MA750.A.ABICG.003
MA750.A.ABICG.003
    TAOGLASLIMITED
    Pantheon MA750 5-in-1 Permanent Mount Antenna 是一种全向重型、完全防水的外部 M2M 天线,适用于远程信息处理、运输和远程监控应用。该天线提供了强大的 5...
MA750.A.ABICG.003 数据手册
Pantheon MA750 5-in-1 Permanent Mount Antenna Part No: MA750.A.ABICG.003 Description: Pantheon MA750 5-in-1 Permanent Mount Antenna GPS/GLONASS/Galileo, 5G/4G MIMO, 2.4/5.8Hz MIMO Features: 2 x 5G/4G 600-6000MHz Antennas (MIMO) 1 x GPS/GLONASS/Galileo 1575.42/1602MHz Active Antenna 2 x Wi-Fi 2.4GHz/5.8GHz Antennas (MIMO) IP67 Waterproof Front End SAW Filter High Efficiency / Peak Gain Outdoor Antenna Dimensions: Ø143.2 x 82.4mm Fully Customizable Cable and Connectors RoHs & Reach Compliant SPE-12-8-146-K 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 9 4. Radiation Patterns 17 5. Mechanical Drawing 39 6. Installation 40 7. Packaging 41 Changelog 42 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. The Taoglas MA750 Pantheon 5-in-1 antenna is an omnidirectional heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation, and remote monitoring applications. This unique antenna delivers powerful MIMO antenna technology for 5G/4G Cellular and Wi-Fi, plus GNSS for next-generation multiple wireless technology systems. The GNSS antenna covers the GPS/GLONASS/Galileo bands and includes a Front End SAW Filter for improved performance. Introduction The Pantheon MA750 covers all 5G bands from 600-6000MHz, exhibiting excellent performance at key 5G bands such as band 71(617MHz) and the repurposed CBRS and C-band frequencies from 3400-4200MHz. This ensures the Pantheon is prepared for mission critical applications. Introduction Typical Applications Include: 1. - Public Safety Passenger Bus and Rail Services Digital Signage Commerical Transportation and Fleet Management Introduction All five high-performance antennas are integrated into an extremely robust IP67 permanent mount compact antenna package measuring just 82.4mm in height and 143.2mm in diameter. The antenna has its own ground-plane and can radiate on any mounting environment like metal or plastic without affecting performance. The cables are low loss allowing for lengths of up to 10 meters (32' and 9.70"), critical for buses, trains, and other commercial transport applications. Customized cables and connector version available, contact your regional Taoglas customer support team for further information SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 2. Specifications GNSS Frequency Bands Covered L1 L2 L5 L6 3. Specifications GPS/QZSSAntenna Characteristics2. 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz GLONASS 3. ■ □ □ □ L5R 1176.45MHz L3PT 1201.5MHz L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ ■ ■ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ □ ■ Antenna Characteristics Galileo 4. □ □ □ □ Antenna Radiation Patterns3. Antenna B1 B2 1207.14MHz B3 □ □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz BeiDou 1561MHz Characteristics2. Compass 3. SBAS 3. 4. 1268.52MHz Specifications Antenna Characteristics2. □ □ Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ ■ Antenna Characteristics GNSS Electrical Centre Frequency 1575.42MHz / 1602MHz Bandwidth 10MHz Antenna Radiation Patterns3.Antenna Radiation Efficiency 2 Impedance 50Ω DC Power Input Range 3 - 5V DC Input 4. 