G30.B.108111
G30.B.108111
    TAOGLASLIMITED
    G30.B.108111
G30.B.108111 数据手册
SPECIFICATION Part Number: Product Name: G30.B.108111 Olympian Direct Mount Ultra Wide-Band 2G/3G/4G LTE/Cellular/CDMA and Wi-Fi Antenna For 2G/3G/4G Applications LTE/GSM/CDMA/DCS/PCS/WCDMA/UMTS/HSDPA/GPRS/EDGE/IMT 698 to 960MHz, 2.4GHz and 1710 to 2700MHz Features: Heavy duty screw mount UV and vandal resistant ABS housing and thread IP67 compliant Standard is 1M RG-316 SMA(M) Cables and Connectors Customizable RoHS Compliant SPE-12-8-149/H/AS Page 1 of 25 1. INTRODUCTION The G30 Olympian is a high performance screw mount wide-band cellular antenna for external use on vehicles and outdoor assets worldwide. Omni-directional high gain and high efficiency across all bands ensures constant reception and transmission. This is vital for today's high data bandwidth applications in video and mobile broadband. Durable UV resistant ABS housing is resistant to vandalism and direct attack. At only 48mm height it complies with the latest EU height restrictions directives for roof-mounted objects. This antenna is mounted on metal and plastic structures and is locked from the inside of the structure by a nut. Adhesive foam at the base provides a watertight seal to the mounting structure. High quality waterproof and corrosion resistant Teflon jacket RG316 is used for the cable. Two of these G30 separated at distance from each other are ideal for the latest LTE MIMO spatial diversity applications. Customized cable length and connectors are available. Taoglas recommend a minimum cable length of 70mm when used on a ground plane to achieve an efficiency of greater than 40% in the 900MHz band and greater than 60% in the 1800MHz band. For longer cable lengths and if 700MHz band is required, it is necessary to use the MA740 Pantheon for 2G/3G/4G or the MA741 2g/3G/4G MIMO Pantheon. SPE-12-8-149/H/AS Page 2 of 25 2. SPECIFICATION ELECTRICAL ANTENNA G30 STANDARD 2G/3G/4G/2.4GHz Operation Frequency (MHz) 700~960 MHz Peak Gain Average Gain Efficiency 1.2 dBi 1710~2170 MHz 3.2dBi 2.5dBi 1.5dBi -4.5 dB -2.5dB -4.5dB -4.5dB 40% 55% 40% 38% VSWR
G30.B.108111
物料型号: G30.B.108111
产品名称: Olympian Direct Mount Ultra Wide-Band 2G/3G/4G LTE/Cellular/CDMA和Wi-Fi天线
支持频段: 698至960MHz,1710至2700MHz,包括2.4GHz
特点: - 重型螺丝安装 - 耐紫外线和防破坏的ABS外壳和螺纹 - IP67防护等级 - 标准配置为1米长的RG-316 SMA(M)电缆 - 可根据需求定制电缆和连接器 - 符合RoHS标准
功能详解: - 适用于全球车辆和户外资产的高性能宽带蜂窝天线 - 所有频段的全向高增益和高效率,确保持续的接收和传输 - 耐用的UV抗性ABS外壳,可抵抗破坏和直接攻击 - 高质量的防水和耐腐蚀的特氟龙外套RG316用于电缆
应用信息: - 适用于最新的LTE MIMO空间多样性应用 - 可定制电缆长度和连接器
封装信息: - 尺寸:高48mm,直径50mm - 重量:66g - 安装扭矩推荐值:2.94N·m - 最大扭矩:3.92N·m
环境测试: - 保护等级:IP69K - 耐腐蚀性:5% NACI溶液中96小时 - 温度范围:-40°C至+85°C - 热冲击:100次循环,-40°C至+85°C - 湿度:65°C下95% RH非凝结 - 冲击测试:混凝土上1米跌落6轴 - 电缆拉力:8Kgf
测试设置和天线参数包括了回波损耗、VSWR、效率、峰值增益、平均增益和辐射模式的图表。
机械绘图提供了天线的顶视图和侧视图,以及组件的名称、部件号、材料、表面处理、数量等详细信息。
安装部分提供了推荐的安装扭矩。
包装信息说明了每个PE袋中包含1个G30天线,每箱125个天线,以及托盘的尺寸和箱数。
G30.B.108111 价格&库存
很抱歉,暂时无法提供与“G30.B.108111”相匹配的价格&库存,您可以联系我们找货
G30.B.108111
    • 1+456.82920
    • 200+182.28240
    • 500+176.19120
    • 1000+173.17800
    G30.B.108111
      G30.B.108111
      • 3+211.97946
      • 13+186.73344
      • 26+182.38068
      • 52+178.29392
      • 100+174.27971
      库存:6
      G30.B.108111
      • 2+411.628892+53.35494
      • 5+351.940395+45.61818
      • 10+258.3714210+33.48986
      • 25+247.5983525+32.09346
      • 50+246.9438250+32.00862
      库存:115
      G30.B.108111
      • 1+306.724521+39.75734
      • 10+249.1099610+32.28940
      • 30+232.2650830+30.10598
      • 100+220.69965100+28.60688
      G30.B.108111
