AP.10H.01
AP.10H.01
    TAOGLASLIMITED
    10MM SMT 25DB ACTIVE GPS/GALILEO PATCH ANTENNA WITH FRONT END SAW FILTER
AP.10H.01 数据手册
SPECIFICATION Part No. : Product Name : AP.10H.01 10mm SMT 25dB Active GPS/GALILEO Patch Antenna With Front End Saw Filter Features : Unique SMT GPS/GALILEO active patch Wide Input Voltage 1.8V to 5.5V Ultra low power consumption RoHS compliant SPE-11-8-101/E/SS Page 1 of 10 1. Introduction The AP.10H.01 two stage 25dB active GPS/GALILEO patch antenna is the smallest SMT GPS/GALILEO high performance embedded antenna currently available in the world. Using extremely sensitive high dielectric constant powder formulation and tight process control the 10mm x 10mm x 4mm patch antenna is accurately tuned to have its frequency band right at 1575.42MHz for GPS/GALILEO systems. A patented SMT structure gives high reliability in integration. With an ultra low power consumption two stage LNA with Saw Filter, this small active patch has the performance of an ordinary active patch, but at only a quarter of the size. This product is suited to small form factor mobile devices such as GPS/GALILEO Smartphones, Personal Location, Medical devices, Telematic devices and Automotive navigation and tracking. Custom gain, connector and cable versions are available. The AP.10H consists of 2 functional blocks – the LNA and also the patch antenna. SPE-11-8-101/E/SS Page 2 of 10 2. Specification ELECTRICAL Frequency 1575.42 ± 1.023MHz Gain Typ. -10dBic @ Zenith Gain@3.0V (With LNA) 15 ± 4dBic @ 90o Impedance 50Ω Polarization RHCP Axial Ratio Max 4.0dB @ Zenith Input Voltage Min. 1.8V, ESD Capability Typ. 3.0V, Max. 5.5V Direct Discharge: 4KV Min. LNA Frequency 1575.42 ± 1.023MHz F0=1575.42MHz Outer Band Attenuation F0±30MHz 5dB min. F0±50MHz 20dB min. F0±100MHz 25dB min. Output Impedance 50Ω Output VSWR 2.0 Max Pout at 1dB Gain Min. 8dBm Compression point Typ. 11dBm LNA Gain, Power Consumption and Noise Figure LNA Gain(Typ) Power Consumption(mA)Typ Noise Figure(Typ) Minimum 1.8V 20dB 5mA 2.7dB Typical 3.0V 25dB 10mA 2.5dB Maximum 5.5V 25dB 23mA 2.7dB Input Voltage Min. 1.8V Typ. 3.0V Max. 5.5V MECHANICAL Dimension 10mm x 10mm x 4mm (add 7.3mm depth for vertical PCB) Connection SMT via solder pads ENVIRONMENTAL Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% SPE-11-8-101/E/SS Page 3 of 10 2.1. LNA Gain and Out Band Rejection @3.0V SPE-11-8-101/E/SS Page 4 of 10 2.2. LNA Noise Figure @3.0V SPE-11-8-101/E/SS Page 5 of 10 3. Radiation Patterns XY Plane XZ Plane YZ Plane SPE-11-8-101/E/SS Page 6 of 10 4. Technical Drawing SPE-11-8-101/E/SS Page 7 of 10 4.1. PCB Footprint SPE-11-8-101/E/SS Page 8 of 10 5. Recommended Reflow Soldering Profile SPE-11-8-101/E/SS Page 9 of 10 6. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-101/E/SS Page 10 of 10
AP.10H.01 价格&库存
很抱歉,暂时无法提供与“AP.10H.01”相匹配的价格&库存,您可以联系我们找货
AP.10H.01
  • 1+146.845361+19.02161
  • 10+116.3724710+15.07431
  • 25+108.7545125+14.08752
  • 100+100.38223100+13.00301
库存:412
AP.10H.01
  • 250+96.39032250+12.48592
  • 500+93.98474500+12.17431
  • 750+92.78000750+12.01826
库存:412