3.3V 4.0V Antenna Radiation Frequency 1575.42 Patterns 1602 5.5V 1575.42 1602 1575.42 1602 VSWR 2 2 2 2 2 2 LNA Gain 29.2 29 31 31 32.3 32 3.2 3.4 3.4 9.4 15 15 3.1 3.1 3.2 Antenna Radiation Patterns3. Antenna Noise Figure Power Consumption Characteristics Band Attenuation 4. 50(without cable) VSWR Characteristics 4. Specifications 7.5 7.5 1520MHz: -20dB 1642MHz: -20dB 9.4 1520MHz: -20dB 1642MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-146-K SPE-12-8-146-K Specifications www.taoglas.com 5G/4G MIMO Band Efficiency Frequency (MHz) (%) MIMO 1 5GNR/4G Band 5,8,12,13,14,17,18,20, 26,27,28, 29,71 MIMO 1 MIMO 1 MIMO 1 MIMO 1 MIMO 1 MIMO 1 3.3 30X30cm GroundPlane 35 -1.7 3.5 Free Space 69 -4.7 2.5 30X30cm GroundPlane 26 -6.1 1.4 Free Space 36 -4.4 2.8 30X30cm GroundPlane 21 -4.8 2.8 Free Space 34 -7.0 -0.5 30X30cm GroundPlane 18 -7.8 0.5 Free Space 58 -2.4 3.1 30X30cm GroundPlane 48 -2.4 5.4 Free Space 57 -3.2 3.2 30X30cm GroundPlane 47 -3.3 4.4 Free Space 44 -3.6 2.1 30X30cm GroundPlane 64 -3.2 4.0 Free Space 47 -1.9 5.2 30X30cm GroundPlane 67 -1.8 5.8 Free Space 51 -3.0 4.6 30X30cm GroundPlane 65 -2.6 4.7 Free Space 55 -1.9 5.4 30X30cm GroundPlane 68 -1.7 6.2 Free Space 34 -5.2 5.8 30X30cm GroundPlane 41 -5.1 8.1 Free Space 35 -4.0 4.7 30X30cm GroundPlane 42 -3.9 6.8 Free Space 16 -8.1 1.2 30X30cm GroundPlane 23 -8.2 2.4 Free Space 16 -6.5 3.0 30X30cm GroundPlane 22 -6.7 3.3 Polarization 3 Max 50Ω Linear 5150~5925 MIMO 2 SPE-12-8-146-K SPE-12-8-146-K -2.2 Impedance 3300~5000 MIMO 2 LTE5200/ Wi-Fi 5800 61 VSWR 2490~2690 MIMO 2 5GNR/4G Band 22,42,43,48,77,78,79 Free Space 2400~2500 MIMO 2 4G/3G Band 7,38,41 (dBi) 1710~2200 MIMO 2 Wi-Fi 2400 (dB) 1427~1518 MIMO 2 4G/3G Band 1,2,3,4,9,23,25,35,39,66 Peak Gain 617~960 MIMO 2 5GNR/4G Band 21,32,74,75,76 Average Gain www.taoglas.com Wi-Fi MIMO 2.4GHz / 5GHz Efficiency (%) Average Gain (dB) Peak Gain (dBi) MIMO 1 36 -4.5 3.7 MIMO 2 57 -2.4 2.2 Frequency (MHz) VSWR Polarization Impedance 2 Max Linear 50 Ω 2400~2500 MIMO 1 51 -2.9 5.4 MIMO 2 50 -3.1 4.8 5150~5850 All measurements were conducted with 0.5m low loss CFD-200 cable. SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com Mechanical Antenna Dimensions Height 82.4mm x Diameter 143.19mm Casing Wonderloy PC-540 PC/ABS Alloy Waterproof IP67 Cables 5G/4G & Wi-Fi – 3m CFD-200 GNSS – 3m RG-174 Connectors GNSS & 5G/4G – SMA(M) Wi-Fi – RP-SMA(M) Base and thread CAN10 Zinc Alloy Thread diameter M30 x 2 (30mm) Nut Nickel Plated Steel Foam 3M 9448HK Weight(kg) 1.29 Recommended Torque for Mounting 5-7Nm Envioronmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 90°C Humidity Non-condensing 65°C 95% RH SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink 1 2 3 4 5 7 8 9 11 12 13 14 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 35 38 39 40 41 42 43 48 66 71 74/75/76 78 79 85 SPE-12-8-146-K SPE-12-8-146-K Downlink Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -5 4. Antenna Radiation Patterns Return Loss [dB] 4. -10 -15 Antenna Radiation Patterns3.Antenna Characteristics -20 Free Space - MIMO1 Free Space - MIMO2 30cm X 30cm Groundplane - MIMO1 30cm X 30cm Groundplane - MIMO2 -25 4. 