MA710.A.ABI.001
MA710.A.ABI.001
    TAOGLASLIMITED
    MA710.A.ABI.001
MA710.A.ABI.001 数据手册
SPECIFICATION Part No. : MA710.A.ABI.001 Product Name : Pantheon Antenna 3in1 MA.710 Screw-Mount (Permanent Mount) 2 x 2G/3G/4G LTE MIMO Cellular Antenna 1 x GPS/GLONASS Antenna Feature : ● 2 x Cellular 2G/3G/4G Antennas (MIMO) LTE/HSPA/GSM/GPRS/CDMA/UMTS 698~960MHz/1710~2170MHz/2300~2700MHz/2900-3500MHz ● 1 x GPS/GLONASS 1575.42/1602MHz Active Antenna IP67 Waterproof High Efficiency / Peak Gain Outdoor Antenna RoHS Compliant SPE-13-8-073/C/SS Page 1 of 19 1. Introduction The MA710 Pantheon antenna is an omnidirectional heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation and remote monitoring applications. It includes two LTE MIMO antennas and one GPS/GLONASS antenna, in the highest efficiency and peak gain possible. This antenna particularly finds its application in mobile video, vehicle communications, location and fleet management, safety & security, remote industrial equipment monitoring. The antenna consists of two LTE MIMO elements 698-960MHz, 1710-2170MHz, 2300~2700MHz, 2900-3500MHz. The antennas are designed to work equally well on LTE to deliver maximum data rates, or on legacy 2G and 3G frequencies where LTE is not available. The GNSS antenna is a wide-band GPS/GLONASS element tuned to have optimum gain at 1575.42 MHz GPS and 1602MHz Glonass frequencies. Mechanically, we have packed 3 high efficiency and gain antennas in an extremely robust IP67 direct mount antenna package with excellent isolation (20dB+). The strengthened domed housing is designed to deflect tree branches and wires that tend to catch and break shark fin or rigid whip antennas. The Pantheon has its own internal ground-plane and can radiate on any mounting environment such as metal or plastic without affecting performance. The internal components are individually screwed down onto a robust plate, preventing damage from regular vehicle vibrations. A completely waterproof mounting seal prevents water from leaking under the housing. The connectors and cable length are customizable. It is also available in White (MA710W). SPE-13-8-073/C/SS Page 2 of 19 2. Specification Table 2G/3G/4G MIMO GSM 850 824~ 896 LTE Frequency 698~ 787 GSM 900 880~ 960 DCS PCS 1710~ 1880 1850~1 990 WCDMA I 1920~ 2170 ISM LTE 2400~ 2500 2600~3500 MHz MIMO 1 VSWR (max.) 2.5 2.5 3 2.5 2.5 2.5 3 2.5 Efficiency 66.17 51.88 47.87 39.97 47.67 45.97 28.73 38.35 % Peak Gain 2.52 1.48 1.15 1.03 1.22 1.22 0.15 3.20 dBi MIMO 2 VSWR (max.) 3.5 3.5 3.5 2.5 2.5 2.5 2 2.5 Efficiency 35.98 18.41 20.24 40.85 35.42 37.68 42.27 35.24 % Peak Gain 1.56 -2.08 -2.31 1.69 0.86 2.06 2.99 2.97 dBi Polarization Vertical Impedance 50 Ω GPS-GLONASS Centre Frequency 1575.42MHz / 1602MHz Bandwidth 10MHz Radiation Efficiency Passive Gain @ Zenith VSWR 50 % (without cable) 4.0 dBi typ. (with ψ=140mm ground) 2 Impedance 50Ω DC Power Input Range DC input 1.8V ~ 5V 1.8V 3.3V 4.0V 5.5V MHz 1575.42 1602 1575.42 1602 1575.42 1602 1575.42 1602 VSWR 2 2 2 2 2 2 2 2 LNA Gain 17 17 29.2 29 31 31 32.3 32 Noise Figure Power Consumption 3.4 3.4 3.1 3.1 3.2 3.2 3.4 3.4 3.2 3.2 7.5 7.5 9.4 9.4 15 15 Band Attenuation 1535MHz: -20dB 1642MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB