AA.108.301111
AA.108.301111
    TAOGLASLIMITED
    AA.108.301111
AA.108.301111 数据手册
SPECIFICATION Part No. : AA.108.301111 Product Name : Titan GPS/GALILEO Antenna AA.108 Features : Adhesive Mount Covert stylish design Wide band input voltage IP-67 Waterproof 3M RG-174 SMA(M) Connector Cable and connector customizable RoHS Compliant SPE-11-8-067/C/SS Page 1 of 8 1. Introduction Our AA.108 Titan adhesive mount external antenna is ideal for robust, covert installations where durability and small size is paramount. It is ideal for telematics and M2M applications for commercial vehicle installations for fleet management etc. Titan antennas are also widely used for consumer GPS/GALILEO devices when extra sensitivity is required, e.g. navigation devices and speed trap detectors. The AA.108 is first tier automotive approved IP67 antenna, the part AA.108.301F21 (with GT5 connector) is listed in the global automotive IMDS databases, it has gone through full PPAP design, reliability and quality audits, including audits at the production facility. SPE-11-8-067/C/SS Page 2 of 8 2. Specifications Ceramic Patch Outline Dimension 25*25*4mm Ground Size 25*25*4mm Center Frequency 1575.42±3MHz Bandwidth 10MHz VSWR 1.92 Max Axial ratio 3dB Typ. Gain @ Zenith 2dBic Typ. Impedance 50Ω Polarization RHCP LNA Specification Frequency 1575.42MHz Impedance 50Ω VSWR 1.92 Max. DC Power Input 1.8V 2.5V 2.7V 3.3V 5V Gain 21.8dB 28dB 29dB Noise Figure 1.4dB 1.38dB 1.3dB Power Consumption 4.5mA 6.6mA 7mA 12V 31dB Band Attenuation 40dB @fo±50MHz Operating temp -40°C ~ +85°C Storage Temp -40°C ~ +90°C *Formula = Patch Antenna Average Gain + LNA typical gain – RG174 cable loss @1.2dB per meter = Gain at connector Gain at the Connector - Patch Gain 2dB + LNA Gain 30dB – Cable loss of 1.2dB per metre (@3m = 3.6dB) = 28.4dB approx. SPE-11-8-067/C/SS Page 3 of 8 3. Ceramic Antenna Radiation Pattern (with housing) 3.1. Ceramic Antenna S11 (with housing) SPE-11-8-067/C/SS Page 4 of 8 3.2. XZ Plane & YZ Plane SPE-11-8-067/C/SS Page 5 of 8 3.3. LNA gain 3.4. LNA S22 SPE-11-8-067/C/SS Page 6 of 8 4. Drawing (Unit: mm) SPE-11-8-067/C/SS Page 7 of 8 5. RG-174 Cable Specification RG-174 Cable Attenuation(dB/100mm) GHz 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 RG-174 67 110 127 153 168 183 207 229 252 272 291 311 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-067/C/SS Page 8 of 8
AA.108.301111 价格&库存
很抱歉,暂时无法提供与“AA.108.301111”相匹配的价格&库存,您可以联系我们找货
AA.108.301111
  • 1+202.937891+26.25544
  • 10+162.4570610+21.01816
  • 30+150.6346730+19.48862
  • 100+141.24732100+18.27411
  • 250+135.95268250+17.58911
  • 500+132.76248500+17.17637
库存:290
AA.108.301111
  • 5+98.97695
  • 22+97.15121
  • 44+95.32547
  • 88+93.49972
  • 100+91.67398
库存:539
