ANT-2.4-WRT-RPS
ANT-2.4-WRT-RPS
    LINXTECHNOLOGIES(灵思)
    ANT-2.4-WRT-RPS
ANT-2.4-WRT-RPS 数据手册
Datasheet ANT-2.4-WRT-ccc 2.4 GHz External Panel-Mount Antenna The ANT-2.4-WRT is a low-profile, panel-mount dipole antenna designed for 2.4 GHz ISM frequency band applications such as Bluetooth® and ZigBee®. The ANT-2.4-WRT antenna’s compact size allows it to be mounted in applications requiring a low profile and external antenna performance, such as wireless vending and traffic control equipment. The ANT-2.4-WRT antenna is designed with an integrated counterpoise that eliminates the need for additional ground plane in the product, making it ideal for applications with non-conductive or RF transparent enclosures. ANT-2.4-WRT-SMA Shown Connector options for the ANT-2.4-WRT antenna are: SMA plug (male pin), RP-SMA plug (female socket), MHF1/U.FL-type plug (female socket), or MHF4-type plug (female socket). Features Applications • Performance at 2.4 GHz ― VSWR: ≤ 1.5 ― Peak Gain: 9.1 dBi ― Efficiency: 66% • Low-profile ― Height: 10.0 mm (0.40 in) ― Diameter: 19.0 mm (0.75 in) • Mounts permanently with pressure sensitive adhesive ring and provided nut • Single-band WiFi/WLAN/802.11 ― WiFi 4 • 2.4 GHz ISM applications ― Bluetooth® ― ZigBee® • U-NII and ISM applications • Internet of Things (IoT) devices • Smart Home networking • Sensing and remote monitoring Ordering Information Part Number Description ANT-2.4-WRT-UFL-100 Antenna, 100 mm (3.94 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) ANT-2.4-WRT-UFL-150 Antenna, 150 mm (5.91 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) ANT-2.4-WRT-UFL Antenna, 216 mm (8.50 in) of 1.32 mm coaxial cable, MHF1/U.FL-type plug (female socket) ANT-2.4-WRT-MHF4 Antenna, 216 mm (8.50 in) of 1.13 mm coaxial cable, MHF4-type plug (female socket) ANT-2.4-WRT-RPS Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, RP-SMA plug (female socket) ANT-2.4-WRT-SMA-150 Antenna, 150 mm (5.91 in) of RG-174 coaxial cable, SMA plug (male pin) ANT-2.4-WRT-SMA Antenna, 216 mm (8.50 in) of RG-174 coaxial cable, SMA plug (male pin) Available from Linx Technologies and select distributors and representatives. WRT Series ANT-2.4-WRT-ccc Datasheet Table 1.   Electrical Specifications ANT-2.4-WRT Frequency Range VSWR (max) Peak Gain (dBi) Average Gain (dBi) Adhesive Ring Efficiency (%) 8-sided plastic nut and mounting shaft -SMA, -RPS -MHF1/U.FL Ø5.3 mm (0.21 in) Counterpoise Polarization Impedance Wavelength M11 x 1.0 mm Linear 50 Ω 1/2-wave 2.4 GHz 2.4 GHz to 2.5 GHz 1.5 9.1 -2.0 Ø19.0 mm 66 (0.75 in) Omnidirectional 5W Dipole Radiation Max Power Electrical Type Electrical specifications and plots measured in free space. 8.0 mm -MHF1/U.FL 10.0 mm Table 2.   Mechanical Specifications (0.32 in) (0.39 in) 82.5 mm (3.25 in) Part Number Connection Coaxial Cable, minimum inside bend radius MHF1/U.FL-type plug 1.32 mm: 6.0 mm (0.24 in) 100 mm = 4.6 g (0.16 oz) 150 mm = 4.9 g (0.17 oz) 216 mm = 5.2 g (0.18 oz) See Ordering Information for cable length and termination options ANT-2.4-WRT-UFL ANT-2.4-WRT-MHF4 ANT-2.4-WRT-RPS 916 MHF4-type plug RP-SMA plug MHz SMA plug ANT-2.4-WRT-SMA -SMA, -RPS Weight 1.13 mm: 5.0 mm (0.20 in) 216 mm = 5.1 g (0.18 oz) RG-174: 10.2 mm (0.40 in) 216 mm = 7.0 g (0.25 oz) RG-174: 10.2 mm (0.40 in) 150 mm = 6.1 g (0.22 oz) 216 mm = 7.0 g (0.25 oz) -MMCX -40 °C to +90 °C Operating Temp. Range Height: 10.0 mm (0.40 in), Diameter: 19.0 mm (0.75 in) Dimensions Packaging Information The ANT-2.4-WRT antenna is placed in a clear plastic sleeve and sealed in clear plastic bags in quantities of 50 pcs. Bags are packaged in cartons of 250 (5 bags). Distribution channels may offer alternative packaging options. Product Dimensions Figure 1 provides dimensions for the ANT-2.4-WRT series antenna. Adhesive Ring 8-sided plastic nut and mounting shaft M11 x 1.0 mm Ø5.3 mm (0.21 in) Counterpoise Ø19.0 mm (0.75 in) -SMA, -RPS -SMA, -MHF1/-U.FL -MHF4 8.0 mm (0.32 in) 32.5 mm (1.28 in) See Ordering Information for cable length and termination options Figure 1.  