SPECIFICATION
Part No.
MA.301.A.AB.001
Product Name
MA.301 GPS/Penta-band Cellular Magnetic
Antenna
Features
IP65 - Waterproof
GPS - High gain LNA up to 32dB
Penta-band 850/900/1800/1900/2100 MHz
GSM/CDMA/PCS/DCS/UMTS/HSPA
Low Profile
Height 10.8mm Diameter 55.1mm
RoHS Compliant
3D view
(This side faces the sky)
Underside View
(Magnet)
SPE-11-8-131/D/SS
Page 1 of 11
MA.301.A.A301111.B301111
1. Introduction
The MA.301 is a combination small form factor high performance GPS and
Penta-band Cellular (GSM/CDMA/PCS/DCS/ WCDMA/UMTS) antenna to
simplify AVL or Fleet management antenna systems worldwide. It comes
with magnet mount as standard. An internal O-ring meets IP-65
waterproof standards. With the strongest GPS and Cellular antenna design
team in the industry and rigorous testing Taoglas offers guaranteed
performance with your system and your environment.
The standard version comes with 3 metres RG174 cable and SMA(M)
connectors for both GPS and Cellular feeds. Cables and connectors are
customizable upon request.
2. Features
GPS
High LNA Gain up to 32 dB
Antenna Gain 28 ± 2 dB
Miniaturized to 56.3 x 17.3 mm
Low Noise 1.5 dB max
Ultra-Low Power Consumption 6mA typ ( at 2.7V~3.3V dc)
Cellular
Advanced penta-band cellular antenna
(GSM/CDMA/PCS/DCS/WCDMA/UMTS)
Other
IP65 Water Resistant due to Internal O-Ring Structure
Quality textured covert design. Low profile
UV resistant ABS housing
Optional - high grade 3M double sided tape for quick and
easy mounting
Optional cables and connectors
ROHS Compliant
SPE-11-8-131/D/SS
Page 2 of 11
3. Performance Specifications
Items
GPS Antenna
Features
High performance GPS
ceramic patch antenna
with cutting edge low
noise amplifier
Frequency
Gain
Noise Figure
Polarization
Bandwidth
VSWR
Impedance
Power
Consumption
Cable / Connector
Operating
Temperature
Storage
Temperature
Size
1575.42 MHz ± 2MHz
28 dB typ.
Gain at Zenith
:-3
dBi min
Axial Ratio :
3.0
dB typ
1.5 dB max.
RHCP
10 MHz min @ -10dB
1.92 max
50Ω
6mA ( at 2.7 ~ 3.3V
dc)
Standard 2/3/5m RG174 Cables and
Connectors Fully
Customisable
Cellular Antenna
CDMA: 824~896 MHz
GSM: 880~960 MHz
PCS: 1850~1990 MHz
DCS: 1710~1880 MHz
UMTS/WCDMA
As above
As patterns
Linear
As S11
很抱歉,暂时无法提供与“MA301.A.AB.001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+244.90325
- 15+235.48436
- 40+226.42820
- 150+217.72268
- 350+209.37989
- 国内价格
- 2+378.38502
- 15+327.45456
- 40+314.76986
- 150+302.70802
