RFANT8010080A3T
RFANT8010080A3T
    WALSIN(华新科)
    SMD_8X1MM
    2.4GHz Bluetooth, WLAN Chip RF Antenna 2.4GHz ~ 2.5GHz 2dBi Solder Surface Mount
RFANT8010080A3T 数据手册
Approval sheet RFANT Series – RoHS Compliance CERAMIC ANTENNA Halogens Free Product 2.4 GHz ISM Band Working Frequency P/N: RFANT8010080A3T *Contents in this sheet are subject to change without prior notice. Page 1 of 9 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet FEATURES 3 Surface Mounted Devices with a small dimension of 8.0 x 1.0 x 0.8 mm meet future miniaturization trend. Low profile for thin type terminal High Stability in Temperature / Humidity Change High mechanical strength 1. 2. 3. 4. APPLICATIONS Bluetooth Wireless LAN HormRF ISM band 2.4GHz wireless applications 1. 2. 3. 4. CONSTRUCTION 1 3 PIN Connection 1 Identification Mark 2 Soldering terminal 3 Feeding 2 DIMENSIONS Figure Page 2 of 9 Symbol Dimension (mm) L 8.00 ± 0.20 W 1.05 ± 0.20 T 0.80 ± 0.10 A 0.30 ± 0.20 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet ELECTRICAL CHARACTERISTICS RFANT8010080A3T Specification Working Frequency Range 2.4 GHz ~ 2.5GHz Gain 2 dBi (Typical) VSWR 2 max. Polarization Linear Azimuth Beamwidth Omni-directional Impedance 50Ω Rated Power (max.) 3 Watts Maximum Input Power 5 Watts for 5 minutes Operation Temperature -40˚C ~ +85˚C Remark: The specification is defined based on the test board dimension as in below SOLDER LAND PATTERN DESIGN Figure (Vertical type) Page 3 of 9 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet Antenna on Test Board ( FR4 Thickness 0.8mm) Vertical type Antenna S11 on Test Board Vertical type -15.34 dB @ 2.40 GHz -17.55 dB @ 2.45 GHz -15.17 dB @ 2.50 GHz Page 4 of 9 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet RADIATION PATTERN (Vertical type) Radiation Pattern and Gain were dependent on measurement board design. The specification of RFANT8010080A3T antenna was measur ed based on the PCB size and installation position as shown in the below figure Test Board Z x Y Vertical Horizontal 90 120 90 60 0 120 -10 -10 150 Plane Average Gain= 1.136 dBi Y 150 30 Y -20 Y-Z -30 -40 0 Z 210 180 240 -40 330 240 300 300 270 270 Peak Gain= -0.06 dBi Average Gain=-7.16 dBi Peak Gain = 3.25 dBi Average Gain = 0.44 dBi X Cut X Cut 90 90 120 60 0 Plane Average Gain= -1.750dBi 150 30 -20 X-Z -30 -40 Z X 210 240 0 180 -40 240 300 300 Peak Gain= 3.12 dBi Average Gain= -2.59 dBi X Cut X Cut 90 90 120 60 Plane Average Gain= -2.322 dBi 150 30 -20 X-Y x -30 -40 0 Y 210 240 180 -40 0 Y 240 300 Peak Gain= -2.43 dBi Average Gain= -7.10dBi x 210 330 330 300 270 270 Page 5 of 9 30 -20 -30 180 60 0 -10 -10 150 330 270 Peak Gain= -2.68 dBi Average Gain= -9.30dBi 0 0 Z X 210 330 270 120 30 -20 -30 180 60 0 -10 -10 150 0 Z 210 330 120 30 -20 -30 180 60 0 Peak Gain= 0.96 dBi Average Gain= -4.08 dBi ASC_RFANT8010080A3T_V04 May.2013 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235 ± 5°C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2 ± 0.5 sec electrode must be covered by fresh solder. JESD22-B102D Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260 ± 5°C (Resistance to *Leaching immersion time:30 ± 0.5 sec dissolution of Loss of metallization on the edges of each electrode shall not exceed 25%. Solder : SN63A metallization) IEC 60068-2-58 Resistance to soldering *Preheating temperature:120~150℃, No mechanical damage. heat JIS C 0050-5.4 1 minute. Electrical specification shall satisfy the *Solder temperature:270±5°C descriptions in electrical characteristics under *Immersion time:10±1 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 24±2 hrs Drop Test JIS C 0044 Customer’s specification. *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 Page 6 of 9 *Pressurizing force: 5N(≦0603);10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec ASC_RFANT8010080A3T_V04 May.2013 Approval sheet Bending test The middle part of substrate shall be JIS C 0051- 7.4.1 pressurized by means of the pressurizing rod Electrical specification shall satisfy the No mechanical damage. at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 5±1 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 24±2 hours Temperature cycle JIS C 0025 1. 30±3 minutes at -40°C±3°C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 30±3 minutes at +85°C±3°C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 24±2 hrs High temperature JIS C 0021 *Temperature:85°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 24±2 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:40±2°C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 24±2 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 24±2 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 7 of 9 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2 Fig 2. Infrared soldering profile ORDERING CODE RF Walsin HF: RF /Pb free device ANT 801008 Product code Dimension code ANT : Antenna 0 A Unit of dimension Per 2 digits of Length, Width, Thickness : 0 : 0.1 mm 3 T Application Specification Packing A : 2.4GHz ISM Band Design Code T : Reeled 1 : 1.0 mm e.g. : 801008 = Length 80, Width 10, Thickness 8 Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Ao Bo ΦD T W Dimension (mm) 1.20 ± 0.10 8.20 ± 0.10 1.50 ± 0.10 1.00 ± 0.10 16.0 ± 0.10 Index E F Po P1 P2 Dimension(mm) 1.75 ± 0.10 7.50 ±0.10 4.00 ± 0.05 4.00 ± 0.10 2.00 ± 0.05 Page 8 of 9 ASC_RFANT8010080A3T_V04 May.2013 Approval sheet Reel dimensions C Index Dimension (mm) A B A B C Φ178 Φ60.0 Φ13.0 Typing Quantity: 2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) Aircraft equipment (2) Aerospace equipment (3) Undersea equipment (4) Medical equipment (5) Disaster prevention / crime prevention equipment (6) Traffic signal equipment (7) Transportation equipment (vehicles, trains, ships, etc.) (8) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be confirmed. (2) Storage environment condition. Products should be storage in the warehouse on the following conditions. Temperature : -10 to +40°C Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. Page 9 of 9 ASC_RFANT8010080A3T_V04 May.2013
RFANT8010080A3T 价格&库存
很抱歉,暂时无法提供与“RFANT8010080A3T”相匹配的价格&库存,您可以联系我们找货
