AP.12F.07.0045A
AP.12F.07.0045A
    TAOGLASLIMITED
    AP.12F.07.0045A
AP.12F.07.0045A 数据手册
SPECIFICATION Part No. : AP.12F.07.0045A Product Name : 12mm Two Stage 25dB GPS/GALILEO Active Patch Antenna Module with front-end Saw Filter Features : 13.4*13.4*6mm (Ground Plane) 45mm Ø1.13 cable IPEX MHFI (U.FL) 28dB LNA Wide Input Voltage 1.8V to 5.5V Low Power Consumption RoHS & Reach compliant SPE-11-8-094/E/SS Page 1 of 9 1. Introduction The AP.12F has been designed specifically for embedded (inside device) integration with GPS/GALILEO receiver modules where there is a GSM transmitter nearby and risk of interference and saturation. The AP.12F combines a 12*12*3.5mm advanced low profile ceramic patch antenna with a two stage LNA and a front-end SAW filter with ultra thin coaxial cable. Only 5.6mm in height, this Taoglas active antenna module utilises XtremeGain™ technology for the highest industry sensitivity. The AP.12F consists of 2 functional blocks – the LNA and also the patch antenna. The AP.12F has a SAW filter on the front of it. The main use of the AP.12F would be for small devices where the GSM transmitter is close to the GPS/GALILEO antenna, it helps avoid burn-out of the LNA or the module due to interference from the GSM transmitter at out band frequencies. SPE-11-8-094/E/SS Page 2 of 9 2. Specification ELECTRICAL Frequency 1575.42 ± 1.023MHz Gain @ Zenith -5 dBic Typ. @ Zenith Gain (with LNA) At 3V: 23 ± 4dBi@90° Impedance 50Ω Polarization RHCP Axial Ratio 4.0dB max. @Zenith Input Voltage Min. 1.8V Typ 3.0V Max. 5.5V LNA Frequency 1575.42 ± 1.023MHz F0=1575.42MHz Outer Band Attenuation F0 30MHz 8dB min. F0 50MHz 20dB min. F0 100MHz 25dB min. Output Impedance 50Ω Output VSWR 2.0 Max Pout at 1dB Gain Typ. 11dBm Compression point Min. 5dBm LNA Gain, Power Consumption and Noise Figure Voltage LNA Gain (Typ) Power Consumption(mA) Typ Noise Figure Typ Min. 1.8V 20dB 4mA 2.0dB Typ. 3.0V 28dB 9mA 2.0dB Max. 5.5V 29dB 20mA 2.0dB Input Voltage Min. 1.8V Typ. 3.0V Max. 5.5V MECHANICAL Dimension 12mm x 12mm x 3.5mm RF Cable Coaxial Cable Ø1.13 ± 0.1mm, length 45 ± 2.5mm Connector IPEX MHFI (U.FL) ENVIRONMENTAL Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% SPE-11-8-094/E/SS Page 3 of 9 2.1. LNA Gain and Out Band Rejection @3.0V 2.2. LNA Noise Figure @3.0V SPE-11-8-094/E/SS Page 4 of 9 3. Radiation Patterns XY Plane XZ Plane YZ Plane SPE-11-8-094/E/SS Page 5 of 9 4. Plugs Usage and Precautions 4.1. Mating / Un-mating (1) To disconnect connectors, insert the end portion of I-PEX under the connector flanges and pull off vertically, in the direction of the connector mating axis. (2) To mate the connectors, the mating axes of both connectors must be aligned and the connectors can be mated. The "click" will confirm fully mated connection. Do not attempt to insert on an extreme angle. 4.2. Pull forces on the cable after connectors are mated After the connectors are mating, do not apply a load to the cable in excess of the values indicated in the diagram below. SPE-11-8-094/E/SS Page 6 of 9 5. Technical Drawing SPE-11-8-094/E/SS Page 7 of 9 6. Packaging SPE-11-8-094/E/SS Page 8 of 9 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. © Taoglas SPE-11-8-094/E/SS Page 9 of 9
AP.12F.07.0045A 价格&库存
很抱歉,暂时无法提供与“AP.12F.07.0045A”相匹配的价格&库存,您可以联系我们找货
AP.12F.07.0045A
  • 120+72.54786120+9.40359
  • 360+71.34563360+9.24776
  • 720+70.82016720+9.17964
库存:1200
AP.12F.07.0045A
    AP.12F.07.0045A
      • 5+295.281125+38.27406
      • 25+176.4956025+22.87719
      • 50+163.9752250+21.25431
      库存:155
      AP.12F.07.0045A
        • 1+221.17320
        • 200+88.24680
        • 360+85.29840
        • 1080+83.84040
        AP.12F.07.0045A
          • 120+73.81323120+9.56760
          • 360+72.59003360+9.40905
          • 720+72.05539720+9.33975
          库存:1200
          AP.12F.07.0045A
            AP.12F.07.0045A
            • 1+145.428531+18.85031
            • 10+115.1864310+14.93036
            • 25+107.6369425+13.95180
            • 100+99.33616100+12.87586
            • 360+94.06685360+12.19286
            • 720+91.91505720+11.91394
            库存:227