600 1100 1600 2100 2600 3100 3600 Antenna Radiation Patterns3. Antenna Frequency [MHz] 4100 4600 5100 5600 Characteristics 3.2 Efficiency 100 4. Free Space -MIMO1 Antenna Radiation Patterns 90 Free Space -MIMO2 30cm X 30cm Groundplane -MIMO1 80 30cm X 30cm Groundplane -MIMO2 70 4. Antenna Radiation Patterns 60 Efficiency [%] 4. 50 40 Antenna Radiation Patterns 30 20 10 4. 0 Antenna Radiation Patterns3.Antenna 600 1100 Characteristics 4. 1600 2100 2600 3100 3600 4600 5100 5600 Frequency [MHz] Antenna Radiation Patterns3.Antenna SPE-12-8-146-K SPE-12-8-146-K 4100 www.taoglas.com 3.3 Peak Gain 8 7 6 5 4 Gain [dBi] 3 2 1 0 -1 -2 Free Space -MIMO1 -3 Free Space -MIMO2 -4 30cm X 30cm Groundplane -MIMO2 -5 30cm X 30cm Groundplane -MIMO1 -6 600 1100 1600 2100 2600 3100 3600 4100 4600 5100 5600 5100 5600 Frequency [MHz] 3.4 Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 Free Space -MIMO1 -8 Free Space -MIMO2 -9 30cm X 30cm Groundplane -MIMO1 30cm X 30cm Groundplane -MIMO2 -10 600 1100 1600 2100 2600 3100 3600 4100 4600 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.5 Return Loss – WiFi MIMO 1 &2 (2.4/5 GHz) 0 Return Loss [dB] -5 -10 -15 -20 -25 Wi-Fi 1 -30 2000 Wi-Fi 2 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] 3.6 VSWR - WiFi MIMO 1 &2 (2.4/5 GHz) 5.0 Wi-Fi 1 Wi-Fi 2 VSWR 4.0 3.0 2.0 1.0 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.7 Isolation – WiFi MIMO 1 &2 (2.4/5 GHz) 0 WiFi - 1 WiFi - 2 -5 Isolation -10 -15 -20 -25 -30 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] 3.8 Efficiency - WiFi MIMO 1 &2 (2.4/5 GHz) 100 90 80 Efficiency [%] 70 60 50 40 30 20 Wi-Fi 1 10 Wi-Fi 2 0 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.9 Peak Gain - WiFi MIMO 1 &2 (2.4/5 GHz) 8 Gain [dBi] 6 4 2 0 Wi-Fi 1 Wi-Fi 2 -2 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] 3.10 Average Gain - WiFi MIMO 1 &2 (2.4/5 GHz) 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 Wi-Fi 1 -9 Wi-Fi 2 -10 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.11 Block Diagram - GPS/GLONASS/GALILEO 3.12 Return Loss - GNSS 0 -5 Return Loss [dB] -10 -15 -20 -25 -30 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.13 GNSS – Efficency 100 Efficiency [%] 75 50 25 0 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] 3.14 GNSS – Peak Gain 10 5 Gain [dBi] 0 -5 -10 -15 -20 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 3.15 GNSS – Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 -10 1400 1450 1500 1550 1600 1650 1700 Frequency [MHz] 3.17 GNSS - Axial Ratio 22 20 18 16 Axial Ratio 14 L1/E1/B1/G1 12 10 8 6 4 2 0 1500 1520 1540 1560 1580 1600 1620 1640 1660 Frequency [MHz] SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 4. Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup VNA Test Set-up 4. Chamber Test Set-up Antenna Radiation Patterns SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 4.2 705MHz 3D and 2D Cellular Radiation Patterns XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 750MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 825MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 880MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 960MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 1710MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 1880MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 1990MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 2170MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 