MA741.A.BI.001
MA741.A.BI.001
    TAOGLASLIMITED
    MA741.A.BI.001
MA741.A.BI.001 数据手册
Pantheon MA741.A.BI.001 Specification Part No. MA741.A.BI.001 Product Name Pantheon Pantheon Antenna 2in1 MA.741 Screw-Mount (Permanent Mount) LTE Cellular 2G/3G/4G 2*2 MIMO Feature 2 x LTE Cellular (2G/3G/4G) Antennas (MIMO) Works for LTE/GSM/GPRS/CDMA/UMTS/HSPA 698~960MHz, 1710~2170MHz, 2300~2700MHz, 2900-3500MHz IP67 Waterproof High Efficiency / Peak Gain Outdoor Antenna 3M CFD-200 SMA(M) RoHS Compliant SPE-14-8-013/B/WY | page 1 of 16 1. Introduction The MA.741 Pantheon LTE MIMO 2*2 antenna is an omnidirectional heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation and remote monitoring applications. It includes two LTE MIMO antennas, with the highest efficiency and peak gain possible. This is necessary for today’s high speed data uplink and downlink systems in applications such as real time video, for maximum throughput and highest signal to noise ratio. The antenna elements operate at all common 2G, 3G and 4G LTE bands worldwide 698-960MHz, 1710-2170MHz, 2300~2700MHz, 2900-3500MHz. The housing is an extremely robust IP67 direct mount antenna package with excellent isolation (20dB+). The antenna has its own ground-plane and can radiate on any mounting environment like metal or plastic without affecting performance. The connectors and cable length are customizable. It is also available in White. SPE-14-8-013/B/WY | page 2 of 16 2. Specification 2G/3G/4G MIMO 1 LTE GSM 850 GSM 900 DCS PCS WCDMA I ISM LTE Frequency 698~787 824~896 880~960 1710~1880 1850~1990 1920~ 2170 2400~2500 2600~3500 Return Loss
MA741.A.BI.001 价格&库存
很抱歉,暂时无法提供与“MA741.A.BI.001”相匹配的价格&库存,您可以联系我们找货
