Hercules
A.01.C.301111
Specification
Part No.
A.01.C.301111
Product Name
GPS Hercules Heavy Duty Screw Mount Antenna
Description
Two Stage 30dB Active GPS Antenna.
Height 29mm, Diameter 49mm
UV and Vandal Resistant PC Housing
IP67 & IP69K Waterproof Rating
3M RG-174 SMA(M) – Standard
RoHS Compliant
Applications
Location based services
M2M
Telematics
Remote monitoring
Timing for base stations
Vehicle fleet tracking
SPE-11-8-018/I/SS
page 1 of 10
1. Introduction
The A.01 Hercules is a high performance thread mount GPS antenna designed for external use on vehicles
and outdoor assets. Designed for heavy duty work with one piece C&C machined nickel steel base plate and
threads, there are also convenient side slots for running cables laterally. Durable UV resistant ABS housing is
resistant to vandalism and direct attack. At only 29mm high it complies with the latest EU directives for height
restrictions, whilst also enabling covert operation with a diameter of 49mm.
Cable lengths, types and connectors are fully customizable. For cable lengths above 5M please use our 40dB
LNA A.03 model and low loss cable.
SPE-11-8-018/I/SS
page 2 of 10
2.
Electrical Specifications
Parameter
Specification
Frequency
1575.42MHz ± 1.023MHz
Dimensions
Height 29mm, Diameter 49mm,
Impedance
50 ohm
VSWR
2.0 Max
GPS Patch Gain
2.0dB Passive Gain at Zenith
-1.0dBi Gain at 10 degrees elevation
Axial ratio
3.0 dB max
Polarization
RHCP
fo = 1575.42MHz
fo ± 30 MHz 5dB Min.
Out Band Rejection
fo ± 50 MHz 20dB Min.
fo ± 100 MHz 25dB Min.
Input Voltage
Min.1.8V
Typ. 3.0V
Max. 5.5V
Total Gain @ Zenith
25dBic
30dBic
32dBic
Current Consumption
6mA
12mA
30mA
Noise Figure
2.7dB
3.0dB
3.7dB
SPE-11-8-018/I/SS
page 3 of 10
3. LNA
3.1 LNA Functional Circuit
GPS + GNSS
Antenna
SAW
Filter
Low Noise
Amplifier
RG-174
Low Noise
Amplifier
DC-INPUT
Coaxial Cable
3.2 LNA Gain and Out-band Rejection @ 3.0V
Tr1 S21 Log mag 10.00dB/ ref -40.00dB [F2]
60.00
›1
1.5754200 GHZ 30.649 dB
Ch1
Ch1
Ch1
Ch1
Ch1
Ch1
Ch1
50.00
40.00
1
Tr1 >1
Tr1
2
Tr1
3
Tr1
4
Tr1
5
Tr1
6
Tr1
7
1.5754200 Ghz
1.6054200 Ghz
1.5454200 Ghz
1.6254200 Ghz
1.5254200 Ghz
1.6754200 Ghz
1.4754200 Ghz
30.649 dB
-6.709 dB
24.584 dB
-5.635 dB
8.073 dB
-15.436 dB
1.571 dB
30.00
20.00
3
10.00
5
0.00
7
-10.00
-20.00
2
4
6
-30.00
-40.00
SPE-11-8-018/I/SS
page 4 of 10
3.4 LNA Noise Figure at DC 3V
Mkr 1
1.5754 Mhz
2.909 dB
30.298dB
9.000
NFIG
Scale/
1.000
dB
1
-1.000
40.00
1
GAIN
Scale/
5.000
dB
-10.000
Centre 1.57542 Ghx
Tcold 296.50k
BW 4 Mhz
Avgs 16
Points 11
Att 0/--dB
Span 3.00 Mhz
Loss Off
Corr
SPE-11-8-018/I/SS
page 5 of 10
4.
Radiation Patterns
0̊
5.00dB
0.00dB
-5.00dB
-10.00dB
-15.00dB
-20.00dB
-25.00dB
-30.00dB
90 ̊
-40.00dB
270 ̊
180 ̊
0 degree is the top of Hercules
SPE-11-8-018/I/SS
page 6 of 10
5.
Mechanical Specifications
Parameter
Specification
Housing
UV resistant PC
Thread and Base Plate
Nickel Plated Steel/Zinc
Sealing Foam
CR4305 with 3M9448B double-side adhesive
Waterproof
IP67 & IP69K
Thread Diameter
18mm
Recommended Mounting Torque
24.5N·m
Maximum Mounting Torque
29.4N·m
Operating Temperature
-40ºC ~ +85ºC
Storage Temperature
-40ºC ~ +105ºC
Cable/Connectors
3M RG-174 Cables and SMA Connector (std)
Fully Customizable
SPE-11-8-018/I/SS
page 7 of 10
6.
Mechanical Drawing
Name
Material
PC
Black 1
2
Closed Cell Foam
CR 4305
Black
1
3
3M Double Adhesive
3M 9448 HK
White Liner
1
4 M18 Inner Nut
Carbon Steel
Ni Plated
1
5
Outer Nut Cover
ABS
Black
1
6
M18x2,5 Thread
Zinc Alloy
Ni Plated
1
7
Heat Shrink Tube
PE
Black
1
8
GPS Label
Coated paper
Orange
1
9
Rubber Stopper
Rubber
Black
1
Name
1 Housing
Finish Qty
Spec
3000 ± 60mm
Finish Qty
1
YY Cable Type
RG-174
Black
1
ZZ Connector Type
SMA(M) ST (GPS)
Gold
1
XX Cable Length
SPE-11-8-018/I/SS
page 8 of 10
7. Installation
Recommended torque for mounting is 24.5N·m
Maximum torque for mounting is 29.4N·m
SPE-11-8-018/I/SS
page 9 of 10
8.
Packaging
1pc antenna per PE Bag
40 big PE bags per box
Unit : mm
Taoglas makes no warranties based on the
accuracy or completeness of the contents
of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document
and the information contained herein.
Reproduction, use or disclosure to third
parties without express permission is
strictly prohibited.
Copyright © Taoglas Ltd.
SPE-11-8-018/I/SS
| page 10 of 10
很抱歉,暂时无法提供与“A.01.C.301111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+762.528801+98.65346
- 5+414.153545+53.58182
- 10+403.1801210+52.16211
- 25+386.4152425+49.99313
- 50+347.7546450+44.99135
