MagmaX
Part No:
AA.171.301111
Description:
MagmaX IP67 GPS/QZSS (L1), Galileo (E1), GLONASS (G1), BeiDou (B1)
External Automotive Antenna 3M RG-174 SMA(M)-SAW Filter
Features:
Magnetic Mount
Low Axial Ratio, less than 3
Covers:
• GPS/QZSS (L1)
• Galileo (E1)
• GLONASS (G1)
• BeiDou (B1)
Cable: 3m RG-174
Connector: SMA(M)
First Tier Automotive TS16949 Approved
Dimensions: 53mm*50mm*17mm
CE Certified
RoHS & Reach Compliant
SPE-15-8-002-F
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
7
4.
Radiation Patterns
11
5.
Active Characteristics
19
6.
Field Test Results
21
7.
Pull Force Test
22
8.
Mechanical Drawing
24
9.
Packaging
25
Changelog
26
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-15-8-002-F
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
The AA.171 MagmaX Low Axial Ratio Magma magnetic mount external GNSS antenna is ideal for robust,
covert installations where durability and small size is paramount. It is used in telematics and M2M
1.
applications, for example in commercial vehicle installations for fleet management.
Introduction
Typical Applications Include:
1.
Timing
Introduction
Telematics
Precision Positioning for Robotics / Automotive
Autonomous Routing
Standard cable and connector version is 3 meter RG174 and SMA(M). Cable length and connector type are
1.
Introduction
customizable upon request.
Using a unique specialist feed structure this antenna delivers best in class axial ratio across all GPS, GLONASS,
Galileo and BeiDou bands. Low axial ratio improves accuracy of GNSS system location and leads to quicker
lock times. A front-end SAW reduces out-band interference from any nearby wireless transmitters, helping
prevent LNA compression and burnout. Manufactured in a dedicated TS16949 facility, PPAP and IMDS
documentation are available on request. Low power consumption lengthens device battery life. Adhesive
mount version is available on request.
The cable and connector is fully customizable, contact your regional Taoglas customer support team for
further information.
SPE-15-8-002-F
www.taoglas.com
3
2.
Specifications
3.
GNSS Frequency Bands Covered
Antenna
Characteristics2.
Specifications
GPS
L1
L2
L5
GLONASS
3.
G1
G2
G3
Galileo
BeiDou
4.
E1
E5a
E5b
E6
B1
B2a
B2b
B3
Antenna Radiation
Patterns3.
Antenna
QZSS
(Regional)
L1
Characteristics2.
IRNSS
(Regional)
3.
L5
L6
L5
Antenna
Characteristics2.
SBAS
L1/E1/B1
L5/B2a/E5a
◼ GNSS Frequency Bands Covered.
4.
L2C
Specifications
3.
Specifications
G1
G2
G3
□ GNSS Frequency Bands Not Covered.
*SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5).
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Antenna
GNSS Bands and Constellations
Characteristics
4.
Characteristics2.
SPE-15-8-002-F
Specifications
www.taoglas.com
4
GNSS Electrical
Frequency (MHz)
BeiDou
GPS/Galileo
GLONASS
1559~ 1563
1563~ 1587
1593~ 1610
Efficiency (%)
on 30x30cm
ground plane
47.5
46.8
33.7
Average Gain (dB)
on 30x30cm
ground plane
-3.2
-3.3
-4.7
2.9
1.2
Peak Gain (dBi)
on 30x30cm
ground plane
3.1
Axial Ratio (dB) at zenith
on 30x30cm
ground plane
0.5
0.5
1
7.5
7.5
1.7
1.7
2
2
Group Delay
on 30x30cm
ground plane
7.5
PCO (cm)
on 30x30cm
ground plane
1.7
PCV (cm)
on 30x30cm
ground plane
2
Polarization
RHCP
Return Loss
< -7dB
Impedance
50 Ω
LNA and Filter Electrical Properties
Frequency (MHz)
1561
1575.42
1602
Gain@1.8V (Typ.)
21.14dB
21.36dB
21.01dB
Gain@3.0V (Typ.)
28.49dB
28.79dB
28.53dB
Gain@5.5V (Typ.)
29.86dB
30.18dB
29.9dB
Noise@1.8V (Typ.)
3.04dB
2.78dB
2.88dB
Noise@3.0V (Typ.)
2.83dB
2.51dB
2.73dB
Noise@5.5V (Typ.)
2.89dB
2.52dB
2.76dB
Current@1.8v(mA)
3.06mA
Current@3v(mA)
7.71mA
Current@5.5v(mA)
9.13mA
SPE-15-8-002-F
www.taoglas.com
5
Mechanical
Housing Dimensions
53*50*17mm
Housing Material
ABS
Cable
3m RG-174 (fully customizable)
Connector
SMA(M) (fully customizable)
Waterproof
IP67
Weight
92g
Magnetic Pull Force
Pull horizontal max pull force(kgf): 0.52
Pull vertical max pull force(kgf): 0.48
Environmental
Operation Temperature
-40°C ~ +85°C
Storage Temperature
-40°C ~ +90°C
RoHS Compliant
Yes
REACH Compliant
Yes
SPE-15-8-002-F
www.taoglas.com
6
3.
