AP.10E.07.0039B
AP.10E.07.0039B
    TAOGLASLIMITED
    AP.10E.07.0039B
AP.10E.07.0039B 数据手册
SPECIFICATION Part No. : AP.10E.07.0039B Product Name : AP.10E - 1 Stage 15dB 39mm 0.81 with IPEX MHFI (U.FL compatible) Feature : World smallest GPS/GALILEO active patch High performance Ultra low power consumption RoHS Compliant SPE-12-8-003/B/SS Page 1 of 9 1. Introduction AP.10E active GPS/GALILEO patch antenna is the smallest GPS high performance antenna currently available in the world. Using extremely sensitive high dielectric constant powder formulation and tight process control the 10*10*4mm patch antenna is accurately tuned to have its frequency band right at 1575.42MHz for GPS systems. With an ultra low power consumption one stage LNA, this small active patch has the performance of an ordinary active patch, but at only a quarter of the size. This product is suited to small form factor mobile devices such as GPS Smartphones, Personal Location, Medical devices, Telematic devices and Automotive navigation and tracking. Custom gain, connector and cable versions are available. The AP.10E consists of 2 functional blocks – the LNA and also the patch antenna. SPE-12-8-003/B/SS Page 2 of 9 2. Specification ELECTRICAL Frequency 1575.42 ± 1.023MHz Gain @ Zenith -10dBic Typ. @ Zenith Polarization RHCP Axial Ratio 4.0dB max. @Zenith Patch Dimension 10*10*4.0mm LNA Frequency 1575.42 ± 1.023MHz F0=1575.42MHz Outer Band Attenuation F0±30MHz 9dB min. F0±50MHz 20dB min. F0±100MHz 25dB min. Output Impedance 50Ω Output VSWR 2.0 Max Pout at 1dB Gain Compression point Typ. -2dBm Voltage Min. 1.8V Min. -6dBm LNA Gain, Power Consumption and Noise Figure Power LNA Gain (Typ) Consumption(mA) Typ 14dB 3mA Noise Figure Typ 2.5dB Typ. 3.0V 15dB 3mA 2.5dB Max. 5.5V 15dB 3mA 2.6dB MECHANICAL Dimensions 10*10*4.0mm RF Cable Coaxial Cable Ø0.81 ± 0.1mm, length 39 ± 2.0mm Connector IPEX MHFI (U.FL) ANTENNA WITH LNA Frequency 1575.42 ± 1.023MHz Gain At 3V: 5  4dBi@90 Output Impedance 50Ω Polarization RHCP Output VSWR Max 2.0 Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% Input Voltage Antenna Min:1.8V Typ. 3.0V Max:5.5V 10*10*5.9mm SPE-12-8-003/B/SS Page 3 of 9 3. LNA Gain and Out Band Rejection @3.0V SPE-12-8-003/B/SS Page 4 of 9 4. LNA Noise Figure @3.0V SPE-12-8-003/B/SS Page 5 of 9 5. Radiation Pattern XZ Plane Radiation YZ Plane Radiation XY Plane Radiation SPE-12-8-003/B/SS Page 6 of 9 6. Antenna Drawing SPE-12-8-003/B/SS Page 7 of 9 7. Plugs Usage Precautions 7.1. Mating / Unmating (1) To disconnect connectors, insert the end portion of I-PEX under the connector flanges and pull off vertically, in the direction of the connector mating axis. (2) To mate the connectors, the mating axes of both connectors must be aligned and the connectors can be mated. The "click" will confirm fully mated connection. Do not attempt to insert on an extreme angle. 7.2. Pull forces on the cable after connectors are mated After the connectors are mated, do not apply a load to the cable in excess of the values indicated in the diagram below. SPE-12-8-003/B/SS Page 8 of 9 8. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-003/B/SS Page 9 of 9
AP.10E.07.0039B 价格&库存
很抱歉,暂时无法提供与“AP.10E.07.0039B”相匹配的价格&库存,您可以联系我们找货
AP.10E.07.0039B
  • 1+154.558671+20.08797
  • 10+134.5432810+17.48657
  • 25+127.5868625+16.58245
  • 100+118.04397100+15.34216
  • 360+110.18433360+14.32064
  • 720+106.28148720+13.81339
库存:458
