M830120
M830120
    ETHERTRONICS
    SAVVICERAMICIMDGPSANT
M830120 数据手册
DATASHEET Part No. M830120 Product: 1.575GHz Ceramic Antenna Part No. M830120 GPS SavviTM Ceramic Antennas 1.575GHz Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas deliver on the key needs of device designers for higher functionality and performance in smaller/thinner designs. These innovative antennas provide compelling advantages for a GPS enabled handheld devices, media players and other mobile devices. Real-World Performance and Implementation Ceramic antennas may look alike on the outside, but the important difference is inside. Other antennas may contain simple PiFA or monopole designs that interact with their surroundings, complicating layout or changing performance with use position. Ethertronics’ antennas utilize patented IMD technology to deliver a unique size and performance combination. SavviTM Ceramic Antennas GPS 1.575 GHz Greater Flexibility Ethertronics’ first-in-class IMD technology enables you to develop concept designs that are more advanced and that deliver superior performance in reception critical applications. KEY BENEFITS Electrical Specifications Typical Characteristics, on 40x80mm PCB Stay-in-Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Quicker Time-to-Market By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Reliability Fully compliant with the European RoHS Directive 2011/65/EU. APPLICATIONS • • • • • Embedded design Cellular, Headsets, Tablets Gateway, Access Point M2M, Industrial devices Handheld 10/20/2016 Frequency 1.575GHz Peak Gain 1.78 dBi Average Efficiency VSWR Match Feed Point Impedance Polarization Power Handling 75% 1.7:1 max 50 ohms unbalanced Linear 0.5 Watt CW Mechanical Specifications Size 8.0x3.0x1.3mm Mounting Surface mount Weight Packaging Demo Board Proprietary and confidential. 0.2 g Tape & Reel, M830120 – 1,000 pieces per reel M830120-4.5K – 4,500 pieces per reel M830120-01 www.ethertronics.com DATASHEET | Part No. M830120 1.575GHz Ethertronics’ SavviTM Embedded Antenna Specifications Ethertronics produces a wide variety of standard and custom antennas to meet user needs. Below are the typical performances. Typical Return Loss and Efficiency Plots Measured on 40x80mm demo board Antenna Radiation Patterns Typical Performances on Ethertronics’ 40x80 PCB Test Board Antenna Layout For references only, tuning varies based on application 2 M830120 *All dimensions provided in this document are for informational purposes only. © 2016 Ethertronics Incorporated. tel +(1) 858.550.3820 | fax +(1) 858.550.3821 email: info@ethertronics.com 5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
M830120 价格&库存
很抱歉,暂时无法提供与“M830120”相匹配的价格&库存,您可以联系我们找货