3.1
4.
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-15-8-002-F
www.taoglas.com
7
Average Gain
3.4
Peak Gain
dBi
3.3
SPE-15-8-002-F
www.taoglas.com
8
3.5
Axial Ratio @ 1561MHz
3.6
Axial Ratio @ 1575MHz
SPE-15-8-002-F
www.taoglas.com
9
3.7
Axial Ratio @ 1602MHz
SPE-15-8-002-F
www.taoglas.com
10
4.
4.
4.
Radiation Patterns
4.1
Test Setup – Free Space
Y
X
4.
Z
4.
4.
4.
4.
SPE-15-8-002-F
www.taoglas.com
11
4.2
Test Setup – on 30*30cm Ground Plane
Y
X
Z
SPE-15-8-002-F
www.taoglas.com
12
4.3
1561MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
13
4.4
1575.42MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
14
4.5
1602MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
15
4.6
1561MHz 3D and 2D Radiation Patterns – On 30*30cm Ground Plane
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
16
4.7
1575.42MHz 3D and 2D Radiation Patterns – On 30*30cm Ground Plane
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
17
4.8
1602 MHz 3D and 2D Radiation Patterns – On 30*30cm Ground Plane
XY Plane
SPE-15-8-002-F
XZ Plane
YZ Plane
www.taoglas.com
18
5.
6.
5.1
Block Diagram
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical
Drawing
6.
Packaging5.
6.
Packaging
5.2
Mechanical Drawing
LNA Gain @ 3V
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-002-F
Mechanical Drawing
www.taoglas.com
19
5.3
Block Diagram
SPE-15-8-002-F
www.taoglas.com
4.
Field Test Results
4. 6.1 Antenna
Patterns
RooftopRadiation
test
In this section Taoglas will present the field test result for AA.171 antenna. The test was performed when the
antenna was mounted on a static rooftop test set up in an open sky environment for at least 6 hours.
4.
Taoglas will show the field test results using the following receiver:
1. U-blox ZED-F9P
4.
Receiver features:
Antenna
Radiation Patterns
Multi-band GNSS: 184-channel GPS L1C/A L2C, GLONASS: L1OF L2OF, Galileo: E1B/C E5b, BeiDou: B1I B2I, QZSS: L1C/A L2C
4.
4.
4.
Multi-band RTK with fast convergence times and reliable performance
Nav. update rate RTK up to 20 Hz
Position accuracy = RTK 0.01 m + 1 ppm CEP
Positioning Accuracy Table (2D Accuracy)
Test
Condition
Correction
Service
CEP (50%)
DRMS (68%)
2DRMS (95-98.2%)
TTFF (sec)
30x30 cm
Ground
Plane
RTK DISABLED
77.22 cm
93.73 cm
187.47 cm
22
1.52 cm
3.04 cm
22
Antenna
Radiation1.26Patterns
RTK ENABLED
cm
Antenna Radiation PatternsRTK Availability
30x30 cm Ground Plane
4.
No RTK
Float
Fixed
SPE-15-8-002-F
www.taoglas.com
21
7.
6.
Pull Force Test (Units: mm)
7.1
Test Setup
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-002-F
Mechanical Drawing
www.taoglas.com
22
7.2
Horizontal Pull Force Breakdown
Horizontal Pull Force Breakdown: 0.52kgf
7.3
Vertical Pull Force Breakdown
Vertical Pull Force Breakdown: 1.23 kgf
SPE-15-8-002-F
www.taoglas.com
23
8.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-002-F
Mechanical Drawing
www.taoglas.com
24
9.
Packaging
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
SPE-15-8-002-F
www.taoglas.com
25
Changelog for the datasheet
SPE-15-8-002 – AA.171.301111
Revision: F (Current Version)
Date:
Changes:
Changes Made by:
2020-05-02
Field Test results Added
Victor Pinazo
Previous Revisions
Revision: E
Date:
Changes:
Changes Made by:
2020-02-25
New Template and RTK Data
Jack Conroy
Revision: D
Date:
Changes:
2018-11-09
New Drawing
Changes Made by:
Sean Hancox
Revision: C
Date:
Changes:
2018-04-04
New Packaging
Changes Made by:
Carol Faughnan
Revision: B
Date:
Changes:
Changes Made by:
2020-05-02
Aine Doyle
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-15-8-002-F
2015-01-14
Initial Datasheet Release
Aine Doyle
www.taoglas.com
26
www.taoglas.com
© Taoglas
SPE-15-8-002-F
www.taoglas.com
27
很抱歉,暂时无法提供与“AA.171.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+813.75840
- 200+324.70200
- 500+313.84800
- 1000+308.49120
- 国内价格 香港价格
- 1+652.631551+84.59348
- 10+541.2783810+70.15999
- 30+508.7499330+65.94368
- 100+482.93326100+62.59735
- 国内价格 香港价格
- 1+603.590411+78.23681
- 10+424.8797210+55.07250
- 30+420.6673730+54.52650
- 100+420.42435100+54.49500
