2-in-1 Ultima
Part No:
MA111.C.LB.001
Description:
MA111 Ultima Series – 2-in-1 Super Low-Profile Combination
GPS/GLONASS/BeiDou/Galileo and Cellular Permanent Mount Antenna
Features:
Height: 19.6mm (0.77”)
Diameter: 55mm (2.17”)
Heavy duty Permanent Mount
UV and vandal resistant ABS housing and thread
IP67 Rated Waterproof
Cable: 3m RG-174 GNSS, 3m CFD-200 Cellular
Connector: SMA(M)ST
RoHS & Reach Compliant
SPE-13-8-040-C
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
8
4.
Active Antenna Characteristics
13
5.
Radiation Patterns
17
6.
Mechanical Drawing
39
7.
Installation
40
8.
Packaging
41
9.
Application Note
42
Changelog
45
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-040-C
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The MA111 Ultima Series 2-in-1 GPS/GLONASS/BeiDou/Galileo & Cellular Combination Antenna is an
extremely low-profile combination high performance GPS/GLONASS/BeiDou/Galileo and cellular antenna
solution for professional telematics applications. At only 22 mm height it is one the lowest profile antennas
in the market, with a diameter of 55 mm. It is designed to be mounted and couple to the metal structures it
attaches to radiate. Durable UV ABS housing, thread and nut is resistant to vandalism and direct attack.
Introduction
Typical Applications Include:
- Asset Tracking
- Digital Signage
- Smart Metering
Introduction
The IP67 waterproof robust plastic body makes it extremely light, economical for shipping and minimum
weight impact on vehicles. This also makes it ideal for use in humid environments such as water pits or marine
applications as there are no external metal parts to corrode. The closed cell foam with double-sided adhesive
provides a permanent waterproof seal and can adjust to different curvatures, stopping water from leaking
under the antenna into the mounting hole.
Introduction
For applications that require mounting on non-metal structures we recommend the Hercules MA105. The
cables and connectors are fully customizable, contact your regional Taoglas Customer support teams for
more information.
SPE-13-8-040-C
www.taoglas.com
3
2.
Specifications
3.
GNSS Frequency Bands Covered
AntennaL1 Characteristics2.
Specifications
L2
L5
L6
GPS/QZSS
1575.42MHz
1227.6MHz
1176.45MHz
1278.75MHz
L5R
L3PT
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
E5a
1176.45MHz
E5b
1201.5MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
L1
1575.42MHz
3. GLONASS
Antenna
Characteristics
1176.45MHz
1201.5MHz
Galileo
4.
Antenna□ Radiation
Patterns3.
Antenna
B1
BeiDou
Characteristics2.
1561MHz
Compass
3.
B3
Specifications
1268.52MHz
E5B(B2)/ E6(B3)
1268.56MHz
E2(B1)
1561MHz
Antenna□ Characteristics2.
Specifications
SBAS
3.
B2
1207.14MHz
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
GNSS Electrical
Frequency (MHz)
4.
1561
1575.42
1602
48.3
56.2
42.6
44.7
55.7
61.5
-3.16
-2.50
-3.71
Antenna
Radiation
Patterns-3.49
30x30cm Ground
plane
-2.54
-2.11
1.88
1.05
2.56
4.13
Efficiency
Antenna Radiation Patterns3.
Antenna
Free space
Characteristics
30x30cm Ground plane
Average Gain (dB)
Free space
4.
Peak Gain (dBi)
Free space
4.
1.08
30x30cm Ground
plane
1.32 Antenna
Antenna
Radiation
Patterns3.
Polarization
RHCP
Characteristics
Impedance
50Ω
Return Loss
4.
很抱歉,暂时无法提供与“MA111.C.LB.001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+464.70558
- 5+456.16934
- 10+447.54845
- 19+438.92757
- 国内价格 香港价格
- 1+813.796341+105.75022
- 10+715.5614010+92.98491
- 25+681.5927925+88.57080
- 100+635.07772100+82.52631
