SPECIFICATION
Patent Pending
Part Number
FXP611.07.0092C
Product Name
“The Cloud” Flexible Polymer
GPS/GLONASS/GALILEO/BeiDou
Cloud Shape Antenna
Features
1559-1610 MHz
38mm*37mm*0.15mm size
92mm Cable
IPEX MHFI Connector (U.FL compatible)
RoHS Compliant
SPE-13-8-010/E/AS
Page 1 of 12
1. Introduction
This convenient “peel and stick” flexible polymer antenna is designed for applications
which require high positioning accuracy using GPS, GLONASS, Galileo and even BeiDou
functions on modern day GNSS systems. The antenna is designed to be mounted directly
to plastic (e.g. ABS enclosure of a wireless device) and has been designed in a way that
makes it extremely resistant to detuning affects caused by the device environment.
SPE-13-8-010/E/AS
Page 2 of 12
2. Specification
ELECTRICAL
ANTENNA
GPS-GLONASS-GALILEO-BeiDou
STANDARD
Operation Frequency (MHz)
1559-1610
Polarization
Linear
Impedance (Ohms)
50
Max VSWR
1.2:1
Peak Gain (dBi)
3
Efficiency (%)
80
Average Gain (dB)
-1
Radiation Properties
Omnidirectional
Max Input Power (Watts)
5
* The FXP611 antenna performance was measured with 30X30 cm ABS Plastic.
MECHANICAL
Antenna
Standard
Dimensions (mm)
38x37x0.15
Required Space (mm)
40x40x0.2
Material
Flexible Polymer
Connector
MHFI(U.FL Compatible)
Weight(g)
0.9
** The FXP611 antenna requires at least 1cm clearance to metal or to the main device ground
plane
ENVIRONMENTAL
Antenna
Standard
Operation Temperature
Storage Temperature
-40°C to 85°C
-40°C to 105°C
Relative Humidity
40% to 95%
RoHS Compliant
Yes
SPE-13-8-010/E/AS
Page 3 of 12
3. Test Setup
Figure 1: Impedance, isolation and correlation coefficient measurements (left hand)
and peak gain, average gain, efficiency and radiation pattern measurements (right hand)
SPE-13-8-010/E/AS
Page 4 of 12
4. Antenna Parameters
4.1. Return Loss
Figure 2: Return loss of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna
4.2. VSWR
Figure 3: VSWR of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna
SPE-13-8-010/E/AS
Page 5 of 12
4.3. Efficiency
Figure 4: Efficiency of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna
4.4. Peak Gain
Figure 5: Peak Gain of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna
SPE-13-8-010/E/AS
Page 6 of 12
4.5. Average Gain
Figure 6: Average Gain of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna
SPE-13-8-010/E/AS
Page 7 of 12
4.6. Radiation Pattern
Figure 7: Radiation Pattern of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna at 1561MHz
Figure 8: Radiation Pattern of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna at 1575MHz
SPE-13-8-010/E/AS
Page 8 of 12
Figure 9: Radiation Pattern of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna at 1589MHz
Figure 10: Radiation Pattern of FXP611 GPS/GLONASS/GALILEO/BeiDou Antenna at 1610MHz
SPE-13-8-010/E/AS
Page 9 of 12
5. Mechanical Drawing
5.1. Antenna
SPE-13-8-010/E/AS
Page 10 of 12
5.2. Connector
SPE-13-8-010/E/AS
Page 11 of 12
6. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-13-8-010/E/AS
Page 12 of 12
很抱歉,暂时无法提供与“FXP611.07.0092C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+181.637235+23.26490
- 25+99.8473925+12.78890
- 国内价格 香港价格
- 1+76.818501+9.83926
- 10+59.5386710+7.62598
- 25+55.2210925+7.07296
- 100+50.47638100+6.46524
- 300+47.83001300+6.12628
- 500+46.85113500+6.00090
- 1000+45.729121000+5.85719
- 国内价格 香港价格
- 2+66.388992+8.50340
- 10+56.6236710+7.25261
- 25+53.6005525+6.86540
- 100+37.81608100+4.84365
- 300+36.19293300+4.63575
- 500+35.42234500+4.53705
- 1000+34.577981000+4.42890
