Specification
Part No.
WA.500w.301151
Product Name :
Stingray Adhesive Mount
Wi-Fi/Zigbee Antenna
Features
Dual Band 2.4-2.5 GHz, 4.9-6.0 GHz
IP-65 Water Resistance
RG-174 – 3M, RP-SMA(M)
RoHS Compliant
SPE-13-8-045/E/SS
Page 1 of 20
1. Introduction
The WA.500w Stingray is a high efficiency, high gain adhesive mount dual band wireless
antenna. Its high quality low profile covert housing can be attached onto the glass or plastic.
The WA.500w is designed for applications that require omni-directional gain across both
bands to ensure wide coverage area and constant reception and transmission for Wi-Fi and
ZigBee applications.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions. In
practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi
when put inside a device. So ideally you should go for a slightly higher peak gain antenna than
mentioned on the module specification to compensate for this effect, giving you better
performance.
Upon testing of any of our antennas with your device and a selection of appropriate layout,
integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be
below the peak gain limits. Taoglas can then issue a specification and/or report for the
selected antenna in your device that will clearly show it complying with the peak gain limits,
so you can be assured you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than 2dBi
peak gain, but you don’t need to select an embedded antenna that has a peak gain of less
than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a
slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets
integrated into your device, performance will degrade below this 2dBi peak gain due to the
effects of GND plane, surrounding components, and device housing. If you want to be
absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher
peak gain than what is specified by the module manufacturer and enlisting our help will
ensure you are getting the best performance possible without exceeding the peak gain limits.
Cables and Connectors are customizable.
SPE-13-8-045/E/SS
Page 2 of 20
2. Specifications
2.1 Dimensions
Parameter
Specification
Base Diameter
55mm
Base Height
10.8mm
2.2 Electrical Characteristics
Parameter
Specification
Frequency
2.4/5.8GHz
Polarization
Linear
Impedance
50Ω
VSWR
1.92 Max
2.3 Mechanical
Parameter
Specification
Dimensions
Diameter 55mm Height 10.80mm
Colour
Black
Connector
RP-SMA(M)
Fully Customizable
Cable
RG174 Length = 3M
Fully Customizable
Weight
62g
SPE-13-8-045/E/SS
Page 3 of 20
2.4 Efficiency, Average Gain, & Peak Gain without cable
Frequency
Efficiency (%)
Average Gain dBi
Peak Gain dBi
On Plastic
On Glass
On Plastic
On Glass
On Plastic
On Glass
2400
30.421
48.78
-6.957
-4.475
2.452
5.382
2450
48.09
49.605
-4.217
-4.329
4.2
6.886
2500
57
46.247
-3.473
-4.687
4.933
5.844
5000
67.232
42.28
-2.45967
-3.64833
8.991
3.736
5150
71
42.7
-2.11333
-3.94167
9.161
4.532
5200
65.933
43.03
-2.448
-4.434
8.901
4.481
5250
72
43.398
-1.852
-4.18833
9.154
5.129
5300
63.761
40.8
-2.279
-4.954
8.502
4.369
5350
72.267
43.751
-1.65933
-4.11033
8.906
5.757
5400
61.363
42.88
-2.311
-4.658
7.905
5.056
5450
68.398
43.649
-1.74467
-4.076
8.135
4.739
5500
68.624
43.413
-1.69933
-4.00933
7.985
4.564
5550
70.21
45.55
-1.51533
-3.73533
7.907
5.094
5600
66.97
44.11
-1.72333
-3.898
7.656
4.863
5650
66.678
43.04
-1.78233
-3.841
7.635
4.205
5700
62.174
41.88
-2.12867
-3.92433
7.394
4.062
5750
68.187
42.21
0.311333
-4.013
7.859
4.917
5800
70.44
44.052
-1.505
-3.76133
7.901
4.308
5825
67.31
42.43
-2.113
-4.32467
7.769
3.615
5850
69.353
40.583
-1.62233
-4.21933
7.899
3.487
5875
76.068
45.984
-1.22067
-3.56
8.091
3.856
5900
69.981
43.385
-2.24767
-3.78733
7.611
3.990
5925
70.424
43.379
-1.581
-3.83533
7.701
4.262
5950
70.742
42.749
-1.59033
-3.876
7.755
3.899
6000
72.374
56.95
-1.51533
-3.48933
7.701
3.239
Plastic Dimension
520*520*13.8mm3, PC+ABS
Glass Dimension
500*500*3mm3
SPE-13-8-045/E/SS
Page 4 of 20
SPE-13-8-045/E/SS
Page 5 of 20
SPE-13-8-045/E/SS
Page 6 of 20
SPE-13-8-045/E/SS
Page 7 of 20
3.Drawing
SPE-13-8-045/E/SS
Page 8 of 20
4. Testing
SPE-13-8-045/E/SS
Page 9 of 20
SPE-13-8-045/E/SS
Page 10 of 20
SPE-13-8-045/E/SS
Page 11 of 20
SPE-13-8-045/E/SS
Page 12 of 20
SPE-13-8-045/E/SS
Page 13 of 20
SPE-13-8-045/E/SS
Page 14 of 20
SPE-13-8-045/E/SS
Page 15 of 20
SPE-13-8-045/E/SS
Page 16 of 20
SPE-13-8-045/E/SS
Page 17 of 20
SPE-13-8-045/E/SS
Page 18 of 20
5. Packaging
SPE-13-8-045/E/SS
Page 19 of 20
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas
reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-13-8-045/E/SS
Page 20 of 20
很抱歉,暂时无法提供与“WA.500W.301151”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+204.526361+26.49332
- 国内价格
- 7+141.98464
- 40+136.38651
- 80+130.88510
- 200+125.73434
- 700+120.58357
