AA.105.301111
AA.105.301111
    TAOGLASLIMITED
    AA.105.301111
AA.105.301111 数据手册
Titan GPS/Galileo Active Antenna Part No: AA.105.301111 Features: Magnetic Mount Covert stylish design Wide band input voltage Gain can be adjusted for your application (10dB~31dB) IP-67 Waterproof Dimensions: 43.3 x 32.7 x 14mm Cable: 3m RG174 Connector: SMA (M) Straight Cable and connector customizable RoHS and REACH Compliant SPE-12-8-024-H 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Antenna Field Test Results 9 6. Mechanical Drawing 10 7. Packaging 11 Changelog 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-024-H www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Titan AA.105 is a small magnetic mount external active GPS/Galileo antenna. The Titan AA.105 is ideal for robust, covert installations where durability and small size is paramount. It is fully IP67 waterproof rated for installations where water ingress may be an issue. With a small footprint of just 43.3 x 32.7 mm, the Titan AA.105 can be used in applications where space may be a constraint, and with its magnetic mounting style it is perfect for use in transportation applications. Introduction Typical Applications Include: - Commercial Transportation - E-Scooters/Electric Vehicles - Robotics and Automonous Vehicles - Asset Tracking Introduction The Titan is also available in an adhesive mount version – AA.108. For further information, please contact your regional Taoglas customer support team. Introduction SPE-12-8-024-H www.taoglas.com 3 2. Specifications GNSS Frequency Bands Covered L1 L2 L5 L6 3.GPS/QZSS Antenna Characteristics2. Specifications 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz GLONASS 3. □ □ □ L5R 1176.45MHz L3PT 1201.5MHz L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ ■ □ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ □ ■ Antenna Characteristics Galileo 4. ■ □ Radiation □ Patterns3. □ □ Antenna Antenna BeiDou B1 1561MHz B2 1207.14MHz B3 1268.52MHz □ □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz Characteristics2. Compass 3. SBAS 3. Specifications □ Characteristics2. □ Antenna Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ ■ Specifications Antenna Characteristics Electrical Centre Frequency 4. 1575.42±3MHz Antenna Radiation Patterns3.Antenna Bandwidth 10MHz Characteristics 4. VSWR 1.92 Max Axial ratio 3dB Typ. Gain @ Zenith 2dBi Typ. Antenna Radiation Patterns Impedance Polarization 4. 50Ω RHCP Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-024-H Specifications www.taoglas.com 4 LNA and Filter Electrical Properties Frequency 1575.42MHz Impedance 50Ω VSWR 1.92 Max. Gain 30dB Typ. Gain at Connector* 28.4dB DC Power Input 2.7~5V Noise Figure 1.5dB Typ. Power Consumption 4.7mA @2.7V 6mA @3.3V 10.3mA @5V Pout 1dB Gain Compression Point -35.7dBm Mechanical Dimensions 43.3 x 32.7 x 14 mm Weight 64g Cable 3m RG-174 Connector SMA Male Straight Environmental Operating temp -40°C ~ +85°C Storage Temp -40°C ~ +90°C *Formula = Patch Antenna Average Gain + LNA typical gain – RG-174 cable loss @1.2dB per meter = Gain at connectorGain at the Connector - Patch Gain 2dB + LNA Gain 30dB – Cable loss of 1.2dB per metre (@3m = 3.6dB) = 28.4dB approx. RG-174 cable attenuation(dB/100m) Frequency(GHz) 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 Cable Loss(dB) 67 110 127 153 168 183 207 229 252 272 291 311 SPE-12-8-024-H www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 LNA Gain 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4.SPE-12-8-024-H Antenna Radiation Patterns3.Antenna www.taoglas.com 6 3.3 LNA S22 3.4 P1dB Point 50 45 40 35 30 25 db:Trc1_S21 20 15 10 5 0 -5 -10 -15 -20 -25 -50 -45 -40 -35 -30 -25 -20 -15 -10 -5 power[dBm] SPE-12-8-024-H www.taoglas.com 7 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns 4.2 3D and 2D Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-12-8-024-H www.taoglas.com 8 5. 6. Antenna Field Test Results Antenna was connected to a U-blox EVK-6H evaluation kit under open sky conditions. Packaging5. ⚫ Mechanical Drawing 1.8 V Cold Start needs typically 40 seconds. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging ⚫ Mechanical Drawing 3.3V Cold Start needs typically 40 seconds. 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6.SPE-12-8-024-H Packaging5. Mechanical Drawing www.taoglas.com 9 6. Mechanical Drawing 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4.SPE-12-8-024-H Antenna Radiation Patterns3.Antenna www.taoglas.com 10 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6.SPE-12-8-024-H Packaging5. Mechanical Drawing www.taoglas.com 11 Changelog for the datasheet SPE-12-8-024 – AA.105.301111 Revision: H (Current Version) Date: Changes: Changes Made by: 2021-11-17 Full datasheet template update & added P1dB Point. Gary West Previous Revisions Revision: G Revision: B Date: Changes: 2019-10-22 Date: Changes: Changes Made by: Jack Conroy Changes Made by: Revision: F 2012-03-21 Revision: A (Original First Release) Date: Changes: Changes Made by: 2017-07-10 Updated as per PCN -17-8-083 Andy Mahoney Date: 2012-03-08 Notes: Author: Revision: E Date: Changes: 2013-07-18 Changes Made by: Revision: D Date: Changes: 2012-08-01 Changes Made by: Revision: C Date: 2012-06-11 Changes: Changes Made by: SPE-12-8-024-H www.taoglas.com 12 www.taoglas.com SPE-12-8-024-H © Taoglas www.taoglas.com 13
AA.105.301111 价格&库存
很抱歉,暂时无法提供与“AA.105.301111”相匹配的价格&库存,您可以联系我们找货
AA.105.301111
  • 1+123.749231+16.00886
  • 10+121.8973310+15.76928
  • 30+91.5806930+11.84736
  • 100+91.04621100+11.77822
  • 250+89.77780250+11.61413
库存:357
AA.105.301111
    • 5+167.832725+21.71173
    • 10+162.5935710+21.03396
    • 25+116.2720625+15.04157
    • 50+114.4929150+14.81141
    库存:630
    AA.105.301111
      • 1+152.997071+19.79251
      • 22+113.2259122+14.64750
      • 44+111.1156144+14.37450
      • 88+109.0053188+14.10150
      • 100+106.81384100+13.81800
      库存:99
      AA.105.301111
        AA.105.301111
          • 1+125.907651+16.28808
          • 10+124.0234510+16.04433
          • 30+93.1780330+12.05400
          • 100+92.63422100+11.98365
          • 250+91.34369250+11.81670
          库存:357
          AA.105.301111
            • 5+98.97695
            • 22+97.15121
            • 44+95.32547
            • 88+93.49972
            • 100+91.67398
            库存:103