ANT-2.4-WRT Series Antenna Dimensions 2.4 Hex Nut M11 x 1.0 mm 2 10.0 mm (0.39 in) -MHF1/ - WRT Series ANT-2.4-WRT-ccc Datasheet Recommended Mounting 8-s The recommended enclosure mounting dimensions areMounting shown in Figure 2. The ANT-2.4-WRT series Recommended antenna is supplied with an integrated closed-cell pressure sensitive adhesive ring which helps seal -SMA, -RPS enclosures against external elements. The adhesive ring has a protective plastic backing that must be removed prior to installation. A pull tab has been provided for easy removal of the protective backing. The antenna can be permanently mounted using the provided nut which should be tightened-MHF1/-U.FL to 4.0 kgf/cm (5 in/ lbs) max. The recommended maximum enclosure wall thickness is 4.70 mm (0.188 in). Ø5. C -MHF4 Ø10.8 mm (0.43 in) See O cable leng Figure 2.  ANT-2.4-WRT Series Antenna Recommended Enclosure Mounting Dimensions Antenna Orientation The ANT-2.4-WRT antenna is characterized in two antenna orientations as shown in Figure 3. The antenna in free space characterizes use of an antenna attached to an enclosure-mounted connector which is connected by cable to a printed circuit board. Although the antenna is a dipole not requiring a ground plane for function, characterization with an adjacent ground plane (102 mm x 102 mm) provides insight into antenna performance when attached directly to a printed circuit board mounted connector. The two orientations represent the most common end-product use cases. Free Space Center of Ground Plane Figure 3.  ANT-2.4-WRT Series Antenna Test Orientations 3 WRT Series ANT-2.4-WRT-ccc Datasheet Free Space, No Ground Plane The charts on the following pages represent data taken with the antenna oriented in free space without a ground plane, as shown in Figure 4. Figure 4.  ANT-2.4-WRT in Free Space, No Ground Plane VSWR 2500 5 2400 Figure 5 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 1 2400 10 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 Figure 5.  ANT-2.4-WRT VSWR, Free Space 4 2480 2490 0 2500 Reflected Power (%) 40 WRT Series ANT-2.4-WRT-ccc Datasheet Return Loss 2500 0 2400 Return loss (Figure 6), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. -2 Return Loss (dB) -4 -6 -8 -10 -12 -14 -16 -18 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 6.  ANT-2.4-WRT Return Loss, Free Space Peak Gain 2500 10 2400 The peak gain across the antenna bandwidth is shown in Figure 7. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 5 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 7.  ANT-2.4-WRT Peak Gain, Free Space 5 WRT Series ANT-2.4-WRT-ccc Datasheet Average Gain 2500 10 2400 Average gain (Figure 8), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 5 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 8.  ANT-2.4-WRT Antenna Average Gain, Free Space Radiation Efficiency 2500 100 2400 Radiation efficiency (Figure 9), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 Figure 9.  