Specification
Part No.
Shockwave TL.10.1HH11
Product Name
Wideband Direct Mount antenna
Covers all common
2G/3G/4G Cellular - ISM- Wi-Fi Bands
Feature
LTE / GSM / CDMA /DCS /PCS / WCDMA / UMTS / HSDPA
/ GPRS / EDGE /GPS /Wi-Fi
698MHz to 960MHz, 1575.42MHz,
1710MHz to 2700Mhz,
Highest Efficiency and Peak Gain –up to 90%
IP67 Waterproof and IP69K
NMO (M) Connector
RoHS Compliant
Shockwave TL.10 with Magnetic
Mount Assembly
Shockwave TL.10 with Direct Mount Assembly
SPE-13-8-048/D/WY
Page 1 of 24
1.
Introduction
The Shockwave TL.10 NMO series is a new generation of antenna, one part number
that is a highly efficient, high gain omni-directional permanent mount antenna
designed for all common Cellular, Wi-Fi and ISM bands worldwide. It is specially
designed for easy and cost effective vandal-proof and waterproof mounting
requirements on meters, terminal boxes, and heavy equipment and vehicles.
In installation, the antenna connects to a NMO Mount connector jutting out from
a metal panel. A unique indent tab on the base itself on the antenna allows a
wrench to be used to solidly lock the antenna on top of its mounting location, thus
preventing removal by hand later by vandals, but crucially allowing for
replacement antenna to be installed by qualified personnel in the future without
the need to open the device or box it is mounted on itself. A waterproof O-ring
around the bottom outer edge prevents water leaking under the antenna.
The antenna is IP67 waterproof and IP69K resistant against high pressure water
jets in commercial cleaning environments, incorporating highest quality stainless
steel mounting base ensuring corrosion resistance.
The Shockwave TL.10 has been tested on a variety of mounting conditions as
below specification, with excellent efficiency and gain measured in all typical
common mounting conditions. Radiation patterns are consistent, and show very
good stability in the azimuth on lower and upper bands.
Housing, frequency application, mounting type and connector are customizable,
subject to minimum order quantities. Please contact your local Taoglas sales office
for more information. The antenna also comes in White as standard.
SPE-13-8-048/D/WY
Page 2 of 24
2.
Specification
ELECTRICAL
Frequency (MHz)
698~800 824~960 1575.42 1710 ~ 1880 1850 ~ 1990 1920 ~ 2170 2400~2700
Peak Gain (dBi)
Free Space
-1.7
-0.9
0.8
1.3
1.3
1.7
3.5
10x10cm GP center
-1.3
0.1
0.3
0.1
0.4
0.5
2.3
30x30cm GP center
2.7
2.5
1.0
2.2
2.1
2.2
3.1
50x50cm GP center
2.6
2.5
1.2
3.1
3.2
3.1
2.8
Average Gain (dBi)
Free Space
-6.6
-5.1
-1.8
-1.5
-1.5
-1.3
-0.9
10x10cm GP center
-3.1
-1.9
-1.9
-2.1
-2.0
-1.9
-1.4
30x30cm GP center
-0.4
-1.1
-1.6
-1.7
-1.3
-1.3
-1.6
50x50cm GP center
-0.3
-1.0
-1.6
-1.2
-0.8
-0.9
-1.6
Efficiency
Free Space
22%
31%
64%
69%
69%
72%
80%
10x10cm GP center
48%
63%
63%
60%
63%
63%
71%
30x30cm GP center
90%
76%
67%
67%
73%
73%
69%
50x50cm GP center
91%
78%
68%
75%
83%
81%
68%
Impedance
50Ω
Polarization
Vertical
Radiation Pattern
Omni
Max. Input Power
5W
MECHANICAL
Casing
PC+PBT
Connector
NMO
Base
Stainless Steel
Weight
180g
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-13-8-048/D/WY
Page 3 of 24
LTE BANDS
LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Band Number
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
SPE-13-8-048/D/WY
Covered
Page 4 of 24
3.
