FXP290.07.0100A
FXP290.07.0100A
    TAOGLASLIMITED
    FXP290.07.0100A
FXP290.07.0100A 数据手册
SPECIFICATION Part No. : FXP290.07.0100A Model : 915MHz ISM Band Flex Circuit Antenna Features : 75*45*0.1mm 100mm Ø1.13 Cable RoHS & REACH compliant SPE-15-8-025/B/WY Page 1 of 10 1. OVERVIEW The Taoglas FXP290 915 MHz ISM Antenna covers from 902-928 MHz used in the 915 MHz ISM (Industrial Scientific Medical) Band. The antenna has been designed in a flexible material with a square form-factor and cable connection for an easy installation. The antenna works on different plastic materials and thickness. We have selected a piece of ABS with 2 mm of thickness as a baseline for testing. 2. ANTENNA CHARACTERISTICS Parameter Frequency Range Return Loss (dB) Efficiency (%) Gain (dBi) Impedance VSWR Polarization Power Handled Operation Temperature Storage Temperature Dimensions Weight Connector Cable Standard Cable Length and color RoHS Compliant Adhesive Specification 902MHz to 928MHz -20 40 1.5 50 Ω ≤2:1 Linear 5W -40°C ~ +85°C -40°C ~ +85°C 75*45*0.1mm 1.5g MHFII (U.FL Compatible) Mini-Coax 1.13 mm 100mm, Black Yes 3M 467 SPE-15-8-025/B/WY Page 2 of 10 3. TEST SET UP An ETS-Lindgren 3D Scan System with Anechoic Chamber Y X Z Figure 1. ETS-Lindgren System. Rhode & Schwartz ZVL6 Vector Network Analyzer Figure 2. Network Analyzer. SPE-15-8-025/B/WY Page 3 of 10 4. ANTENNA PARAMETERS The next antenna parameter graphs like Return Loss, VSWR and smith chart were measured in the Agilent Rhode & Schwartz ZVL6 Vector Network Analyzer. The Gain, Efficiency and Radiation Patterns were measured in the ETS-Lindgren 3D Scan System. 4.1. Return Loss Data Figure 3. Return Loss for the FXP290 Antenna. 4.2. VSWR Data Figure 4. VSWR for the FXP290 Antenna. SPE-15-8-025/B/WY Page 4 of 10 4.3. Smith Chart Data Figure 5. Smith Chart for the FXP290 Antenna. 4.4. Efficiency Data Figure 6. Efficiency for the FXP290 Antenna. SPE-15-8-025/B/WY Page 5 of 10 4.5. Gain Data Figure 7. Gain for the FXP290 Antenna. 4.6. Radiation Pattern Data. Figure 8. Radiation pattern 3D View, Figure 1 as reference (dB). SPE-15-8-025/B/WY Page 6 of 10 Figure 9. Radiation pattern YZ Plane, Figure 1 as reference (dB). Figure 10. Radiation pattern XY plane, Figure 1 as reference (dB). SPE-15-8-025/B/WY Page 7 of 10 Figure 11. Radiation pattern XY plane, Figure 1 as reference (dB). SPE-15-8-025/B/WY Page 8 of 10 5. MECHANICAL DRAWING Figure 12. Mechanical Drawing for the FXP290 Antenna. SPE-15-8-025/B/WY Page 9 of 10 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. © Taoglas SPE-15-8-025/B/WY Page 10 of 10
FXP290.07.0100A 价格&库存
很抱歉,暂时无法提供与“FXP290.07.0100A”相匹配的价格&库存,您可以联系我们找货
FXP290.07.0100A
  • 12+62.26164
  • 50+61.00395
  • 100+51.80485
库存:7344
FXP290.07.0100A
    • 12+67.0479312+8.67840
    • 50+65.7384050+8.50890
    • 100+55.78598100+7.22070
    库存:7344
    FXP290.07.0100A
    • 10+43.61225
    • 50+42.82633
    • 100+40.39604
    库存:7414
    FXP290.07.0100A
    • 1+98.766981+12.78398
    • 10+77.2498110+9.99889
    • 25+71.8736125+9.30302
    • 100+65.96274100+8.53794
    • 300+62.66521300+8.11112
    • 500+61.44592500+7.95330
    • 1000+60.048021000+7.77237
    库存:968
