FW.80.SMA.M
FW.80.SMA.M
    TAOGLASLIMITED
    FW.80.SMA.M
FW.80.SMA.M 数据手册
SPECIFICATION Part No. : FW.80.SMA.M Product Name : Meteor 169MHz 0dBi Flexible Whip Monopole Omni-Directional Antenna SMA Male connector Feature : IP67 Housing 1/4 Wavelength Robust but Flexible Inner Steel Whip High Efficiency Outdoor Antenna Advanced RF Design and Materials RoHS Compliant SPE-12-8-033/D/PK Page 1 of 7 1. Introduction The Meteor FW.80 is a 0dBi 169MHz ISM band 1/4 wavelength monopole flexible whip antenna with omni- directional pattern optimized in the azimuth for wide coverage range in typical 169 MHz applications such as Wireless M-Bus metering. It also finds its usage in remote asset monitoring applications, alarms, paging systems and private mobile radio services. The Meteor has a IP67 housing. The antenna, like all low frequency monopole antennas needs to be mounted to a metal plate to radiate. For a waterproof integration to a metal box a waterproof panel mount SMA connector or cable assembly can be provided. TNC and N-type antenna versions are also available. This whip is made up of a flexible inner steel core covered by TPU so extremely resistant to collisions and maintaining its original shape and RF performance. Customized frequency and gain versions can be supplied. SPE-12-8-033/D/PK Page 2 of 7 2. Specification Table Meteor FW.80 Frequency (MHz) 169 Peak Gain (dBi) * 0dBi Average Gain (dBi) * -3.9 Efficiency (%) * 40% Impedance (Ω) 50 Polarization Linear Radiation Pattern Omnidirectional Input Power(W) 50 MECHANICAL Dimensions (mm) 353xφ16 Base Diameter (mm) φ16 Whip Diameter (mm) φ4 Casing ABS Connector SMA(M) ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH * For low frequency antennas these parameters can only be estimated using RF formula calculation, simulation or rough field test comparisons with large benchmark antennas. SPE-12-8-033/D/PK Page 3 of 7 3. Antenna Characteristics 3.1 Antenna setup Antenna is placed on metal ground 30x30cm 3.2 SWR (on metal ground plane 30x30cm) SPE-12-8-033/D/PK Page 4 of 7 4. Drawing Name Material P/N Finish QTY Housing 000111K0600XXA ABS Flexible Whip 001111K0000XXA Steel+PE Jacket Black 1 Cap 000711C0000XXA ABS Black 1 Outer Body SMA(M) 000611B0000XXA Brass Black 1 SPE-12-8-033/D/PK Black 1 Page 5 of 7 5. Packaging SPE-12-8-033/D/PK Page 6 of 7 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-033/D/PK Page 7 of 7
FW.80.SMA.M 价格&库存
很抱歉,暂时无法提供与“FW.80.SMA.M”相匹配的价格&库存,您可以联系我们找货
FW.80.SMA.M
  • 1+132.451671+17.18550
  • 10+104.6212310+13.57452
  • 50+93.4617250+12.12658
  • 100+90.00648100+11.67827
  • 250+86.35866250+11.20497
  • 500+84.16044500+10.91975
  • 1000+82.351461000+10.68504
库存:120
FW.80.SMA.M
    • 10+62.07521
    • 40+60.93866
    • 75+59.71746
    库存:96