Antenna Characteristics
3.1 Return Loss
3.2 Maximum Gain
SPE-13-8-048/D/WY
Page 5 of 24
3.3 Average Gain
3.4 Efficiency
SPE-13-8-048/D/WY
Page 6 of 24
4. Antenna Radiation Patterns
4.1 Antenna setup (Free Space)
Y
Z
X
SPE-13-8-048/D/WY
Page 7 of 24
4.1.1 Radiation Patterns
XY Plane
X
Y
X
Y
SPE-13-8-048/D/WY
Page 8 of 24
X
Y
XZ Plane
Z
10
30
300
60
-20
-30
270
90
-40
X
704MHz
751MHz
240
120
824MHz
880MHz
210
150
180
960MHz
(dBi)
SPE-13-8-048/D/WY
Page 9 of 24
Z
10
30
300
60
-20
-30
270
90
-40
X
1710MHz
240
120
1880MHz
1990MHz
210
150
180
2170MHz
(dBi)
Z
X
SPE-13-8-048/D/WY
Page 10 of 24
4.2 Antenna setup (10x10cm Metal Ground Plane)
Y
X
Z
4.2.1 Radiation Patterns
XY Plane
X
10
30
300
60
-20
-30
270
90
-40
Y
704MHz
240
120
751MHz
824MHz
210
150
180
880MHz
960MHz
(dBi)
SPE-13-8-048/D/WY
Page 11 of 24
X
330
30
300
60
-20
-30
270
90
-40
240
120
Y
1710MHz
1880MHz
210
1990MHz
150
180
2170MHz
(dBi)
X
330
30
300
60
-20
-30
270
90
-40
Y
2300MHz
240
120
2500MHz
2570MHz
210
150
180
2700MHz
(dBi)
SPE-13-8-048/D/WY
Page 12 of 24
XZ Plane
Z
330
30
300
60
-20
-30
270
90
-40
X
704MHz
751MHz
240
120
824MHz
880MHz
210
150
180
Z
960MHz
(dBi)
330
30
300
60
-20
-30
270
90
-40
X
1710MHz
240
120
1880MHz
1990MHz
210
150
180
2170MHz
(dBi)
SPE-13-8-048/D/WY
Page 13 of 24
Z
330
30
300
60
-20
-30
270
90
-40
X
2300MHz
240
120
2500MHz
2570MHz
210
150
180
2700MHz
(dBi)
4.3 Antenna setup (30x30cm Metal Ground Plane)
Y
X
Z
SPE-13-8-048/D/WY
Page 14 of 24
4.3.1 Radiation Patterns
XY Plane
X
330
30
300
60
-20
-30
270
90
-40
Y
704MHz
240
120
751MHz
824MHz
210
880MHz
150
180
X
960MHz
(dBi)
330
30
300
60
-20
-30
270
90
-40
240
120
Y
1710MHz
1880MHz
210
150
180
1990MHz
2170MHz
(dBi)
X
SPE-13-8-048/D/WY
Page 15 of 24
330
30
300
60
-20
-30
270
90
-40
Y
2300MHz
240
120
2500MHz
2570MHz
210
150
2700MHz
180
(dBi)
SPE-13-8-048/D/WY
Page 16 of 24
XZ Plane
Z
330
30
300
60
-20
-30
270
90
-40
X
704MHz
751MHz
240
120
824MHz
880MHz
210
150
180
Z
960MHz
(dBi)
330
30
300
60
-20
-30
270
90
-40
X
1710MHz
240
120
1880MHz
1990MHz
210
150
180
2170MHz
(dBi)
SPE-13-8-048/D/WY
Page 17 of 24
Z
330
30
300
60
-20
-30
270
90
-40
X
2300MHz
240
120
2500MHz
2570MHz
210
150
180
2700MHz
(dBi)
4.4 Antenna setup (50x50cm Metal Ground Plane)
Y
X
Z
SPE-13-8-048/D/WY
Page 18 of 24
4.4.1 Radiation Patterns
XY Plane
X
330
30
300
60
-20
-30
270
90
-40
Y
704MHz
240
120
751MHz
824MHz
210
880MHz
150
180
X
960MHz
(dBi)
330
30
300
60
-20
-30
270
90
-40
240
120
Y
1710MHz
1880MHz
210
150
180
1990MHz
2170MHz
(dBi)
SPE-13-8-048/D/WY
Page 19 of 24
X
330
30
300
60
-20
-30
270
90
-40
Y
2300MHz
240
120
2500MHz
2570MHz
210
150
180
XZ Plane
2700MHz
(dBi)
Z
330
30
300
60
-20
-30
270
90
-40
X
704MHz
751MHz
240
120
824MHz
880MHz
210
150
180
960MHz
(dBi)
SPE-13-8-048/D/WY
Page 20 of 24
Z
330
30
300
60
-20
-30
270
90
-40
X
1710MHz
240
1880MHz
120
1990MHz
210
150
180
Z
2170MHz
(dBi)
330
30
300
60
-20
-30
270
90
-40
X
2300MHz
240
120
2500MHz
2570MHz
210
150
180
2700MHz
(dBi)
SPE-13-8-048/D/WY
Page 21 of 24
5. Mechanical Drawing (Unit: mm)
Name
Material
Finish
Quantity
1
Antenna Top
PC + PBT
Black
1
2
Antenna Bottom (NMO Connector)
SUS
N/A
1
3
O-Ring
NBR
Red
1
4
PIN
Brass
Gold
1
SPE-13-8-048/D/WY
Page 22 of 24
6. Installation
Recommended torque for mounting is 95Nm or 70ft lbs
Maximum torque for munting is 135.6Nm or 100ft lbs
40mm wrench or 1-9/16” wrench can be used
SPE-13-8-048/D/WY
Page 23 of 24
7. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this
document and reserves the right to make changes to specifications and product descriptions at any
time without notice. Taoglas reserves all rights to this document and the information contained
herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-13-8-048/D/WY
Page 24 of 24
很抱歉,暂时无法提供与“TL.10.1HH11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+300.07450
- 8+294.59727
- 15+289.02332
- 30+283.44937
- 50+277.87542
- 国内价格
- 2+432.98074
- 8+382.52941
- 15+375.23481
