SPECIFICATION
Part No.
AGGBP.25B.07.0060A
Description
25x25mm Two Stage GPS-GLONASS-GALILEO-BeiDou
Embedded Active Patch Antenna Module with Front-End
SAW Filter
Features
Full GPS-GLONASS-GALILEO-BeiDou Coverage
28dB two stage LNA
Ceramic patch Element
Front-end SAW filter to reduce out of band noise
Wide input voltage 1.8V to 5.5V
25.1 x 25.1 x 7.9mm
60mm Ø1.13 IPEX MHFI (U.FL)
Automotive TS16949 Production and Quality Approved
Cable length and connector type customizable
RoHS Compliant
SPE-15-8-022/A/WY Page 1 of 13
1. Introduction
The AGGBP.25B is an internal GPS/GLONASS/GALILEO/BeiDou active patch antenna
with Ø1.13 cable and IPEX MHFI connector. It is the ideal antenna for next generation
GNSS devices to achieve good sensitivity across all bands in a small form factor.
The active patch antenna, by means of a double resonance design, has a wide-band
operation over GPS/GLONASS/GALILEO/BeiDou systems from 1561MHz to 1606MHz.
It includes a two-stage LNA and front-end SAW filter to reduce out of band noise, such
as from nearby cellular transceivers. This antenna offers better protection from nearby
radiated power surges and greatly reduces the probability of damaging your
GPS/GLONASS/BeiDou receiver due to nearby transmissions.
The patch, the ground plane, the LNA, and front-end SAW components are all
integrated in a dimension of 25.1 x 25.1 x 7.9 mm, connecting with a Ø1.13 60mm
long coaxial cable and an IPEX MHFI connector. The AGGBP.25B is manufactured and
tested in a TS16949 first tier automotive approved facility. The cable length and
connector type can be adjusted for a MOQ.
For further optimization to customer specific device environments, custom tuned
patch antennas can be supplied, again to a MOQ. For more details please contact your
regional Taoglas sales office.
SPE-15-8-022/A/WY Page 2 of 13
2. Specification
2.1
Patch Antenna
ELECTRICAL
GPS: 1575.42 ± 1.023MHz
Frequency
Galileo: 1575.42 ± 4GHz
GLONASS: 1602 ± 5MHz
BEIDOU: 1561.098 ± 2.046MHz.
Polarization
Antenna Gain at Zenith
(Ceramic Patch only)
RHCP
GPS/Galileo: -2.5 dBi typ. @zenith
GLONASS: -1.5 dBi typ. @zenith
BEIDOU: -1 dBi typ. @zenith
Total Antenna Gain at Zenith
GPS/Galileo 1575.42MHz: 25.5 3dBi
(Antenna+SAW+LNA+
GLONASS 1602MHz: 26 3dBi
Cable+Connector)
BEIDOU 1561MHz: 27 3dBi
Impedance
50 ohms
Output VSWR
Max 2.0
MECHANICAL
Ceramic Dimension
Total Dimension
(including shielding case)
25.1 x 25.1 x 4.7mm
25.1 x 25.1 x 7.9mm
Connector
IPEX MHFI (U.FL)
Cable
coaxial cable Ø1.13, length 60mm
Weight (g)
11.46
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to + 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-15-8-022/A/WY Page 3 of 13
2.1
LNA
ELECTRICAL
Frequency
1558~1610 MHz.
Out of Band Attenuation
0-1534MHz, 13dB Min.
1634MHz-6000MHz, 20dB Min.
Output Impedance
50Ω
Output VSWR
2.0 Max
Pout at 1dB Gain
-6 dBm Min.
Compression Point
-2 dBm Typical
LNA Gain, Power Consumption and Noise Figure
Power Consumption(mA)
Voltage
LNA Gain(Typ)
Min 1.8V
22dB
5mA
3.0dB
Typ 3.0V
28dB
10mA
2.8dB
Max 5.5V
31dB
23mA
3.0dB
Typ
Noise Figure (Typ)
SPE-15-8-022/A/WY Page 4 of 13
3. LNA Gain and Noise Figure @3.0V
SPE-15-8-022/A/WY Page 5 of 13
4. Antenna Return Loss
BeiDou
GPS
GLONASS
SPE-15-8-022/A/WY Page 6 of 13
5. Antenna Radiation Properties
5.1
Test Setup
SPE-15-8-022/A/WY Page 7 of 13
5.2
2D Radiation Pattern
XY Plane
ZX Plane
SPE-15-8-022/A/WY Page 8 of 13
YZ Plane
5.3
3D Radiation Pattern
1561MHz
SPE-15-8-022/A/WY Page 9 of 13
1575.42MHz
1602MHz
SPE-15-8-022/A/WY Page 10 of 13
6. Plugs Usage Precautions
SPE-15-8-022/A/WY Page 11 of 13
7. Mechanical Drawing (Unit: mm)
Unit:mm
SPE-15-8-022/A/WY Page 12 of 13
8. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-15-8-022/A/WY Page 13 of 13
很抱歉,暂时无法提供与“AGGBP.25B.07.0060A”相匹配的价格&库存,您可以联系我们找货