2300MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 2500MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 2570MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 2700MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 3200MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 4200MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 5150MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 5550MHz XY Plane SPE-12-8-146-K SPE-12-8-146-K XZ Plane YZ Plane www.taoglas.com 4.3 Wi-Fi 3D and 2D Radiation Patterns XZ Plane YZ Plane XY Plane Wi-Fi 1 Wi-Fi 2 SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 5.5GHz XZ Plane YZ Plane XY Plane Wi-Fi 1 Wi-Fi 2 SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 5.8GHz XZ Plane YZ Plane XY Plane Wi-Fi 1 Wi-Fi 2 SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com 4.4 GNSS 3D and 2D Radiation Patterns XZ Plane SPE-12-8-146-K SPE-12-8-146-K YZ Plane XY Plane www.taoglas.com 5. Mechanical Drawing rawing (Units: mm) 6. Packaging5. 6. Packaging 7. SPE-12-8-146-K SPE-12-8-146-K Mechanical Drawing Application Note6. Packaging5. Mechanical www.taoglas.com 6. 8. Installation Packaging 6. 6. Packaging5. Packaging5. 6. 6. Packaging Packaging Mechanical Drawing Mechanical Drawing 7. Application Note6. Packaging5. 7. Application Note6. Packaging5. Drawing Drawing 6. 6. Packaging5. Packaging5. 6. 6. Packaging Packaging 7. 7. Application Note6. Packaging Application Note6. Packaging 7. 7. Application Note Application Note 7. 7. Application Note6. Packaging Application Note6. Packaging Mechanical Drawing Mechanical Drawing 7. Application Note6. Packaging5. 7. Application Note6. Packaging5. Drawing Drawing 6. SPE-12-8-146-K Packaging5. 6. SPE-12-8-146-K Packaging5. Mechanical Mechanical Mechanical Mechanical Mechanical Drawing Mechanical Drawing www.taoglas.com 7. 8. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-146-K SPE-12-8-146-K Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-12-8-046 – MA750.A.ABIC.003 Revision: K (Current Version) Date: Changes: Changes Made by: 2021-11-10 Rebranded as 5G & updated datasheet template to new template. Gary West Previous Revisions Revision: J Revision: E Date: Changes: Changes Made by: 2020-08-08 Updates Peter Knaz Revision: I Date: Changes: Changes Made by: 2013-07-11 Added GPS/GLONASS Aine Doyle Revision: D Date: Changes: Changes Made by: 2017-06-04 Added LTE Band Table Peter Monahan Revision: H Date: Changes: Changes Made by: 2013-03-27 Amended to GPS/GLONASS & Front End SAW Filter Aine Doyle Revision: C Date: Changes: Changes Made by: 2015-03-20 Added packaging and updated torque Aine Doyle Revision: G Date: Changes: 2012-12-14 Changes Made by: Revision: B Date: Changes: Changes Made by: 2014-04-08 Changed page 4 Iron to Steel Aine Doyle Revision: F Date: Changes: 2012-11-27 Changes Made by: Revision: A (Original First Release) Date: Changes: Changes Made by: SPE-12-8-146-K SPE-12-8-146-K 2014-03-18 Amended spec table to say RP-SMA for Wi-Fi Aine Doyle Date: 2012-11-26 Notes: Author: www.taoglas.com Previous Revisions (Continued) SPE-12-8-146-K SPE-12-8-146-K www.taoglas.com SPE-12-8-146-K SPE-12-8-146-K © Taoglas www.taoglas.com
MA750.A.ABICG.003 价格&库存
很抱歉,暂时无法提供与“MA750.A.ABICG.003”相匹配的价格&库存,您可以联系我们找货
