.07.0054A
AP.25E.07.0054A
    TAOGLASLIMITED
    AP.25E.07.0054A
AP.25E.07.0054A 数据手册
SPECIFICATION Part No. : Product Name : AP.25E.07.0054A 25mm One Stage GPS/GALILEO Active Patch Antenna Module with front-end Saw Filter Features : Industry leading GPS/GALILEO antenna performance 35mm*35mm*4.50mm (Ground Plane) 54mm Ø1.13 I-PEX MHFI (U.FL) 15dB LNA Wide Input Voltage 1.8V to 5.5V Low Power Consumption ROHS Compliant SPE-11-8-038/D/SS Page 1 of 10 1. Introduction The AP.25E has been designed specifically for embedded (inside device) integration with GPS/GALILEO receiver modules where there is a GSM transmitter nearby and risk of interference and saturation. The AP.25E combines a 25*25*2mm advanced low profile ceramic patch antenna with a one stage LNA and a front-end SAW filter with ultra thin coaxial cable. The Ground Plane size of 35*35mm combined with the larger size GPS/GALILEO Patch, gives this solution a performance increase in gain of 12dB. It also helps shields the patch antenna from noise and increases performance at low elevations. Taoglas active antenna modules utilise XtremeGain™ technology for the highest sensitivity in the industry. The AP.25E consists of 2 functional blocks – the LNA and also the patch antenna. The AP.25E has a SAW filter on the front of it. The main use of the AP.25E would be for small devices where the GSM transmitter is close to the GPS/GALILEO antenna, it helps avoid burn-out of the LNA or the module due to interference from the GSM transmitter at out band frequencies. SPE-11-8-038/D/SS Page 2 of 10 2. Specification 2.1. Patch Antenna Parameter Specification Frequency 1575.42 ± 1.023MHz Gain @ Zenith +1.5 dBic Typ. @ Zenith Polarization RHCP Axial Ratio 3.0dB max. @Zenith Patch Dimension 25*25*2mm 2.2. LNA Parameter Specification Frequency 1575.42 ± 1.023MHz F0=1575.42MHz F0 30MHz 9dB min. Outer Band F0 50MHz 20dB min. Attenuation F0 100MHz 25dB min. Output Impedance 50Ω Output VSWR 2.0 Max Pout at 1dB Gain Typ. -2dBm Compression point Min. -6dBm LNA Gain, Power Consumption and Noise Figure LNA Gain Power Consumptio (mA) Noise Figure Voltage (Typ) Typ Typ Min. 1.8V 14dB 3mA 2.5dB Typ. 3.0V 15dB 3mA 2.5dB Max. 5.5V 15dB 3mA 2.5dB 2.3. Cable* & Connector Parameter Specification RF Cable Coaxial Cable Ø1.13 ± 0.1mm, length 54 ± 4.5mm Connector IPEX MHFI (U.FL) SPE-11-8-038/D/SS Page 3 of 10 2.4. Total Specification (through Antenna, LNA, Cable and Connector) Parameter Specification Frequency 1575.42 ± 1.023MHz At 5V:16.5± 3dBic At 3V: 16.5  3dBic Gain At 1.8V: 15.5  3dBic Output Impedance 50Ω Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Min:1.8V Typ. 3.0V Max:5V Antenna 35*35*4.5mm SPE-11-8-038/D/SS Page 4 of 10 3. LNA Gain and Out Band Rejection @3.0V SPE-11-8-038/D/SS Page 5 of 10 4. LNA Noise Figure @3.0V SPE-11-8-038/D/SS Page 6 of 10 5. Technical Drawing SPE-11-8-038/D/SS Page 7 of 10 SPE-11-8-038/D/SS Page 8 of 10 6. Radiation Patterns SPE-11-8-038/D/SS Page 9 of 10 7. Plugs Usage Precautions Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-038/D/SS Page 10 of 10
AP.25E.07.0054A 价格&库存
很抱歉,暂时无法提供与“AP.25E.07.0054A”相匹配的价格&库存,您可以联系我们找货
AP.25E.07.0054A
  • 10+49.18620
  • 45+48.23101
  • 90+47.36046
  • 120+45.53472
库存:121