Cable 3m RG174 standard Connector SMA(M) standard SPE-13-8-073/C/SS 1520MHz: -20dB 1642MHz: -20dB Page 3 of 19 MECHANICAL Antenna Dimensions Height 85.7mm x Diameter 145.6mm Casing Wonderloy PC-540 PC/ABS Alloy Waterproof IP67 2G/3G/4G MIMO 1 3M Low Loss CFD-200 SMA(M) 2G/3G/4G MIMO 2 3M Low Loss CFD-200 SMA(M) GPS/GLONASS 3M RG-174 SMA(M) ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 90°C Humidity Non-condensing 65°C 95% RH * all measurements were conducted with 3m low loss CFD200 cable on cellular and RG-174 cable on GPS/Glonass SPE-13-8-073/C/SS Page 4 of 19 LTE BANDS Band Number LTE/LTE- Advanced /WCDMA/HSPA.HSPA+ Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 (LTE only) 18 UL: 815 to 830 DL: 860 to 875 (LET only) 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 (LTE only) 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 (LTE only) 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 (LTE only) 28 UL: 703 to 748 DL: 758 to 803 (LTE only) 29 UL: - DL: 717 to 728 (LTE only) 30 UL: 2305 to 2315 DL: 2350 to 2360 (LTE only) 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 (LTE only) 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 MIMO 1 MIMO 2 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓  ✓  ✓  ✓ ✓ ✓ ✓      ✓ ✓ ✓    ✓ ✓   ✓ ✓ ✓ ✓ ✓   SPE-13-8-073/C/SS Page 5 of 19 LTE MIMO 2.1. LTE MIMO 1 and LTE MIMO 2 Specification 2.1.1. Return Loss LTE MIMO 1 LTE MIMO 2 2.1.2. Maximum Gain LTE MIMO 1 LTE MIMO 2 SPE-13-8-073/C/SS Page 6 of 19 2.1.3. Average Gain LTE MIMO 1 LTE MIMO 2 2.1.4. Efficiency LTE MIMO 1 LTE MIMO 2 SPE-13-8-073/C/SS Page 7 of 19 3.2 Radiation Patterns Y Z X SPE-13-8-073/C/SS Page 8 of 19 3.2.1 LTE MIMO 1 Radiation Pattern XY plane X X Y Y X X Y Y SPE-13-8-073/C/SS Page 9 of 19 XZ Plane Z Z X X Z Z X X SPE-13-8-073/C/SS Page 10 of 19 2.1.5. 3.2.2 LTE MIMO 2 Radiation Pattern XY plane X X Y Y X X Y Y SPE-13-8-073/C/SS Page 11 of 19 XZ Plane Z Z X X Z Z X X SPE-13-8-073/C/SS Page 12 of 19 3. GPS/GLONASS 3.1. Block diagram 3.2. Return Loss SPE-13-8-073/C/SS Page 13 of 19 3.3. Radiation pattern XZ-plane Free Space @1575.42MHz SPE-13-8-073/C/SS Page 14 of 19 YZ-plane Free Space @1575.42MHz XZ-plane Free Space @1602MHz SPE-13-8-073/C/SS Page 15 of 19 YZ-plane Free Space @1602MHz SPE-13-8-073/C/SS Page 16 of 19 4.4 GPS/GLONASS LNA SPE-13-8-073/C/SS Page 17 of 19 4. Mechanical Drawing (Unit: mm) SPE-13-8-073/C/SS Page 18 of 19 5. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-13-8-073/C/SS Page 19 of 19
MA710.A.ABI.001
物料型号:MA710.A.ABI.001
器件简介:MA710 Pantheon天线是一款全向重型、完全IP67防水的外部M2M天线,适用于远程监控、交通和车辆通信等应用。它包括两个LTE MIMO天线和一个GPS/GLONASS天线,具有高效率和峰值增益。
引脚分配:文档中没有提供具体的引脚分配图,但提到了天线的连接器类型为SMA(M),并且有定制化的电缆长度和连接器选项。
参数特性: - 支持2G/3G/4G LTE MIMO Cellular和GPS/GLONASS频率。 - 高效率和峰值增益,例如LTE MIMO1的峰值增益为2.52 dBi。 - 极化方式为垂直。 - 阻抗为50欧姆。 - GPS/GLONASS天线的中心频率为1575.42MHz和1602MHz,带宽为10MHz。
功能详解: - 天线设计用于在LTE上提供最大数据速率,或在2G和3G频率上工作。 - GNSS天线被调谐以在GPS和Glonass频率上获得最佳增益。 - 天线具有自己的内部接地平面,可以在任何安装环境中辐射,如金属或塑料,不影响性能。
应用信息:适用于移动视频、车辆通信、位置和车队管理、安全与安保、远程工业设备监控等。
封装信息:天线尺寸为高85.7mm x 直径145.6mm,外壳材料为PC-540 PC/ABS合金,具有IP67防水等级。
环境规格:工作温度范围为-40°C至85°C,存储温度范围为-40°C至90°C,湿度为65°C下95% RH非凝结。
MA710.A.ABI.001 价格&库存
很抱歉,暂时无法提供与“MA710.A.ABI.001”相匹配的价格&库存,您可以联系我们找货
