AA.160.301111
AA.160.301111
    TAOGLASLIMITED
    AA.160.301111
AA.160.301111 数据手册
Topside View Underside View AA.160.301111 Specification Part No. AA.160.301111 Product Name Magnet Mount GPS-GLONASS Antenna Feature 1575MHz – 1609MHz Custom cables and connectors available RoHS Compliant SPE-12-8-029/B/SS | page 1 of 7 1. Introduction This antenna is designed for applications which require high positioning accuracy by combining signals from GPS and Glonass systems. High gain wide-band patch antenna on a large integral ground delivers maximum performance. 2. Specification 2.1 Ceramic Patch Antenna 36*36*6mm Parameter Specification Frequency 1575-1609MHz Bandwidth 40MHz min. VSWR 1.5:1 Peak Gain 4.0dBic (70*70mm Ground Plane) Impedance 50Ω Polarization RHCP 2.2 Low Noise Amplifier Parameter Specification Noise Figure 1.5dB typ. Output VSWR 1 3 4 4 2 1 3 CH2 Markers 2: 48.057 Ω 13.596 mΩ 1.59527 GHz 2 Cor 3: 95.949 Ω -4.6445 Ω 1.56794 GHz 4: 26.038 Ω 2.2139 Ω > 1.62259 GHz CENTER 1 595.000 000 MHz SPAN 200.000 000 MHz SPE-12-8-029/B/SS | page 4 of 7 4. S21/S22 Performance Comparison (LNA) CH1 S22 SWR CH2 S21 LOG 1 / REF 1 1: 1.0779 10 dB / REF 0 dB 1 575.420 000 MHz 1: 31.779dB * PRm Cor 1. 57542 GHz CH1 Markers 2: 1.225 1.60900 GHz 3: 1.7211 1.47500 GHz 4: 1.4717 1.67500 GHz 5: 1.5097 1.70000 GHz 1 2 > 3 4 PRm Cor > 5 3 CENTER 1 575.420 000 MHz 1 4 2 CH2 Markers 2: 32.163 dB 1.60900 GHz 3: 12.635 dB 1.47500 GHz 4:-.12150 dB 1.67500 GHz 5:-17.193 dB 1.70000 GHz 5 SPAN 250.000 000 MHz SPE-12-8-029/B/SS | page 5 of 7 A 5. Drawing ALL Initial Design Top Sandy 2012/01/12 Bottom Side GPS Antenna Frequency : 1575. 42MHz GLONASS Antenna Frequency : 1602MHz Voltage : 3V~5V XX YY SMA(M) "A" WW Finish QTY 1 AA.160 AntennaHousing Housing Top 1 AA.160 Antenna Top 000112A000028A ABS+PC ABS+PC 1 Black Black 1 2 2 AA.160 AA.160 AntennaHousing Housing Bottom Antenna Bottom 000112A010028A ABS+PC ABS+PC 1 Black Black 1 3 3 AA.160 AA.160 Sticker Sticker 001012A010028A Terylene Terylene 1 Silver Silver 1 4 4 Heat Heat Shrink Tube Shrink Tube PE 001311F0000XXA PE Black 1 Black 1 Spec Finish QTY Gold 1 Name Name P/N Material Name WW WW XX YY YY Connector Type Cable Type Cable Length Cable Type Material QTY P/N Connector Type Name XX Cable Length Finish P/N SMA.M.ST.PLUG.D.WS Spec SMA.M.ST.PLUG.D.WS 301311F0000XXA 301311F0000XXA SMA(M) SMA(M) Finish 3000±30mm RG174 Gold 3000±30mm RG174 QTY 1 1 Black Black Carton 23t 1 1 1 TW Design Centre This drawing and its inherent design concepts are property of Taoglas. Not to be copied or given to third parties without the written consent of Taoglas. SPE-12-8-029/B/SS | page 6 of 7 5 包裝規格 5.1 每個小 PE 袋放置 1 天線 【1pcs antenna per small PE bag】 5.2 每個 Box 放置 1 個小 PE 袋,如下圖所示 6. Packaging 【1 small PE bags per Box】 5.3 封口時須注意不可壓到天線,裝入需平整不可雜亂 【Antenna should be placed flat and neat in the PE bag. Hot seal the PE bag without pressing or damage the antenna.】 5.4 清點每袋數量不可短缺 Carton 23t 1pcs antenna per small PE bag in each PE bag】 1【Confirm small PE bagthe per quantity box AA.160 小 PE 袋 Box Taoglas makes no warranties based on the product descriptions at any time accuracy or completeness of the contents without notice. Taoglas reserves all UNLESS OTHER SPECIFIED TOLERANCES ON: of this document and reserves the right to rights to this document and the X=± make changes X.X=± X.XX= to specifications and information contained herein. ANGLES=± HOLEDIA=± SCALE: xxxx UNIT:mm DRAWN BY: jason CHECKED BY: Jimmy DESIGNED BY: Jimmy APPROVED BY: jimmy Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-029/B/SS | DOCUMENT PAGE page 7 of 7 REV.
AA.160.301111 价格&库存
很抱歉,暂时无法提供与“AA.160.301111”相匹配的价格&库存,您可以联系我们找货
