TW2410/TW2412
TW2410 and TW2412 Single Band GNSS Antennas
Frequency Coverage: L1/G1
Overview
The TW2410 and TW2412 antennas employ Tallysman’s
unique Accutenna technology, covering the GPS L1,
GLONASS G1 frequency bands, as well as SBAS (WAAS,
QZSS, EGNOS & MSAS, 1557MHz to 1606MHz).
Designed for precision industrial, agricultural and
military OEM applications the TW2410 and TW2412
provide a truly circular response over its entire
bandwidth thereby producing superior multipath signal
rejection.
With a low axial ratio, excellent phase linear response
and a tight phase centre variation, the TW2410 and
TW2412 provide the performance normally associated
with premium-priced antennas.
Each antenna also features a dual-feed wideband patch
element, with one Low Noise Amplifier (LNA) per feed, a
mid section combiner and SAW filter, and a final output
gain stage.
Differing from the TW2410, only by an added pre-filter
option, the TW2412 provides extra protection against
saturation by strong near frequency or harmonic
signals, such as LTE.
The TW2410 and TW2412 are housed in a compact,
industrial-grade weatherproof enclosure, and are
available with a variety of connectors and cable lengths.
They can be ordered with a choice of a magnet mount,
adhesive mount, direct screw mount, or a plastic plug
that provides a smooth mounting surface.
Applications
Features
Benefits
• High Accuracy & Mission Critical GNSS
• Precision Agriculture, Mining &
Construction
• Military & Security
• Avionics
• Law Enforcement & Public Safety
• Fleet Management & Asset Tracking
• Great axial ratio: 1640 MHz >35 dB
Gain ������������������������������������������� 28 dB min.
Noise Figure ��������������������������� 1.5dB typ.
Pre-filtered
50 dB
50 dB
>1640 MHz >70 dB
28 dB min.
3.5dB typ.
Gain Flatness ������������������������� +/- 2 dB
VSWR �����������������������������������������
很抱歉,暂时无法提供与“33-2410-00-5000”相匹配的价格&库存,您可以联系我们找货
