WM.90.A305111
WM.90.A305111
    TAOGLASLIMITED
    WM.90.A305111
WM.90.A305111 数据手册
SPECIFICATION Part No. : WM.90.A.305111 Product Name : Wall Mount Flexible Whip Monopole High Gain 2G/3G/4G Wide-band Cellular Antenna Feature : 698-960MHz/1710-2690MHz Unique - High peak gain on all bands Wide-band High efficiency Flexible Inner Steel Core Whip Completely IP67, Robust Structure, Aesthetic 3M CFD-200 SMA(M)ST Cable is hidden internally RoHS compliant SPE-11-8-025/E/WY Page 1 of 18 1. Introduction The WM.90 wall mount flexible whip monopole has high performance on all common 2G/3G/4G bands used worldwide. Taoglas specifications are compiled completely from real-life testing in state of the art CTIA approved 3D anechoic chambers. Peak gain, average gain/efficiency are both optimized to provide extended coverage area in the azimuth (horizontal direction), while also maintaining an Omni-directional pattern for close in reception/transmission. Testing of the whip antenna on the bracket, in free-space, and on a reference ground-plane has been done to show the benefit of the L-bracket. This antenna delivers wider coverage areas and more reliable connections for professional customers in the automotive, industrial industries. The whip is made up of a flexible inner steel core covered by TPU so extremely resistant to collisions and maintaining its original shape and RF performance. The whip and the connection internally to the bracket is completely IP67 waterproof. The bracket allows complete concealment of the cable for a more secure integration and cleaner installation. The cable can also be routed out of the back wall of the bracket into the interior of the mounting wall for added security against vandalism. The standard version comes with 3 metres extremely low loss CFD200 (0.3dB against 0.7dB for RG58) to allow for flexibility of placement. The cable and connector can be completely customized, the whip itself can also be changed for different frequency bands or gain requirements. SPE-11-8-025/E/WY Page 2 of 18 2. Specification CELLULAR Frequency (MHz) 698 ~ 798 824 ~ 896 880 ~ 960 Free Space -2.11 -1.30 On 30cm*30cm GND -2.75 -0.84 2.02 L - Bracket -1.11 2.53 1.80 Free Space -6.30 -5.33 On 30cm*30cm GND -5.76 -4.62 -3.03 L - Bracket -5.58 -2.33 Free Space 23.49 On 30cm*30cm GND 1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 2570 ~ 2690 3.35 2.83 3.45 4.65 5.09 4.55 4.65 1.81 2.23 2.22 1.80 Average Gain (dBi) -4.59 -1.85 -1.51 -1.73 -2.13 -1.73 -1.44 -1.69 -1.84 -2.44 -2.71 -3.03 -2.75 -2.88 29.32 Efficiency (%) 35.08 65.41 70.84 67.30 61.58 26.60 34.93 50.32 67.30 71.81 67.94 65.54 L - Bracket 27.92 58.66 57.15 53.86 49.86 53.24 51.59 Return Loss (dB)
WM.90.A305111 价格&库存
很抱歉,暂时无法提供与“WM.90.A305111”相匹配的价格&库存,您可以联系我们找货