ANT-2.4-WRT Series Antenna Radiation Efficiency, Free Space 6 2490 2500 WRT Series ANT-2.4-WRT-ccc Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns for a free space orientation are shown in Figure 10 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. Radiation Patterns - Free Space XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 2400 MHz to 2500 MHz (2450 MHz) 34 35 33 32 31 30 29 28 36 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 30 9 29 10 28 11 27 12 26 25 13 24 14 23 15 22 21 20 19 18 XZ-Plane Gain 17 16 35 36 10 1 2 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 17 YZ-Plane Gain 16 35 36 10 1 2 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 3 4 5 6 7 8 9 10 11 26 12 25 13 24 14 23 15 22 21 20 19 18 17 16 2400 MHz 2450 MHz 2500 MHz XY-Plane Gain Figure 10.  ANT-2.4-WRT Antenna Radiation Patterns, Free Space 7 WRT Series ANT-2.4-WRT-ccc Datasheet Center of Ground Plane The charts on the following pages represent data taken with the antenna oriented at the center of the ground plane, as shown in Figure 11. Figure 11.  ANT-2.4-WRT Series Antenna at Center of Ground Plane VSWR 2500 5 2400 Figure 12 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 1 2400 10 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 Figure 12.  ANT-2.4-WRT Antenna VSWR at Center of Ground Plane 8 0 2500 Reflected Power (%) 40 WRT Series ANT-2.4-WRT-ccc Datasheet Return Loss 2500 0 2400 Return loss (Figure 13), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. -2 Return Loss (dB) -4 -6 -8 -10 -12 -14 -16 -18 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 13.  ANT-2.4-WRT Return Loss at Center of Ground Plane Peak Gain 2500 10 2400 The peak gain across the antenna bandwidth is shown in Figure 14. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 5 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 14.  ANT-2.4-WRT Peak Gain at Center of Ground Plane 9 WRT Series ANT-2.4-WRT-ccc Datasheet Average Gain 2500 10 2400 Average gain (Figure 15), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 5 0 -5 -10 -15 -20 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 2500 Figure 15.  ANT-2.4-WRT Antenna Average Gain at Center of Ground Plane Radiation Efficiency 2500 100 2400 Radiation efficiency (Figure 16), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 2400 2410 2420 2430 2440 2450 2460 Frequency (MHz) 2470 2480 2490 Figure 16.  ANT-2.4-WRT Antenna Radiation Efficiency at Center of Ground Plane 10 2500 WRT Series ANT-2.4-WRT-ccc Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns are shown in Figure 17 using polar plots covering 360 degrees. The antenna graphic at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. Radiation Patterns - Center of Ground Plane XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 2400 MHz to 2500 MHz (2450 MHz) 34 35 33 32 31 30 29 28 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 27 26 30 9 29 10 28 11 27 12 25 13 24 14 23 15 22 21 20 19 18 XZ-Plane Gain 17 16 35 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 1 2 3 4 34 5 33 6 32 7 31 8 26 30 9 29 10 28 11 27 12 25 13 24 21 20 19 18 17 1 2 3 4 5 6 7 8 9 10 26 12 25 15 22 36 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 11 14 23 35 16 YZ-Plane Gain 13 24 14 23 15 22 21 20 19 18 17 16 2400 MHz 2450 MHz 2500 MHz XY-Plane Gain Figure 17.  ANT-2.4-WRT Radiation Patterns 11 WRT Series ANT-2.4-WRT-ccc Datasheet Website: http://linxtechnologies.com Linx Offices: 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 (541) 471-6256 E-MAIL: info@linxtechnologies.com Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their respective owners. Copyright © 2022 Linx Technologies All Rights Reserved Doc# DS22070-204ANT Replaces (DS21348-204ANT)
ANT-2.4-WRT-RPS 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-WRT-RPS”相匹配的价格&库存,您可以联系我们找货
