WS.01
on ground-plane
Hercules
WS.01.B.305151
Specification
Part No.
WS.01.B.305151
Product Name
Hercules
Heavy Duty Screw Mount Antenna
Dual-Band 2.4~5.2GHz
Feature
2.4GHz~5.2GHz suitable for
ISM Bands/ZigBee/WLAN/Bluetooth
IEEE.802.11/IEEE.802.15
UV and Vandal Resistant ABS Housing
IP67 & IP69K Waterproof Rating
3M NFC-200 RP-SMA(M) – Standard
RoHS Compliant
SPE-13-8-018/C/SS |
page 1 of 13
1. Introduction
WS.01 Hercules is a high efficiency, high gain thread mount dual band wireless antenna for external use on vehicles and outdoor assets
worldwide. Omni-directional gain across both bands ensures constant reception and transmission making the WS.01 an ideal solution for
a Zigbee Wireless Mesh for remote applications e.g. – remote metering.
It has been designed for heavy duty work with extra thick threads; with durable UV-resistant PVC housing is resistant to vandalism and
direct attack. At only 29mm high it complies with the latest EU height restrictions directives for roof-mounted objects, whilst also enabling
covert operation with a diameter of 49mm.
The antenna housing is completely waterproof to IP67, and also to IP69K, which means it is waterproof against high pressure water jets
used in industrial environments for cleaning.
SPE-13-8-018/C/SS |
page 2 of 13
2. Specifications
ELECTRICAL
Frequency (GHz)
2.4
2.45
2.5
5.15
5.25
5.35
VSWR
1.46
1.66
1.6
1.76
1.41
1.48
Return Loss (dB)
-14.5
-12.1
-12.7
-11.1
-15.3
-14.2
Impedance
50Ω
Polarization
Linear - Horizontal
Radiation Pattern
Omni
Cable/Connectors
3M NFC-200/RP-SMA(M)
Recommended Mounting
24.5N·m
Torque
29.4N·m
Maximum Mounting Torque
MECHANICAL
Dimensions
Height 29mm x Diameter 49mm
Casing
UV resistant PC
Base and thread
Nickel plated steel
Thread diameter
18mm
Weather proof gasket
CR4305 foam with 3M9448B double-side adhesive
ENVIRONMENTAL
Waterproof
IP67 & IP69K
Corrosion
5% NaCl for 96hrs - Nickel plated steel base and thread
Temperature Range
-40°C to +85°C
Thermal Shock
100 cycles -40°C to +80°C
Humidity
Non-condensing 65°C 95% RH
Shock (drop test)
1m drop on concrete 6 axes
Cable pull
8 Kgf
SPE-13-8-018/C/SS |
page 3 of 13
3. Antenna S11 Parameters
3.1 Return Loss
Tr1
S11 Log Mag 5.000dB / Ref 0.000dB [F1]
10.00
1
2
3
4
5
>6
5.000
0.000
2.4000000 GHz
2.4500000 GHz
2.5000000 GHz
5.1500000 GHz
5.2500000 GHz
5.3500000 GHz
-14.535 dB
-12.100 dB
-12.660 dB
-11.145 dB
-15.255 dB
-14.186 dB
-5.000
1
-10.00
-15.00
6
4
2
3
1
5
-20.00
-25.00
-30.00
-35.00
-40.00
2 Start 1 GHz
IFBW 70 kHz
Stop 8 GHz Cor !
SPE-13-8-018/C/SS |
page 4 of 13
3.2 VSWR
Tr1
S11 SWR 1.000 / Ref 1.000 [F1]
11.00
1
2
3
4
5
>6
10.00
9.000
2.4000000 GHz
2.4500000 GHz
2.5000000 GHz
5.1500000 GHz
5.2500000 GHz
5.3500000 GHz
1.4619
1.6616
1.6070
1.7671
1.4179
1.4856
8.000
7.000
6.000
5.000
4.000
3.000
1
2.000
1.000
2 Start 1 GHz
6
4
23
1
5
IFBW 70 kHz
Stop 8 GHz Cor
SPE-13-8-018/C/SS |
page 5 of 13
4. Antenna Radiation
4.1 3D Radiation Pattern
Y
Z
X
SPE-13-8-018/C/SS |
page 6 of 13
2.4GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
2.45GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
SPE-13-8-018/C/SS |
page 7 of 13
2.5GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
5.15GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
SPE-13-8-018/C/SS |
page 8 of 13
5.25GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
5.35GHz
5
GAIN (dBi)
-10
-20
-30
-40
-50
SPE-13-8-018/C/SS |
page 9 of 13
4.2 Result Summary
Channel
2400
2450
2500
5150
5250
5350
Note
Ant. Port Input Pwr. (dBm)
Tot. Rad. Pwr. (dBm)
Peak EIRP (dBm)
-1.61782
-1.77651
-3.01447
-3.8051
-3.23583
4.71773
3.0513
4.05447
4.1152
4.7407
4.37813
Directivity (dBi)
5.03891
5.67229
5.89171
7.75517
8.18322
7.95356
Efficiency (dB)
-1.98761
-1.61782
-1.77651
-3.01447
-3.8051
-3.23583
Efficiency (%)
63.276
68.8997
66.4276
49.952
41.638
47.4698
Gain (dBi)
3.0513
4.05447
4.1152
4.7407
4.37813
4.71773
NHPRP ±Pi/4 (dBm)
-3.25016
-2.86259
-3.02232
-4.67614
-5.69757
-5.29538
NHPRP ±Pi/6 (dBm)
-4.39266
-4.02363
-4.19465
-6.60698
-7.70604
-7.19484
NHPRP ±Pi/8 (dBm)
-5.32364
-5.01353
-5.19258
-7.87659
-8.98205
-8.37507
Upper Hem. PRP (dBm)
-6.08301
-5.80993
-5.86805
-7.71601
-8.71586
-8.08409
Lower Hem. PRP (dBm)
-4.13045
-3.70008
-3.92182
-4.81064
-5.49788
-4.95872
NHPRP4 / TRP Ratio (dB)
-1.26255
-1.24477
-1.2458
-1.66167
-1.89247
-2.05955
74.773
75.0798
75.062
68.2076
64.6774
62.2365
-2.40505
-2.4058
-2.41814
-3.59251
-3.90094
-3.95901
NHPRP4 / TRP Ratio (%)
NHPRP6 / TRP Ratio (dB)
NHPRP6 / TRP Ratio (%)
57.4771
57.4672
57.3041
43.7269
40.7292
40.1882
NHPRP8 / TRP Ratio (dB)
-3.33604
-3.39571
-3.41607
-4.86212
-5.17695
-5.13924
46.387
45.754
45.54
32.6428
30.3602
30.625
UHPRP / TRP Ratio (dB)
-4.0954
-4.19211
-4.09154
-4.70155
-4.91076
-4.84826
UHPRP / TRP Ratio (%)
38.9457
38.0881
38.9804
33.8723
32.2793
32.7472
LHPRP / TRP Ratio (dB)
-2.14284
-2.08226
-2.1453
-1.79617
-1.69279
-1.7229
LHPRP / TRP Ratio (%)
61.0543
61.9119
61.0196
66.1277
67.7207
67.2528
Front/Back Ratio (dB)
3.42725
3.56765
3.94055
10.1253
13.1799
10.9587
NHPRP8 / TRP Ratio (%)
Phi BW (°)
112
96
86
42
40
42
+ Phi BW (°)
66
58
52
17
19
24
- Phi BW (°)
46
38
34
25
21
18
Theta BW (°)
49
35
35
36
34
32
+ Th. BW (°)
25
23
23
12
- Th. BW (°)
24
15
11
13
11
Boresight Phi (°)
270
270
270
75
75
60
Boresight Th. (°)
105
105
105
135
135
150
Maximum Power (dBm)
3.0513
4.05447
4.1152
4.7407
4.37813
4.71773
Minimum Power (dBm)
-15.0552
-14.2956
-14.3893
-15.5291
-16.4014
-15.3489
Average Power (dBm)
-2.26887
-1.84221
-2.02397
-3.4037
-4.13521
-3.4448
Max/Min Ratio (dB)
18.1065
18.3501
18.5045
20.2699
20.7795
20.0666
Max/Avg Ratio (dB)
5.32018
5.89668
6.13917
8.14441
8.51333
8.16253
Max/Avg Ratio (dB)
-12.7863
-12.4534
-12.3653
-12.1254
-12.2662
-11.9041
Average Gain (dB)
-1.98761
-1.61782
-1.77651
-3.01447
-3.8051
-3.23583
E-Plane BW (°)
45
33
34
32
31
35
+ E-Plane BW (°)
22
19
- E-Plane BW (°)
25
15
12
13
11
23
H-Plane BW (°)
115
105
93
51
45
39
+ H-Plane BW (°)
69
70
65
16
16
- H-Plane BW (°)
46
35
28
35
29
19
SPE-13-8-018/C/SS | page 10 of 13
5. Technical Drawing
SPE-13-8-018/C/SS | page 11 of 13
6. Installation
Recommended torque for mounting is 24.5N·m
Maximum torque for mounting is 29.4N·m
SPE-13-8-018/C/SS | page 12 of 13
7. Packaging
1pc antenna per big PE Bag
10 big PE bags per box
Unit : mm
Taoglas makes no warranties based on the
accuracy or completeness of the contents
of this document and reserves the right to
make changes to specifications and
product descriptions at any time
without notice. Taoglas reserves all
rights to this document and the
information contained herein.
Reproduction, use or disclosure to third
parties without express permission is
strictly prohibited.
Copyright © Taoglas Ltd.
SPE-13-8-018/C/SS | page 13 of 13
很抱歉,暂时无法提供与“WS.01.B.305151”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+371.88296
- 8+357.57930
- 30+343.81974
- 70+330.59219
- 国内价格
- 2+565.46940
- 8+489.28932
- 30+470.41199
